Sharp Aquos DLNA Profiles
Post Mon Apr 22, 2013 12:18 pm
Re: Sharp Aquos DLNA Profiles
zip wrote:No way to distinguish, unless they have different H264 profiles/levels.
1920x800 and 640x464 are also differents, there were an opened ticket about non-standard h264 resolution that could be detected then transcoded...
Pyros
Post Fri Apr 11, 2014 8:50 pm
this profile works fine if there's no subtitles...
for each tvshow with external subtitle, i got a file error on ma sharp 39LE952.
How could i fix it ?
Post Fri Apr 11, 2014 11:24 pm
post detailed log of playing the file
Pyros
Post Sat Apr 12, 2014 6:34 am
Hi just copied a tvshow episode to test_zip.mkv to show difference between with and without external subtitle (utf-8 srt file with the same name as the mkv file)
Here's the ffmpeg -i
ffmpeg version 1.1.git Copyright (c) 2000-2013 the FFmpeg developers
built on Oct 7 2013 22:31:52 with gcc 4.7 (Ubuntu/Linaro 4.7.3-1ubuntu1)
configuration: --enable-gpl --enable-libfaac --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libtheora --enable-libvorbis --enable-libx264 --enable-nonfree --enable-postproc --enable-version3 --enable-x11grab --enable-librtmp --enable-libxvid --enable-libass
Input #0, matroska,webm, from '/media//video/series/From Dusk Till Dawn The Series/Saison 01/test_zip2.mkv':
creation_time : 2014-03-19 07:08:56
Duration: 00:46:17.22, start: 0.000000, bitrate: 4618 kb/s
Stream #0:0(eng): Video: h264 (High), yuv420p, 1280x720 [SAR 1:1 DAR 16:9], 23.98 fps, 23.98 tbr, 1k tbn, 2k tbc (default)
Stream #0:1(eng): Audio: ac3, 48000 Hz, 5.1(side), fltp, 384 kb/s (default)
Stream #0:2(eng): Subtitle: subrip
title : CC
and in attachement the log when i try to watch the episode 2 with subtitle
serviio-episode2.log
debug log for episode 2 with external subtitle
(25.23 KiB) Downloaded 399 times
and the same file (renamed) with no subtitles
serviio-test2.log
debug log for episode 2 (renamed) without srt
(28.94 KiB) Downloaded 380 times
For Information, the same episode2 with subtitles watched from a samsung C serie wich is fine with softsub
serviio-episode2-Samsung.log
debug log episode2 with external subtitle read by samsung C
(33.4 KiB) Downloaded 370 times
Thx.
Post Sun Apr 13, 2014 4:14 pm
maybe the srt file is bad... There is a srt fix tool linked on the forum or wiki, try that.
But basiccally the TV asks for the subtitle, receives it and never asks for the actual video.
Previous
