Re: Library refresh on 1.5
Also on windows it does not work
TeslaZap wrote:I think the problem has been identified, but I would like to add my experience nonetheless.
I'm running a clean install of Serviio 1.5.1 on ubuntu server 14.04 running java 8 and I can confirm that library refresh doesn't work.
I even enabled debug mode, but when I add a file nothing happens after 30 minutes or more.
If I login into the web console "Keep library automatically updated" is flagged and when I click Save it updates the library once. Then again no more changes detected until I click Save again.
Both with or without "Search for updates of currently shared files" enabled.
my java is:
openjdk version "1.8.0_01-internal"
OpenJDK Runtime Environment (build 1.8.0_01-internal-b04)
OpenJDK Server VM (build 25.40-b08, mixed mode)
logs after adding a file:
2015-03-05 13:38:44,679 DEBUG [FeedUpdaterWorker] Checking for new and expired online resources
2015-03-05 13:38:44,679 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2015-03-05 13:38:44,681 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 2)
2015-03-05 13:38:45,917 DEBUG [SearchManager] Committing search index
2015-03-05 13:39:15,917 DEBUG [SearchManager] Committing search index
2015-03-05 13:39:44,683 DEBUG [FeedUpdaterWorker] Checking for new and expired online resources
2015-03-05 13:39:44,683 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2015-03-05 13:39:44,684 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 2)
2015-03-05 13:39:45,918 DEBUG [SearchManager] Committing search index
[CUT]
and so on and on
bidelllo wrote:I have a different problem with 1.5.1:
Everything is working fine, i mean: when I disconnect an external drive, the library doesn't clean up and this is very desirable. But the problem occurs when I copy some files inside a folder that serviio is watching. For example after i copy a movie, sometimes happens that when I am watching it, it stops at a certain time, let's say 32:14. When i try watch the movie again, there is no way to go further than 32:14. I think this is related to serviio not updating correctly the file. I have "search for updates of the currently shared file" turned on, by the way.
That's why I sticked to 1.4.1. It sucks when you have to rescan all the library, but when it scans it does it in the right way.
Thanks for developing serviio
bidelllo wrote:Yes, i will provide you with the detailed log, give me few days to reinstall 1.5.1 and repeat the test (quite busy). I strongly agree with you about ffmpeg, because the file was good opened with samba. By the way i have a raspberry pi 2 with raspbian. I compiled ffmpeg as in the guide for raspberry (it took hours). If it is that ffmpeg is analyzing the file too quickly, how can avoid it? Why with force refresh it doesn't work? Does serviio store the hash of the scanned files?
zip wrote:working on it. On Mac the update will be every 5 minutes now, as it was otherwise using too much CPU for large libraries.
Users browsing this forum: No registered users and 54 guests
