M4V and x265
Honestly looking for a profile for x265 as well, not sure if there is one... is there or is that not available in the program yet
ideas anyone
any input or information on where to look would be helpful
cheers all
DenyAll wrote:Serviio supports transcoding of mpv and h265 files out of the box if you are a windows or Mac user, and should also do so for Linux users as long as you have compiled/sourced your ffmpeg correctly.
Have a read of http://www.serviio.org/index.php?option ... icle&id=24. This should explain how to transcode h265 files (matches vcodec command). mpv files are a variant of MP4 audio files and can be transcoded by matching as if it were an MP4 file.
