No Plugins Installed
JarugzJa
Post Sat Apr 04, 2015 4:15 pm
i installed Serviio v.1.5.1 on my FreeBSD box and everything seems to be running ok.
I copied the .groovy files t "/use/local/share/Java/classes/serviio/plugins/". I can watch all the media on the box and I can stream direct links. The problem I'm having is when I add a link that requires the use of a plugin....No media shows up in the folders.
When I click on the "Plugins" tab in ServiioDroid, it says "No Plugins Installed"
The server starts and shuts down without any other issues.
Could anyone PLEASE help me figure out what is causing this..
Thanks in advance
RJ
Post Sun Apr 05, 2015 8:39 pm
Re: No Plugins Installed
Is this where you installed Serviio? /use/local/share/Java/classes/
Also, check the log, it'll list the found plugins on the server start.
JarugzJa
Post Mon Apr 06, 2015 4:27 am
Thanks for your reply
I installed using the command "portmaster net/serviio" and that's where it was installed to.
The logs says no plugins found. I did download and copied at least five .groovy to the plugins folder.
Post Tue Apr 07, 2015 4:24 pm
can you post your log, or at least the bit where the server starts?
Users browsing this forum: Google [Bot] and 145 guests
