incomplete movie list
foxhole
Post Fri Apr 03, 2015 4:54 pm
Is there a limit to the amount of movies serviio will display, though I have about 400 movies in my folder about 15% do not appear in the listings, if I search the 'movies' list those that are missing appear but all with the simple title of 'FILM' and not their original title in the movie folder.?
Post Sat Apr 04, 2015 1:48 am
Re: incomplete movie list
If Serviio and the player think a video will not play, it is not displayed. Make sure you have the correct profile selected for your player. Serviio isn't perfect determining the right one. Not the fault of Serviio, some TVs and BD players don't identify themselves well, if at all.
To my knowledge there's no practical limitation on file count. I have almost 700 movies and over 1500 TV episodes and they are all listed.
foxhole
Post Thu Apr 16, 2015 9:39 pm
As I said , movies will play so correct format, just not displayed correctly.
Post Thu Apr 16, 2015 11:35 pm
Sorry, I overlooked that part. :oops:
What is the naming format you are using? I have seen an occasional file not get named correctly and it might pick up some sort of metadata embedded in the video. Yours might just have "FILM" embedded as the title.
foxhole
Post Fri Apr 17, 2015 6:47 pm
films are just ''movie name'' .mkv or.avi or.mp4
Post Fri Apr 17, 2015 7:49 pm
Also, check the folder in which the FILM files are located for files that may contain metadata. May be hidden files - look for .nfo files or basically anything that isn't a media file and remove for now. Force refresh and update metadata.
foxhole
Post Fri Apr 17, 2015 10:17 pm
All films are on a separate hard drive in computer with no other files in them. [its a mac so no .nfo except in the parrallels program which runs windows , again on another hard drive.] Have 4 hard drives.
Post Fri Apr 17, 2015 10:58 pm
Use MediaInfo and see if there is an embedded title within the file as atc98092 suggested. A few other things to try:
  • turn on detailed logging so you can track what is happening. After restarting give it a while and then
  • move one of the offending folders to a new folder in your share (or start a new share);
  • see how it appears in the Movies category
  • move it back and confirm that it appears in the movies category.
then zip and post the log file and let's see what that tells us.
Post Sat Apr 18, 2015 1:58 am
foxhole wrote:All films are on a separate hard drive in computer with no other files in them. [its a mac so no .nfo except in the parrallels program which runs windows , again on another hard drive.] Have 4 hard drives.
.nfo files are not Windows specific, although Windows does use that extension for something other than this purpose. Many media servers can use nfo files for metadata information, hence the question. :)
foxhole
Post Sun Apr 19, 2015 8:43 pm
DenyAll wrote:Use MediaInfo and see if there is an embedded title within the file as atc98092 suggested. A few other things to try:
Could not get mediainfo to work crashes on start up.
foxhole
Post Sun Apr 19, 2015 8:44 pm
No nfo files found [except on Windows in parallels]
Users browsing this forum: Baidu [Spider] and 17 guests
