Sharp Aquos DLNA Profiles
Post Mon Apr 22, 2013 12:18 pm
Re: Sharp Aquos DLNA Profiles
zip wrote:No way to distinguish, unless they have different H264 profiles/levels.
1920x800 and 640x464 are also differents, there were an opened ticket about non-standard h264 resolution that could be detected then transcoded...
Pyros
Post Fri Apr 11, 2014 8:50 pm
this profile works fine if there's no subtitles...
for each tvshow with external subtitle, i got a file error on ma sharp 39LE952.
How could i fix it ?
Post Fri Apr 11, 2014 11:24 pm
post detailed log of playing the file
Pyros
Post Sat Apr 12, 2014 6:34 am
Hi just copied a tvshow episode to test_zip.mkv to show difference between with and without external subtitle (utf-8 srt file with the same name as the mkv file)
Here's the ffmpeg -i
ffmpeg version 1.1.git Copyright (c) 2000-2013 the FFmpeg developers
built on Oct 7 2013 22:31:52 with gcc 4.7 (Ubuntu/Linaro 4.7.3-1ubuntu1)
configuration: --enable-gpl --enable-libfaac --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libtheora --enable-libvorbis --enable-libx264 --enable-nonfree --enable-postproc --enable-version3 --enable-x11grab --enable-librtmp --enable-libxvid --enable-libass
Input #0, matroska,webm, from '/media//video/series/From Dusk Till Dawn The Series/Saison 01/test_zip2.mkv':
creation_time : 2014-03-19 07:08:56
Duration: 00:46:17.22, start: 0.000000, bitrate: 4618 kb/s
Stream #0:0(eng): Video: h264 (High), yuv420p, 1280x720 [SAR 1:1 DAR 16:9], 23.98 fps, 23.98 tbr, 1k tbn, 2k tbc (default)
Stream #0:1(eng): Audio: ac3, 48000 Hz, 5.1(side), fltp, 384 kb/s (default)
Stream #0:2(eng): Subtitle: subrip
title : CC
and in attachement the log when i try to watch the episode 2 with subtitle
serviio-episode2.log
debug log for episode 2 with external subtitle
(25.23 KiB) Downloaded 389 times
and the same file (renamed) with no subtitles
serviio-test2.log
debug log for episode 2 (renamed) without srt
(28.94 KiB) Downloaded 371 times
For Information, the same episode2 with subtitles watched from a samsung C serie wich is fine with softsub
serviio-episode2-Samsung.log
debug log episode2 with external subtitle read by samsung C
(33.4 KiB) Downloaded 359 times
Thx.
Post Sun Apr 13, 2014 4:14 pm
maybe the srt file is bad... There is a srt fix tool linked on the forum or wiki, try that.
But basiccally the TV asks for the subtitle, receives it and never asks for the actual video.
Previous
Users browsing this forum: Google [Bot] and 76 guests
