Updated to 1.5.2 - Now Cannot connect to Serviio server
ZappaFan16
Post Fri Apr 10, 2015 12:01 am
I am running Serviio on an iMac
OS X 10.10.2
Serviio was working fine. Then I updated to the latest version 1.5.2.
Now every time I try to launch Serviio-console.app I get an error,
"Cannot connect to Serviio server, it does not seem to be running. Exiting...
Any ideas on how I can fix this?
Post Fri Apr 10, 2015 4:31 pm
Re: Updated to 1.5.2 - Now Cannot connect to Serviio server
What version did you have before?
ZappaFan16
Post Fri Apr 10, 2015 4:38 pm
Version 1.5.1
ZappaFan16
Post Fri Apr 10, 2015 8:32 pm
Not sure if this will help, but here is my Serviio.log file.
2015-04-09 19:43:44,441 INFO [MediaServer] ------------------------------------------------------------------------
2015-04-09 19:43:44,442 INFO [MediaServer] Serviio DLNA media streaming server v 1.5.2 (rev. 4b9ce176daa1)
2015-04-09 19:43:44,442 INFO [MediaServer] Petr Nejedly 2009-2015
2015-04-09 19:43:44,442 INFO [MediaServer] http://www.serviio.org
2015-04-09 19:43:44,442 INFO [MediaServer] Java 1.8.0_40-Oracle Corporation x86_64
2015-04-09 19:43:44,442 INFO [MediaServer] OS Mac OS X 10.10.2
2015-04-09 19:43:44,442 INFO [MediaServer] File encoding: UTF-8
2015-04-09 19:43:44,443 INFO [MediaServer] Headless mode enabled: true
2015-04-09 19:43:44,443 INFO [MediaServer] User: root
2015-04-09 19:43:44,443 INFO [MediaServer] User home dir: /var/root
2015-04-09 19:43:44,443 INFO [MediaServer] Temp dir: /var/folders/zz/zyxvpxvq6csfxvn_n0000000000000/T/
2015-04-09 19:43:44,443 INFO [MediaServer] ------------------------------------------------------------------------
2015-04-09 19:43:44,616 INFO [WebServer] Socket buffer set to 65535 bytes
2015-04-09 19:43:44,617 INFO [RestletServer] Starting Restlet server (/rest) exposed on port 23423
2015-04-09 19:43:44,766 INFO [RestletServer] Starting Restlet server (/cds) exposed on port 23424
2015-04-09 19:43:44,766 INFO [RestletServer] Starting Restlet server (/mediabrowser) exposed on port 23424
2015-04-09 19:43:44,778 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2015-04-09 19:43:44,861 INFO [DatabaseManager] Using DERBY database language
2015-04-09 19:43:46,959 WARN [DBConnectionPool] Can't create a new connection for jdbc:derby:db;create=true
java.sql.SQLException: Failed to start database 'db' with class loader sun.misc.Launcher$AppClassLoader@24d46ca6, see the next exception for details.
at org.apache.derby.impl.jdbc.EmbedConnection.bootDatabase(Unknown Source)
at org.apache.derby.impl.jdbc.EmbedConnection.<init>(Unknown Source)
at org.apache.derby.jdbc.InternalDriver.getNewEmbedConnection(Unknown Source)
at org.apache.derby.jdbc.InternalDriver.connect(Unknown Source)
at org.apache.derby.jdbc.AutoloadedDriver.connect(Unknown Source)
at java.sql.DriverManager.getConnection(DriverManager.java:664)
at java.sql.DriverManager.getConnection(DriverManager.java:270)
at org.serviio.db.DBConnectionPool.newConnection(DBConnetionPool.java:186)
at org.serviio.db.DBConnectionPool.getConnection(DBConnetionPool.java:123)
at org.serviio.db.DBConnectionPool.getConnection(DBConnetionPool.java:149)
at org.serviio.db.DatabaseManager.getConnection(DatabaseManager.java:71)
at org.serviio.db.DatabaseManager.getConnection(DatabaseManager.java:64)
at org.serviio.update.dao.DBLogDAOImpl.isScriptPresent(DBLogDAOImpl.java:49)
at org.serviio.update.DBSchemaUpdateExecutor.updateDBSchema(DBSchemaUpdateExecutor.java:77)
at org.serviio.MediaServer.main(MediaServer.java:121)
Caused by: ERROR XJ040: Failed to start database 'db' with class loader sun.misc.Launcher$AppClassLoader@24d46ca6, see the next exception for details.
at org.apache.derby.impl.jdbc.SQLExceptionFactory.wrapArgsForTransportAcrossDRDA(Unknown Source)
... 19 more
Caused by: ERROR XSTB0: An exception was thrown during transaction abort.
at org.apache.derby.impl.store.raw.xact.Xact.abort(Unknown Source)
at org.apache.derby.impl.store.raw.xact.XactFactory.rollbackAllTransactions(Unknown Source)
at org.apache.derby.impl.store.raw.log.LogToFile.recover(Unknown Source)
at org.apache.derby.impl.store.raw.RawStore.boot(Unknown Source)
at org.apache.derby.impl.services.monitor.BaseMonitor.boot(Unknown Source)
at org.apache.derby.impl.services.monitor.TopService.bootModule(Unknown Source)
at org.apache.derby.impl.services.monitor.BaseMonitor.startModule(Unknown Source)
at org.apache.derby.impl.services.monitor.FileMonitor.startModule(Unknown Source)
at org.apache.derby.iapi.services.monitor.Monitor.bootServiceModule(Unknown Source)
at org.apache.derby.impl.store.access.RAMAccessManager.boot(Unknown Source)
at org.apache.derby.impl.db.BasicDatabase.bootStore(Unknown Source)
at org.apache.derby.impl.db.BasicDatabase.boot(Unknown Source)
at org.apache.derby.impl.services.monitor.BaseMonitor.bootService(Unknown Source)
at org.apache.derby.impl.services.monitor.BaseMonitor.startProviderService(Unknown Source)
at org.apache.derby.impl.services.monitor.BaseMonitor.findProviderAndStartService(Unknown Source)
at org.apache.derby.impl.services.monitor.BaseMonitor.startPersistentService(Unknown Source)
at org.apache.derby.iapi.services.monitor.Monitor.startPersistentService(Unknown Source)
... 16 more
Caused by: ERROR XSLA8: Cannot rollback transaction 15344251, trying to compensate null operation with null
at org.apache.derby.impl.store.raw.log.FileLogger.undo(Unknown Source)
... 40 more
Caused by: ERROR XSDG0: Page Page(22532,Container(0, 2832)) could not be read from disk.
at org.apache.derby.impl.store.raw.data.CachedPage.readPage(Unknown Source)
at org.apache.derby.impl.store.raw.data.CachedPage.setIdentity(Unknown Source)
at org.apache.derby.impl.services.cache.ConcurrentCache.find(Unknown Source)
at org.apache.derby.impl.store.raw.data.FileContainer.getAnyPage(Unknown Source)
at org.apache.derby.impl.store.raw.data.BaseContainer.getAnyPage(Unknown Source)
at org.apache.derby.impl.store.raw.data.BaseContainerHandle.getAnyPage(Unknown Source)
at org.apache.derby.impl.store.raw.data.PageBasicOperation.findpage(Unknown Source)
at org.apache.derby.impl.store.raw.data.LogicalPageOperation.generateUndo(Unknown Source)
at org.apache.derby.impl.store.raw.data.InsertOperation.generateUndo(Unknown Source)
... 41 more
Caused by: java.io.EOFException: Reached end of file while attempting to read a whole page.
at org.apache.derby.impl.store.raw.data.RAFContainer4.readFull(Unknown Source)
at org.apache.derby.impl.store.raw.data.RAFContainer4.readPage0(Unknown Source)
at org.apache.derby.impl.store.raw.data.RAFContainer4.readPage(Unknown Source)
... 50 more
2015-04-09 19:43:48,970 ERROR [MediaServer] An unexpected error occured. Ending the application. Message: null
at org.serviio.update.dao.DBLogDAOImpl.isScriptPresent(DBLogDAOImpl.java:50)
2015-04-09 19:48:09,146 INFO [MediaServer] ------------------------------------------------------------------------
2015-04-09 19:48:09,210 INFO [MediaServer] Serviio DLNA media streaming server v 1.5.2 (rev. 4b9ce176daa1)
2015-04-09 19:48:09,210 INFO [MediaServer] Petr Nejedly 2009-2015
2015-04-09 19:48:09,210 INFO [MediaServer] http://www.serviio.org
2015-04-09 19:48:09,210 INFO [MediaServer] Java 1.8.0_40-Oracle Corporation x86_64
2015-04-09 19:48:09,210 INFO [MediaServer] OS Mac OS X 10.10.2
2015-04-09 19:48:09,211 INFO [MediaServer] File encoding: UTF-8
2015-04-09 19:48:09,211 INFO [MediaServer] Headless mode enabled: true
2015-04-09 19:48:09,211 INFO [MediaServer] User: root
2015-04-09 19:48:09,211 INFO [MediaServer] User home dir: /var/root
2015-04-09 19:48:09,211 INFO [MediaServer] Temp dir: /var/folders/zz/zyxvpxvq6csfxvn_n0000000000000/T/
2015-04-09 19:48:09,211 INFO [MediaServer] ------------------------------------------------------------------------
2015-04-09 19:48:09,332 INFO [WebServer] Socket buffer set to 65535 bytes
2015-04-09 19:48:09,336 INFO [RestletServer] Starting Restlet server (/rest) exposed on port 23423
2015-04-09 19:48:09,421 INFO [RestletServer] Starting Restlet server (/cds) exposed on port 23424
2015-04-09 19:48:09,422 INFO [RestletServer] Starting Restlet server (/mediabrowser) exposed on port 23424
2015-04-09 19:48:09,448 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2015-04-09 19:48:09,459 INFO [DatabaseManager] Using DERBY database language
2015-04-09 19:48:10,980 WARN [DBConnectionPool] Can't create a new connection for jdbc:derby:db;create=true
... 19 more
... 16 more
... 40 more
... 41 more
... 50 more
2015-04-09 19:48:13,001 ERROR [MediaServer] An unexpected error occured. Ending the application. Message: null
2015-04-09 20:36:06,724 INFO [MediaServer] ------------------------------------------------------------------------
2015-04-09 20:36:06,769 INFO [MediaServer] Serviio DLNA media streaming server v 1.5.2 (rev. 4b9ce176daa1)
2015-04-09 20:36:06,769 INFO [MediaServer] Petr Nejedly 2009-2015
2015-04-09 20:36:06,769 INFO [MediaServer] http://www.serviio.org
2015-04-09 20:36:06,769 INFO [MediaServer] Java 1.8.0_40-Oracle Corporation x86_64
2015-04-09 20:36:06,769 INFO [MediaServer] OS Mac OS X 10.10.2
2015-04-09 20:36:06,769 INFO [MediaServer] File encoding: UTF-8
2015-04-09 20:36:06,770 INFO [MediaServer] Headless mode enabled: true
2015-04-09 20:36:06,770 INFO [MediaServer] User: root
2015-04-09 20:36:06,770 INFO [MediaServer] User home dir: /var/root
2015-04-09 20:36:06,770 INFO [MediaServer] Temp dir: /var/folders/zz/zyxvpxvq6csfxvn_n0000000000000/T/
2015-04-09 20:36:06,770 INFO [MediaServer] ------------------------------------------------------------------------
2015-04-09 20:36:07,272 INFO [WebServer] Socket buffer set to 65535 bytes
2015-04-09 20:36:07,272 INFO [RestletServer] Starting Restlet server (/rest) exposed on port 23423
2015-04-09 20:36:07,729 INFO [RestletServer] Starting Restlet server (/cds) exposed on port 23424
2015-04-09 20:36:07,730 INFO [RestletServer] Starting Restlet server (/mediabrowser) exposed on port 23424
2015-04-09 20:36:07,763 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2015-04-09 20:36:07,772 INFO [DatabaseManager] Using DERBY database language
2015-04-09 20:36:08,451 WARN [DBConnectionPool] Can't create a new connection for jdbc:derby:db;create=true
... 19 more
... 16 more
... 40 more
... 41 more
... 50 more
2015-04-09 20:36:10,459 ERROR [MediaServer] An unexpected error occured. Ending the application. Message: null
2015-04-10 08:31:48,420 INFO [MediaServer] ------------------------------------------------------------------------
2015-04-10 08:31:48,427 INFO [MediaServer] Serviio DLNA media streaming server v 1.5.2 (rev. 4b9ce176daa1)
2015-04-10 08:31:48,427 INFO [MediaServer] Petr Nejedly 2009-2015
2015-04-10 08:31:48,427 INFO [MediaServer] http://www.serviio.org
2015-04-10 08:31:48,427 INFO [MediaServer] Java 1.8.0_40-Oracle Corporation x86_64
2015-04-10 08:31:48,427 INFO [MediaServer] OS Mac OS X 10.10.3
2015-04-10 08:31:48,427 INFO [MediaServer] File encoding: UTF-8
2015-04-10 08:31:48,427 INFO [MediaServer] Headless mode enabled: true
2015-04-10 08:31:48,427 INFO [MediaServer] User: root
2015-04-10 08:31:48,428 INFO [MediaServer] User home dir: /var/root
2015-04-10 08:31:48,428 INFO [MediaServer] Temp dir: /var/folders/zz/zyxvpxvq6csfxvn_n0000000000000/T/
2015-04-10 08:31:48,428 INFO [MediaServer] ------------------------------------------------------------------------
2015-04-10 08:31:48,524 INFO [WebServer] Socket buffer set to 65535 bytes
2015-04-10 08:31:48,524 INFO [RestletServer] Starting Restlet server (/rest) exposed on port 23423
2015-04-10 08:31:48,578 INFO [RestletServer] Starting Restlet server (/cds) exposed on port 23424
2015-04-10 08:31:48,578 INFO [RestletServer] Starting Restlet server (/mediabrowser) exposed on port 23424
2015-04-10 08:31:48,589 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2015-04-10 08:31:48,594 INFO [DatabaseManager] Using DERBY database language
2015-04-10 08:31:48,868 WARN [DBConnectionPool] Can't create a new connection for jdbc:derby:db;create=true
... 19 more
... 16 more
... 40 more
... 41 more
... 50 more
2015-04-10 08:31:51,178 ERROR [MediaServer] An unexpected error occured. Ending the application. Message: null
2015-04-10 12:36:27,498 INFO [MediaServer] ------------------------------------------------------------------------
2015-04-10 12:36:27,556 INFO [MediaServer] Serviio DLNA media streaming server v 1.5.2 (rev. 4b9ce176daa1)
2015-04-10 12:36:27,556 INFO [MediaServer] Petr Nejedly 2009-2015
2015-04-10 12:36:27,556 INFO [MediaServer] http://www.serviio.org
2015-04-10 12:36:27,556 INFO [MediaServer] Java 1.8.0_40-Oracle Corporation x86_64
2015-04-10 12:36:27,556 INFO [MediaServer] OS Mac OS X 10.10.3
2015-04-10 12:36:27,557 INFO [MediaServer] File encoding: UTF-8
2015-04-10 12:36:27,573 INFO [MediaServer] Headless mode enabled: true
2015-04-10 12:36:27,573 INFO [MediaServer] User: root
2015-04-10 12:36:27,573 INFO [MediaServer] User home dir: /var/root
2015-04-10 12:36:27,573 INFO [MediaServer] Temp dir: /var/folders/zz/zyxvpxvq6csfxvn_n0000000000000/T/
2015-04-10 12:36:27,573 INFO [MediaServer] ------------------------------------------------------------------------
2015-04-10 12:36:30,862 INFO [WebServer] Socket buffer set to 65535 bytes
2015-04-10 12:36:30,863 INFO [RestletServer] Starting Restlet server (/rest) exposed on port 23423
2015-04-10 12:36:30,963 INFO [RestletServer] Starting Restlet server (/cds) exposed on port 23424
2015-04-10 12:36:30,963 INFO [RestletServer] Starting Restlet server (/mediabrowser) exposed on port 23424
2015-04-10 12:36:30,973 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2015-04-10 12:36:30,978 INFO [DatabaseManager] Using DERBY database language
2015-04-10 12:36:32,652 WARN [DBConnectionPool] Can't create a new connection for jdbc:derby:db;create=true
... 19 more
... 16 more
... 40 more
... 41 more
... 50 more
2015-04-10 12:36:34,681 ERROR [MediaServer] An unexpected error occured. Ending the application. Message: null
Post Sat Apr 11, 2015 1:35 pm
Looks like the database is corrupted. Do a clean install.
ZappaFan16
Post Sat Apr 11, 2015 9:24 pm
I uninstalled the app.
Rebooted.
Downloaded and installed the app again.
Still have the same problem.
Any other suggestions? Thanks.
ZappaFan16
Post Sun Apr 12, 2015 1:28 am
And here is the log file again.
... 19 more
... 16 more
... 40 more
... 41 more
... 50 more
... 19 more
... 16 more
... 40 more
... 41 more
... 50 more
... 19 more
... 16 more
... 40 more
... 41 more
... 50 more
... 19 more
... 16 more
... 40 more
... 41 more
... 50 more
... 19 more
... 16 more
... 40 more
... 41 more
... 50 more
2015-04-11 17:19:04,922 INFO [MediaServer] ------------------------------------------------------------------------
2015-04-11 17:19:05,032 INFO [MediaServer] Serviio DLNA media streaming server v 1.5.2 (rev. 4b9ce176daa1)
2015-04-11 17:19:05,032 INFO [MediaServer] Petr Nejedly 2009-2015
2015-04-11 17:19:05,032 INFO [MediaServer] http://www.serviio.org
2015-04-11 17:19:05,032 INFO [MediaServer] Java 1.8.0_40-Oracle Corporation x86_64
2015-04-11 17:19:05,032 INFO [MediaServer] OS Mac OS X 10.10.3
2015-04-11 17:19:05,032 INFO [MediaServer] File encoding: UTF-8
2015-04-11 17:19:05,032 INFO [MediaServer] Headless mode enabled: true
2015-04-11 17:19:05,032 INFO [MediaServer] User: root
2015-04-11 17:19:05,032 INFO [MediaServer] User home dir: /var/root
2015-04-11 17:19:05,032 INFO [MediaServer] Temp dir: /var/folders/zz/zyxvpxvq6csfxvn_n0000000000000/T/
2015-04-11 17:19:05,032 INFO [MediaServer] ------------------------------------------------------------------------
2015-04-11 17:19:05,165 INFO [WebServer] Socket buffer set to 65535 bytes
2015-04-11 17:19:05,165 INFO [RestletServer] Starting Restlet server (/rest) exposed on port 23423
2015-04-11 17:19:05,249 INFO [RestletServer] Starting Restlet server (/cds) exposed on port 23424
2015-04-11 17:19:05,250 INFO [RestletServer] Starting Restlet server (/mediabrowser) exposed on port 23424
2015-04-11 17:19:05,262 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2015-04-11 17:19:05,269 INFO [DatabaseManager] Using DERBY database language
2015-04-11 17:19:05,829 WARN [DBConnectionPool] Can't create a new connection for jdbc:derby:db;create=true
... 19 more
... 16 more
... 40 more
... 41 more
... 50 more
2015-04-11 17:19:07,837 ERROR [MediaServer] An unexpected error occured. Ending the application. Message: null
2015-04-11 17:20:44,810 INFO [MediaServer] ------------------------------------------------------------------------
2015-04-11 17:20:44,810 INFO [MediaServer] Serviio DLNA media streaming server v 1.5.2 (rev. 4b9ce176daa1)
2015-04-11 17:20:44,810 INFO [MediaServer] Petr Nejedly 2009-2015
2015-04-11 17:20:44,810 INFO [MediaServer] http://www.serviio.org
2015-04-11 17:20:44,810 INFO [MediaServer] Java 1.8.0_40-Oracle Corporation x86_64
2015-04-11 17:20:44,810 INFO [MediaServer] OS Mac OS X 10.10.3
2015-04-11 17:20:44,810 INFO [MediaServer] File encoding: UTF-8
2015-04-11 17:20:44,811 INFO [MediaServer] Headless mode enabled: true
2015-04-11 17:20:44,811 INFO [MediaServer] User: root
2015-04-11 17:20:44,811 INFO [MediaServer] User home dir: /var/root
2015-04-11 17:20:44,811 INFO [MediaServer] Temp dir: /var/folders/zz/zyxvpxvq6csfxvn_n0000000000000/T/
2015-04-11 17:20:44,811 INFO [MediaServer] ------------------------------------------------------------------------
2015-04-11 17:20:44,975 INFO [WebServer] Socket buffer set to 65535 bytes
2015-04-11 17:20:44,976 INFO [RestletServer] Starting Restlet server (/rest) exposed on port 23423
2015-04-11 17:20:45,035 INFO [RestletServer] Starting Restlet server (/cds) exposed on port 23424
2015-04-11 17:20:45,035 INFO [RestletServer] Starting Restlet server (/mediabrowser) exposed on port 23424
2015-04-11 17:20:45,047 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2015-04-11 17:20:45,057 INFO [DatabaseManager] Using DERBY database language
2015-04-11 17:20:45,352 WARN [DBConnectionPool] Can't create a new connection for jdbc:derby:db;create=true
... 19 more
... 16 more
... 40 more
... 41 more
... 50 more
2015-04-11 17:20:47,355 ERROR [MediaServer] An unexpected error occured. Ending the application. Message: null
2015-04-11 17:21:46,970 INFO [MediaServer] ------------------------------------------------------------------------
2015-04-11 17:21:46,971 INFO [MediaServer] Serviio DLNA media streaming server v 1.5.2 (rev. 4b9ce176daa1)
2015-04-11 17:21:46,971 INFO [MediaServer] Petr Nejedly 2009-2015
2015-04-11 17:21:46,971 INFO [MediaServer] http://www.serviio.org
2015-04-11 17:21:46,971 INFO [MediaServer] Java 1.8.0_40-Oracle Corporation x86_64
2015-04-11 17:21:46,971 INFO [MediaServer] OS Mac OS X 10.10.3
2015-04-11 17:21:46,971 INFO [MediaServer] File encoding: UTF-8
2015-04-11 17:21:46,972 INFO [MediaServer] Headless mode enabled: true
2015-04-11 17:21:46,972 INFO [MediaServer] User: root
2015-04-11 17:21:46,972 INFO [MediaServer] User home dir: /var/root
2015-04-11 17:21:46,972 INFO [MediaServer] Temp dir: /var/folders/zz/zyxvpxvq6csfxvn_n0000000000000/T/
2015-04-11 17:21:46,972 INFO [MediaServer] ------------------------------------------------------------------------
2015-04-11 17:21:47,129 INFO [WebServer] Socket buffer set to 65535 bytes
2015-04-11 17:21:47,130 INFO [RestletServer] Starting Restlet server (/rest) exposed on port 23423
2015-04-11 17:21:47,220 INFO [RestletServer] Starting Restlet server (/cds) exposed on port 23424
2015-04-11 17:21:47,220 INFO [RestletServer] Starting Restlet server (/mediabrowser) exposed on port 23424
2015-04-11 17:21:47,233 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2015-04-11 17:21:47,247 INFO [DatabaseManager] Using DERBY database language
2015-04-11 17:21:47,661 WARN [DBConnectionPool] Can't create a new connection for jdbc:derby:db;create=true
... 19 more
... 16 more
... 40 more
Post Mon Apr 13, 2015 8:59 pm
Did you uninstall the server,and not just the console?
http://serviio.org/component/content/article?id=21#q4
ZappaFan16
Post Tue Apr 14, 2015 8:16 pm
That fixed it. Thanks.
Users browsing this forum: Google [Bot] and 24 guests
