looking for a profile for VLC IOS
saraseb
Post Fri Mar 13, 2015 6:49 pm
The recent update of VLC on IOS is not capable to decode AC3 audio.
Would someone have a profile to transcode AC3 to AAC?
Cheers,
Seb
peter1212
Post Thu Mar 26, 2015 5:02 pm
Re: looking for a profile for VLC IOS
add this at the end of profiles.xml above </Profiles>
    <Profile id="23" name="VLC for iOS" extendsProfileId="1">
        <Video targetContainer="mpegts" targetACodec="aac">
           <Matches container="*" aCodec="ac3" />
saraseb
Post Sun Mar 29, 2015 7:21 am
Thanks,
it works. the audio is well converted.
I noticed that the subtitles and multi language options disappear.
Any idea?
Seb
Post Sun Mar 29, 2015 6:42 pm
When transcoding occurs, you lose the ability to select captions and multiple audio tracks. Nothing you can do about that unfortunately.
saraseb
Post Mon Mar 30, 2015 7:02 pm
Thanks for the info.
That's pity because I have many mkvs with multi languages in ac3.
Seb
peter1212
Post Fri Apr 03, 2015 7:19 pm
Modify audio tracks in mkv with "mkvmerge GUI" before playing.
You could try "burned in" subs by adding HardSubsTranscoding to Profile:
<HardSubsTranscoding>
    <Video targetContainer="mpegts" targetVCodec="mpeg2video" targetACodec="aac" aBitrate="384" DAR="16:9" />
</HardSubsTranscoding>
