PACKAGE: Serviio 1.5 for QNAP NAS (ARM & x86 Intel)
Xmantium
Post Fri Feb 06, 2015 8:35 am
Re: PACKAGE: Serviio 1.5 for QNAP NAS (ARM & x86 Intel)
There's no subtitles ability for ARM. The libass library is not included to make subtitles work.
Transcoding is a pain for ARM chips, it's perfectly fine for remuxing (video file doesn't change, audio gets transcode). ARM uses fixed point audio encoder to make audio transcoding quicker.
But you have the latest multi core ARM chips that's similar to smartphone.
Maybe if you get ffmpeg compiled from an Android Linux multi core build, you may get better performance and could transcode video real-time.
in2slack
Post Sat Feb 21, 2015 6:50 pm
Thanks for the QPKG. I installed on my TS-453pro. When i browse the library, the categories that depend on downloaded metadata do not show anything or are tagged unknown. I can only see my video file when i browse by folder or recently added/watched.
Xmantium
Post Sat Feb 21, 2015 7:13 pm
Go to library tab on the console.
Tick the "M" for metadata, then press save
new2serviio79
Post Wed Mar 18, 2015 11:32 pm
Thanks for the metadata tip...I was having the same issue!
BTW I am still loving your test build for the dual-core ARM! An optimized version of ffmpeg in a future release would be awesome, but I have no experience with gcc so I wouldn't be able to offer any compiler advice.
Xmantium
Post Wed Mar 18, 2015 11:39 pm
new2serviio79 wrote:BTW I am still loving your test build for the dual-core ARM! An optimized version of ffmpeg in a future release would be awesome, but I have no experience with gcc so I wouldn't be able to offer any compiler advice.
I'm glad it works, these are smartphone chips, maybe you can find a compiled build for Android, but it must be compiled with librtmp.
gambarini
Post Wed Apr 08, 2015 6:33 pm
serviio 1.5 on qnap 253pro
the package works well on my nas but i have a problem:
when i add a nef file to library i receive this message:
2015-04-08 02:47:14,551 WARN [MediaFileIndexer] Cannot add file DSC_0008.NEF because of invalid metadata. Message: Unknown image file type.
the same file on serviio 1.5.1 installed on windows xp works properly and it is added to library without error.
Xmantium
Post Wed Apr 08, 2015 6:39 pm
Thanks, good to know package is working well.
I've never heard of nef files, could be a Linux issue.
gambarini
Post Thu Apr 09, 2015 7:52 pm
with the twonky integrated dlna server the same file works fine...
gambarini
Post Fri Apr 10, 2015 5:11 pm
is there the possibility to disable the query search of metadata for nef files?
Xmantium
Post Fri Apr 10, 2015 7:20 pm
Best to post this on the main support page
hybrid
Post Fri Apr 10, 2015 7:24 pm
True that, :) , Everyone I get an email from Serviio Forum , I'm hoping to get a new update and this does not fall under the QNAP version update section. :)
TVS-871 using Serviio/Mediabrowser (1.5Rev1) on IPad, Iphone, Android Phone , Samsung TV's , OTT MXQ M10 TV Box, PS4 and Xbox.
Post Mon Apr 13, 2015 9:20 pm
Xmantium wrote:I've never heard of nef files, could be a Linux issue.
It's because this package doesn't come with dcraw build .. thus the RAW images won't work.
DEJ710
Post Sun Jun 28, 2015 9:46 am
Hi guys,
I recently bought a NAS and have noticed that Serviio seems to go offline a lot.
Is this the best version: v1.5 Rev 1 for Intel on a QNAP TS-451 device?
How far away will v1.6 be for the NAS on Intel?
Jason
LG 86UM7600PTA 4K TV Sony KD-75X8500D 4K TV Panasonic DP-UB820 4K BluRay NVIDIA Shield TV Pro Onkyo TX-RZ3100 Windows 11 x64 Draytek Vigor2860 Router ASUS Lyra Dual Band Wireless MESH QNAP TS-464 x64 4 Bay NAS 98 TB QNAP TR-004 4 Bay Expansion
fantasteyou
Post Mon Jul 06, 2015 6:57 pm
Hello - i have QNAP TS-231 with ARMv7. Is it possible to install Serviio? - If i try to install the version for ARM, i got error about wrong architecture.
[Edit] found correct build for x31-ARMs. Seems to work perfect. Thanks
Regards
jairoxyz
Post Sat Jul 11, 2015 10:36 am
@xmantium - 1.5 x86 package works perfect on TS-251 but I have a problem with version >= 1.5 from my LG TV (https://bitbucket.org/xnejp03/serviio/issues/854/stream-multiplexer-should-restart-after) . Would it be possible to post a link to the latest 1.4.1 version?
Thanks,
JairoX
Xmantium
Post Sat Jul 11, 2015 10:40 am
Hopefully I should have time this week to update the package, I've been very busy.
The new version fixes few bugs such as scanning new files
jairoxyz
Post Sun Jul 12, 2015 6:00 am
That would be great, many thanks in advance. I will test the new version with my LGTV and see if the streams work. In the meantime, could you re-activate your link to version 1.4.1 (https://bitbucket.org/Xmantium/serviio-qpkg/downloads/Serviio_1.4.1.2-R1_x86.qpkg)? Or could anyone else post the 1.4.1.2-R1 x86 package?
Cheers,
Jx-
DEJ710
Post Fri Jul 17, 2015 6:39 am
Xmantium wrote:Hopefully I should have time this week to update the package, I've been very busy.
Hi Xmantium, any idea why the current version goes offline a lot?
WARNING: Serviio has not started correctly. Please go to App Centre on your NAS or use Qmanager on your phone. Stop Serviio, wait 30 seconds, then start Serviio.
devz3ro
Post Thu Jul 30, 2015 6:10 am
Unfortunately after upgrading to the latest QTS 4.2 the web interface stopped working.
alleck
Post Sat Aug 01, 2015 10:21 am
Hi
Here http://forum.serviio.org/viewtopic.php?f=14&t=19161 you have my workaround for not working web interface.
Regards.
