Serviio 1.4.1.1 install issues
amerkfan
Post Fri Mar 21, 2014 5:26 pm
I am running ubuntu server 12.04, and serviio 1.4.1.1 headless.
After removing an earlier version and installing v1.4.1.1 I cannot connect via web interface and serviidroid gives me this error when I try to add a folder to the library " The server did not understand the request which is probably because something has been removed from the REST api. Please contact me to fix this." When I try to access via the web I get an error: "The server has been stopped" even though 'service serviio status' yields serviio start/running, process 18870
My serviio.log is attached
Thanks in advance
(3.33 KiB) Downloaded 705 times
Post Fri Mar 21, 2014 6:13 pm
Re: Serviio 1.4.1.1 install issues
something wrong with the database. Try to install again and make sure you have write access to the serviio folders
Return to General discussion
