Need help with Sony Media Player N100 US transcoding
jonwestcot
Post Fri Apr 03, 2015 1:03 am
Hi all:
I have a Sony Media Player N100 US device and I am trying to set up Serviio's transcoding to force MKV files into viewable XVid/AVI formats. I've searched here for an answer and have tried to implement what I've read, but still no luck.
Can someone help me out with working transcoding information to insert into the config.xls file? (By the way, I'm running Serviio Pro 1.5.1.) Your help is greatly appreciated.
Sincerely,
Jon
Post Tue Apr 07, 2015 4:28 pm
Re: Need help with Sony Media Player N100 US transcoding
There should be a profile for the player already, no?
jart352015yup
Post Tue Apr 07, 2015 5:16 pm
I see that profile twice in my Profiles.xml
<Profile id="bdp2010" name="Sony BDP-Sx70/SMP-N100 (2010)" extendsProfileId="bdp2012">
and this one right after it
<Profile id="bdp2010us" name="Sony BDP-Sx70/SMP-N100 (2010) - US" extendsProfileId="bdp2010">
these are the two that i see that are Sony Media Player N100
jonwestcot
Post Tue Apr 07, 2015 5:50 pm
Thank you for your replies.
I guess I didn't make my question/request clear. Yes, there is an existing entry for the SMP N100 (US) in the existing profiles.xml file. And it works very well when playing back AVI files encoded with XviD.
However, it refuses to play files encoded as MKV. I am looking for a way to force Serviio into transcoding these files into XviD format so they will play.
Thanks again. I believe that, with the forum's help, I can get this to work.
Post Wed Apr 08, 2015 10:08 pm
They should both already transcode MKV. Post ffmpeg -i of the mkv file and detailed log of playing the file pls.
jonwestcot
Post Sun Apr 12, 2015 3:03 am
Hello:
zip wrote:They should both already transcode MKV. Post ffmpeg -i of the mkv file and detailed log of playing the file pls.
My apologies for taking so long to reply to your request. Here is the information you requested:
MediaInfo data:
Unique ID                                : 231876580614500861616364103834259272301 (0xAE71CE14879C53348ED987DE8321B26D)
Complete name                            : movie.mkv
Format version                           : Version 4 / Version 2
File size                                : 851 MiB
Duration                                 : 1h 28mn
Overall bit rate                         : 1 349 Kbps
Encoded date                             : UTC 2015-02-02 10:54:25
Writing application                      : mkvmerge v7.5.0 ('Glass Culture') 64bit built on Jan  4 2015 16:48:44
Writing library                          : libebml v1.3.1 + libmatroska v1.4.2
DURATION                                 : 01:28:09.280000000
NUMBER_OF_FRAMES                         : 247935
NUMBER_OF_BYTES                          : 56265956
_STATISTICS_WRITING_APP                  : mkvmerge v7.5.0 ('Glass Culture') 64bit built on Jan  4 2015 16:48:44
_STATISTICS_WRITING_DATE_UTC             : 2015-02-02 10:54:25
_STATISTICS_TAGS                         : BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES
Format profile                           : High@L3.1
Format settings, ReFrames                : 5 frames
Duration                                 : 1h 28mn
Width                                    : 720 pixels
Height                                   : 432 pixels
Display aspect ratio                     : 5:3
Writing library                          : x264 core 144 r2525 40bb568
Encoding settings                        : cabac=1 / ref=5 / deblock=1:-2:-2 / analyse=0x3:0x113 / me=umh / subme=8 / psy=1 / psy_rd=0.80:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=crf / mbtree=1 / crf=23.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Color range                              : Limited
DURATION                                 : 01:28:09.201000000
NUMBER_OF_FRAMES                         : 126814
NUMBER_OF_BYTES                          : 834237449
Codec ID                                 : A_AAC
Duration                                 : 1h 28mn
Channel(s)                               : 1 channel
Channel positions                        : Front: C
Delay relative to video                  : 9ms
Menu
00:00:00.000                             : en:00:00:00.000
00:06:45.989                             : en:00:06:45.989
00:10:15.949                             : en:00:10:15.949
00:17:48.693                             : en:00:17:48.693
00:21:07.099                             : en:00:21:07.099
00:27:20.430                             : en:00:27:20.430
00:32:18.603                             : en:00:32:18.603
00:37:52.270                             : en:00:37:52.270
00:42:18.494                             : en:00:42:18.494
00:47:28.554                             : en:00:47:28.554
00:53:23.826                             : en:00:53:23.826
01:00:28.375                             : en:01:00:28.375
01:06:50.798                             : en:01:06:50.798
01:12:50.992                             : en:01:12:50.992
01:16:29.794                             : en:01:16:29.794
01:24:58.593                             : en:01:24:58.593
FFMpeg -i data:
ffmpeg started on 2015-04-11 at 21:57:24
Report written to "ffmpeg-20150411-215724.log"
Command line:
"c:\\program files\\serviio\\lib\\ffmpeg.exe" -report -i movie.mkv
ffmpeg version 2.4.git Copyright (c) 2000-2014 the FFmpeg developers
  built on Nov 19 2014 22:12:09 with gcc 4.7.2 (GCC)
  configuration: --enable-static --disable-shared --disable-ffplay --disable-ffserver --enable-memalign-hack --enable-libmp3lame --enable-libass --enable-librtmp --enable-fontconfig --enable-libfreetype --enable-zlib --enable-libx264 --enable-libspeex --extra-libs='-lrtmp -lpolarssl -lws2_32 -lwinmm -lexpat -lfreetype -lfribidi -lz' --arch=x86 --enable-runtime-cpudetect --enable-pthreads --target-os=mingw32 --cross-prefix=i686-w64-mingw32- --enable-gpl --pkg-config=pkg-config
  libavutil      54. 14.100 / 54. 14.100
  libavcodec     56. 12.101 / 56. 12.101
  libavformat    56. 14.100 / 56. 14.100
  libavdevice    56.  3.100 / 56.  3.100
  libavfilter     5.  2.103 /  5.  2.103
  libswscale      3.  1.101 /  3.  1.101
  libswresample   1.  1.100 /  1.  1.100
  libpostproc    53.  3.100 / 53.  3.100
Splitting the commandline.
Reading option '-report' ... matched as option 'report' (generate a report) with argument '1'.
Reading option '-i' ... matched as input file with argument 'movie.mkv'.
Finished splitting the commandline.
Parsing a group of options: global .
Applying option report (generate a report) with argument 1.
Successfully parsed a group of options.
Parsing a group of options: input file movie.mkv.
Opening an input file: movie.mkv.
[matroska,webm @ 02255E60] Format matroska,webm probed with size=2048 and score=100
st:0 removing common factor 1000000 from timebase
st:1 removing common factor 1000000 from timebase
[matroska,webm @ 02255E60] Before avformat_find_stream_info() pos: 6523 bytes read:0 seeks:33654
[h264 @ 02256F20] no picture
[matroska,webm @ 02255E60] All info found
[matroska,webm @ 02255E60] After avformat_find_stream_info() pos: 9057 bytes read:0 seeks:66422 frames:0
Input #0, matroska,webm, from 'movie.mkv':
    encoder         : libebml v1.3.1 + libmatroska v1.4.2
    creation_time   : 2015-02-02 10:54:25
  Duration: 01:28:09.29, start: 0.000000, bitrate: 1349 kb/s
    Chapter #0:0: start 0.000000, end 405.989000
      title           : 00:00:00.000
    Chapter #0:1: start 405.989000, end 615.949000
      title           : 00:06:45.989
    Chapter #0:2: start 615.949000, end 1068.693000
      title           : 00:10:15.949
    Chapter #0:3: start 1068.693000, end 1267.099000
      title           : 00:17:48.693
    Chapter #0:4: start 1267.099000, end 1640.430000
      title           : 00:21:07.099
    Chapter #0:5: start 1640.430000, end 1938.603000
      title           : 00:27:20.430
    Chapter #0:6: start 1938.603000, end 2272.270000
      title           : 00:32:18.603
    Chapter #0:7: start 2272.270000, end 2538.494000
      title           : 00:37:52.270
    Chapter #0:8: start 2538.494000, end 2848.554000
      title           : 00:42:18.494
    Chapter #0:9: start 2848.554000, end 3203.826000
      title           : 00:47:28.554
    Chapter #0:10: start 3203.826000, end 3628.375000
      title           : 00:53:23.826
    Chapter #0:11: start 3628.375000, end 4010.798000
      title           : 01:00:28.375
    Chapter #0:12: start 4010.798000, end 4370.992000
      title           : 01:06:50.798
    Chapter #0:13: start 4370.992000, end 4589.794000
      title           : 01:12:50.992
    Chapter #0:14: start 4589.794000, end 5098.593000
      title           : 01:16:29.794
    Chapter #0:15: start 5098.593000, end 5289.289000
      title           : 01:24:58.593
    Stream #0:0(eng), 4, 1/1000: Video: h264 (High), yuv420p(tv, bt709/unknown/unknown), 720x432 [SAR 1:1 DAR 5:3], 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default)
      BPS             : 1261797
      BPS-eng         : 1261797
      DURATION-eng    : 01:28:09.201000000
      NUMBER_OF_FRAMES: 126814
      NUMBER_OF_FRAMES-eng: 126814
      NUMBER_OF_BYTES-eng: 834237449
      _STATISTICS_WRITING_APP: mkvmerge v7.5.0 ('Glass Culture') 64bit built on Jan  4 2015 16:48:44
      _STATISTICS_WRITING_APP-eng: mkvmerge v7.5.0 ('Glass Culture') 64bit built on Jan  4 2015 16:48:44
      _STATISTICS_WRITING_DATE_UTC: 2015-02-02 10:54:25
      _STATISTICS_WRITING_DATE_UTC-eng: 2015-02-02 10:54:25
      _STATISTICS_TAGS: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES
      _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES
    Stream #0:1(eng), 8, 1/1000: Audio: aac (LC), 48000 Hz, mono, fltp (default)
      BPS             : 85101
      BPS-eng         : 85101
      DURATION-eng    : 01:28:09.280000000
      NUMBER_OF_FRAMES: 247935
      NUMBER_OF_FRAMES-eng: 247935
      NUMBER_OF_BYTES-eng: 56265956
Successfully opened the file.
[AVIOContext @ 0225E7E0] Statistics: 66422 bytes read, 0 seeks
jonwestcot
Post Sun Apr 12, 2015 3:57 am
Hello:
::hangs head in shame::
Never mind.
In reading through the debug.log file, I found the reason behind my problems trying to transcode .MKV files.
It really helps if you point the transcoder to an existing drive.
Chalk up another "loose screw behind the keyboard" error.
Thanks for your help!
Jon
