Library messed up last update
Dukester
Post Mon Apr 06, 2015 10:29 pm
Having a problem with my library.
Serviio will not show some folders in the folders tab. But does show the folder with 4 of the 9 files in it in the series folder.Also shows the new files I have recently added. I also just installed the new version. Seems to have started with the last version upgrade to 1.5.0. I am now running 1.5.1 I have done restarts and manual library update.
Post Tue Apr 07, 2015 9:51 am
Re: Library messed up last update
Wierd. Try moving the folder out and back into the share...
Otherwise it sounds like your library database may have become corrupt somehow. Some ways to try and fix:
  • remove all shares from your library, and then re-instate them;
  • remove your library (by stopping Serviio, deleting the contents of the Serviio\library and then re-instating your shared folders and all other settings);
  • a fresh install of Serviio (stop Serviio, rename your Serviio folder and then re-install Serviio. After satisfied delete the renamed folder)
Users browsing this forum: Baidu [Spider], Google [Bot] and 35 guests
