Error reading output of an external command
Jurijlv
Post Thu Apr 09, 2015 1:01 am
Hello, as I am rather new in using serviio please do not judge too strict if I miss or misunderstand something.
Do not know when but I`ve started to have few troubles with online streaming.
First picture is going a little bit faster then sound (on some channels) - honestly didn't do any research because I do not watch this channels however my wife is not very happy about this, so may be someone knows how to deal with this?
Second - the most annoying thing is that some channels play for 1-10 min, some days 15 and after that freeze and sometime it continues and some time I've got message that the file type is not supported, however when start/open it again it works. In log file receive several messages:
1. [ProcessExecutor] Process /volume1/@appstore/Serviio/bin/ffmpeg has a return code of 137! This is a possible error. Detailed output follows.
[flv @ 0x80f09e0] max bitrate possibly too small or try trellis with large lmax or increase qmax
frame= 42 fps= 41 q=16.3 size= 256kB time=00:00:01.63 bitrate=1285.7kbits/s
frame= 74 fps= 49 q=6.1 size= 378kB time=00:00:02.68 bitrate=1154.0kbits/s
frame= 106 fps= 52 q=15.4 size= 551kB time=00:00:03.64 bitrate=1239.4kbits/s
frame= 116 fps= 45 q=9.6 size= 580kB time=00:00:03.96 bitrate=1199.4kbits/s
2. WARN [OutputTextReader] Error reading output of an external command:Stream closed
Made a research in forum didn't find any good answer for me.
Log file is rather big and it is impossible to add as an attachment.
Some extractions from the LOGFILE:
2015-04-08 20:55:54,953 WARN [ProcessExecutor] Process /volume1/@appstore/Serviio/bin/ffmpeg has a return code of 1! This is a possible error. Detailed output follows.
libswresample 0. 17.104 / 0. 17.104
[http @ 0x8093fe0] HTTP error 522 Origin Connection Time-out
[hls,applehttp @ 0x8088f00] Error when loading first segment 'http://live.oneplay.tv/STREAM/01/430/03-40/337-20150408T194922.ts'
http://live.oneplay.tv/reproducir/309.m3u8: Input/output error
2015-04-08 20:55:54,953 DEBUG [TranscodingJobListener] Transcoding finished; successful: false
2015-04-08 20:58:02,326 DEBUG [TranscodingJobListener] Error updating FFmpeg output for line 'frame= 1320 fps= 22 q=-1.0 size= 8234kB time=-577014:-32:-22.-77 bitrate=N/A ': For input string: "0.-77"
2015-04-08 20:58:02,331 DEBUG [TranscodingJobListener] Transcoding finished; successful: true
2015-04-08 20:58:02,845 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.6:65292s
2015-04-08 20:58:03,257 DEBUG [WebServer] I/O error: Write end dead
2015-04-08 20:58:05,881 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.6:65292s
2015-04-08 20:58:08,882 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.6:65292s
2015-04-08 20:58:11,891 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.6:65292s
2015-04-08 20:58:17,811 DEBUG [SearchManager] Committing search index
Have a hope that someone can help me with this.
If necessary will make LOGFILE, but don't know hot to make it smaller or how to use filter. :( :roll:
Jurijlv
Post Thu Apr 09, 2015 1:10 am
Re: Error reading output of an external command
Some more information fro logfile:
2015-04-08 21:05:54,835 WARN [ProcessExecutor] Process /volume1/@appstore/Serviio/bin/ffmpeg has a return code of 137! This is a possible error. Detailed output follows.
frame= 1292 fps= 39 q=-1.0 size= 8205kB time=00:00:43.30 bitrate=1552.2kbits/s
frame= 1321 fps= 39 q=-1.0 size= 8425kB time=00:00:44.06 bitrate=1566.1kbits/s
frame= 1354 fps= 40 q=-1.0 size= 8625kB time=00:00:45.22 bitrate=1562.4kbits/s
frame= 1381 fps= 40 q=-1.0 size= 8797kB time=00:00:46.14 bitrate=1561.5kbits/s
frame= 1426 fps= 40 q=-1.0 size= 9013kB time=00:00:47.65 bitrate=1549.4kbits/s
2015-04-08 21:07:40,726 WARN [OutputBytesReader] Error reading bytes stream from external process: Stream closed
Post Thu Apr 09, 2015 8:46 am
Looks like ffmpeg crashes for some reason. Won't be able to help, unless you get a newer ffmpeg version which might have it fixed.
Jurijlv
Post Sat Apr 11, 2015 3:19 am
Will appreciate if someone will help me to update FFMPEG player on SYNOLOGY 713+ DSM5.1
