Serviio 1.5.1 service shutting down or crashing randomly
schmidty00
Post Mon Mar 09, 2015 11:46 pm
I have noticed over the past few days (and it could have been happening earlier) that the serviio service running on my headless Windows XP file server machine has shutting down or crashing, at random. This is causing the serviio console to not be able to be loaded or throws an error because the service is not running. I only start to notice this a few days ago when I tried to connect to the Mediabrowser and I could not. From then I have been seeing problems.
Once I restart the service from the command line (net start serviio) everything starts back up and all is good. But it seems like everyday or every other day I have needed to restart that service. I have started to look most everyday now to see if it is running and I just had to restart the service.
I am running serviio 1.5.1 pro. I can't ever remember having this issue with 1.4. Can someone help point me in the right direction on what I should be looking for and when? I tried looking around the forum for this issue but didn't come across anyone having serviio service issues. I have yet to uninstall and reinstall the software. Thanks.
Sony BDP-S570 | LG BP530 | Netgear NTV300SL | Firestick (ServiioGo sideloaded) | Serviio v1.5.2 Pro
tr671jc
Post Thu Mar 12, 2015 1:39 am
Re: Serviio 1.5.1 service shutting down or crashing randomly
I have the same problem since upgrading from 1.4 to 1.5.1. Also using XP on the server. System has been rock steady for years under prior releases.
Right now it seems there is a bug in this upgrade. Mine crashes once a day with the service going down by itself. If the monitor is running I usually see a message that the service has stopped running.
I have not figured out a fix yet.
Post Thu Mar 12, 2015 9:27 am
What Service Pack are you on (SP1, SP2, SP3 or base)?
You could try to revert back to the polling method of library updates to see if it is the new library update mechanism that is causing the problem - see http://wiki.serviio.org/doku.php?id=lib ... _mechanism and the bit about Forcing POLLER scanner. Restart your server after changing the system property. Please report back if this stabilizes things.
If it isnt this, post a detailed log.
Mdnss
Post Sat Mar 14, 2015 3:37 pm
Same here.
I have Win 8.1 x64 and a Linksys router.
Most of the time I start a movie or just a video and after 10-15 mins the service restarts. We have to wait until it comes back and can restart watching.
Did not have this issue previously.
(I did upgrade from 1.5 and Win 7 x64 almost the same time)
schmidty00
Post Sat Mar 14, 2015 5:00 pm
My setup is this:
System:
Microsoft Windows XP
Media Center Edition
Version 2002
Service Pack 3
I'm not sure what triggers it and when. I will have to try the polling method DenyAll when I have a little more time to mess with it. Until then, I wrote a short executable that checks if the service is running, if not, it kills the serviioconsole.exe, restarts the serviio service, and then restarts the serviioconsole.exe. This runs in a 10 second loop and if a restart of the service is required it will write that to a log file. I want to know when / how often it is doing this as well as get serviio back up and running. The serviio debug log just shows lines of cannot connect.
I am going to let it run for a few days and I'll see what my log file says. This is a bandaid for now and thankfully others are having the same experience, I thought I was crazy.
tr671jc
Post Tue Mar 17, 2015 5:46 pm
The random crashing continues but there is no pattern to it. Running on XP Pro SP3. Since my Servio seems not to crash when I am using it I setup a temp fix that is described below.
When Serviio crashes it makes an entry in the Event Log (System) of either ID 7034 or 7031 depending on how the Recovery Tab is configured for Service Control Manager.
A fix to auto restart Serviio goes this way. Enter Computer Management by Right Click My Computer then Manage. Click on Services in the right Panel then Services again. Scroll down to the Serviio Service Name, Dclick it then open the Recovery Tab and set First Failure to Restart the Service then Make the Reset Count 10 days. This will give you a cumulative fail count in your Logs over a ten day period.
Serviio is always running for me now since I only use it in the evening and the shutdown has not occurred in that period. Additionally I noticed this whole process started a few days before I upgraded to 1.5.1 and was still in 1.4.x. This makes me believe the real cause is the OS or other apps. I did take in several security updates a while back from Microsoft for example.
schmidty00
Post Mon Mar 23, 2015 12:57 am
Here are the results of my log file since I started running this check just over a week ago.
2015-03-14 11:28:59|Serviio service and console restarted
2015-03-14 23:01:54|Serviio service and console restarted
2015-03-17 00:05:01|Serviio service and console restarted
2015-03-17 00:05:30|Serviio service and console restarted
2015-03-17 00:05:59|Serviio service and console restarted
2015-03-17 09:46:22|Serviio service and console restarted
2015-03-19 16:50:50|Serviio service and console restarted
2015-03-21 21:04:43|Serviio service and console restarted
2015-03-21 22:35:41|Serviio service and console restarted
2015-03-23 15:31:37|Serviio service and console restarted
2015-03-23 23:38:17|Serviio service and console restarted
2015-03-24 00:16:04|Serviio service and console restarted
2015-03-27 16:46:58|Serviio service and console restarted
I do not see a pattern here. Thoughts on these results?
wildchild55719
Post Tue Mar 24, 2015 3:44 am
I'm am having similar problem on Ubuntu server. But I upgraded both at same time
Ubuntu 14.04 and serviio 1.5 dumb I know lol but in a hurry
It is crashing about 10 hrs after startup . Console says it is running but you can't see it on any of the player s ( Vlc for iPad & iphone also sony and Samsung tv
I also can not see my video files all my pics and mp3's are there but no videos .
(upadate) reinstalled 1.5.1 woorking good now . fixed crashing
video file's not showing up was ffmpeg not linked to right location
Last edited by wildchild55719 on Mon Mar 30, 2015 3:04 am, edited 2 times in total.
Jeremy R.Erspamer
ubuntu desktop 16.04
serviio pro
Sony Internet tv nsxgt1
serviio GO
sony srt5800es2
samsung un55es7500f
ps3 ps4
sony vdv-n790w
PS3
4 Iphone's "vlc"
3 Ipad's "vlc"
schmidty00
Post Sat Mar 28, 2015 1:56 am
Attached is a copy of the error log file from the last crash about 4 hours ago.
Here is snippet of the serviio.log file from the same time frame:
2015-03-27 16:45:42,280 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /192.168.0.7:49152s
2015-03-27 16:45:42,280 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaServer:1 from address /169.254.51.128:49152s
2015-03-27 16:45:42,280 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /192.168.0.7:49152
2015-03-27 16:45:42,280 DEBUG [DiscoverySearchResponder] Sending 1 M-SEARCH response message(s) to /169.254.51.128:49152
2015-03-27 16:45:58,543 DEBUG [DiscoverySSDPMessageListener] Received a valid NOTIFY (ssdp:alive) message from Renderer d3b06a7f-b26a-7fb9-ae63-7f09b2b9bb02 from address 192.168.0.11
2015-03-27 16:45:58,684 DEBUG [DiscoverySSDPMessageListener] Received a valid NOTIFY (ssdp:alive) message from Renderer d3b06a7f-b26a-7fb9-ae63-7f09b2b9bb02 from address 192.168.0.11
2015-03-27 16:46:01,152 DEBUG [SearchManager] Committing search index
2015-03-27 16:46:28,649 DEBUG [DiscoverySSDPMessageListener] Received a valid NOTIFY (ssdp:alive) message from Renderer d3b06a7f-b26a-7fb9-ae63-7f09b2b9bb02 from address 192.168.0.11
2015-03-27 16:46:28,774 DEBUG [DiscoverySSDPMessageListener] Received a valid NOTIFY (ssdp:alive) message from Renderer d3b06a7f-b26a-7fb9-ae63-7f09b2b9bb02 from address 192.168.0.11
2015-03-27 16:46:31,149 DEBUG [SearchManager] Committing search index
2015-03-27 16:46:32,414 DEBUG [FeedUpdaterWorker] Checking for new and expired online resources
2015-03-27 16:46:32,414 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2015-03-27 16:47:03,958 INFO [ServiioConsole] Initializing Serviio Console
2015-03-27 16:47:04,270 DEBUG [ApplicationInstanceManager] Listening for application instances on socket 44332
2015-03-27 16:47:04,270 DEBUG [ApplicationInstanceManager] Listening for application instances on socket 44331
2015-03-27 16:47:04,270 INFO [MediaServer] ------------------------------------------------------------------------
2015-03-27 16:47:04,270 INFO [MediaServer] Serviio DLNA media streaming server v 1.5.1 (rev. 9d3f18af690f)
2015-03-27 16:47:04,270 INFO [MediaServer] Petr Nejedly 2009-2015
2015-03-27 16:47:04,270 INFO [MediaServer] http://www.serviio.org
2015-03-27 16:47:04,270 INFO [MediaServer] Java 1.8.0_31-Oracle Corporation x86
2015-03-27 16:47:04,270 INFO [MediaServer] OS Windows XP 5.1
2015-03-27 16:47:04,270 INFO [MediaServer] File encoding: windows-1252
2015-03-27 16:47:04,270 INFO [ServiioConsole] Starting Serviio Console
2015-03-27 16:47:04,301 INFO [MediaServer] Headless mode enabled: true
2015-03-27 16:47:04,301 INFO [MediaServer] User: SYSTEM
2015-03-27 16:47:04,301 INFO [MediaServer] User home dir: C:\WINDOWS\system32\config\systemprofile
2015-03-27 16:47:04,301 INFO [MediaServer] Temp dir: C:\WINDOWS\TEMP\
2015-03-27 16:47:04,301 INFO [MediaServer] ------------------------------------------------------------------------
2015-03-27 16:47:04,458 DEBUG [MediaServer] Runtime params: -Dexe4j.semaphoreName=Local\c:_program_files_pc5dczc_bin_serviioservice.exe0, -Dexe4j.isService=true, -Dexe4j.moduleName=C:\Program Files\Serviio\bin\ServiioService.exe, -Dexe4j.tempDir=C:\WINDOWS\TEMP\e4j14C.tmp_dir1427492818, -Dexe4j.unextractedPosition=327425, -Djava.library.path=C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\system32\wbem;c:\Python22;C:\Program Files\Common Files\Roxio Shared\DLLShared\;C:\Program Files\Common Files\Ulead Systems\MPEG;C:\Program Files\QuickTime\QTSystem\;C:\Program Files\Microsoft SQL Server\90\Tools\binn\;C:\Program Files\ATI Technologies\ATI.ACE\Core-Static;c:\program files\serviio\jre\bin, -Dexe4j.consoleCodepage=cp0, -Xms20M, -XX:+UseG1GC, -XX:GCTimeRatio=1, -XX:MinHeapFreeRatio=10, -XX:MaxHeapFreeRatio=20, -Djava.net.preferIPv4Stack=true, -Djava.awt.headless=true, -Dorg.restlet.engine.loggerFacadeClass=org.restlet.ext.slf4j.Slf4jLoggerFacade, -Dserviio.home=C:\Program Files\Serviio\bin\\.., -Dderby.system.home=C:\Program Files\Serviio\bin\\..\library, -Xrs, -Xmx512m
2015-03-27 16:47:05,848 INFO [WebServer] Socket buffer set to 65535 bytes
2015-03-27 16:47:05,895 INFO [RestletServer] Starting Restlet server (/rest) exposed on port 23423
2015-03-27 16:47:05,989 DEBUG [SwingHelper] Choosing java look and feel: com.sun.java.swing.plaf.windows.WindowsLookAndFeel
2015-03-27 16:47:06,957 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2015-03-27 16:47:06,957 DEBUG [ServiioConsole] Checking if server is running
2015-03-27 16:47:07,348 INFO [RestletServer] Starting Restlet server (/cds) exposed on port 23424
2015-03-27 16:47:07,348 INFO [RestletServer] Starting Restlet server (/mediabrowser) exposed on port 23424
2015-03-27 16:47:07,410 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2015-03-27 16:47:07,551 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.sql' has been run
2015-03-27 16:47:07,567 INFO [DatabaseManager] Using DERBY database language
2015-03-27 16:47:18,597 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.1.sql' has been run
2015-03-27 16:47:18,597 DEBUG [DBLogDAOImpl] Checking if script 'script-0.2.sql' has been run
2015-03-27 16:47:18,597 DEBUG [DBLogDAOImpl] Checking if script 'script-0.3.1.sql' has been run
2015-03-27 16:47:18,597 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.sql' has been run
2015-03-27 16:47:18,597 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.1.sql' has been run
2015-03-27 16:47:18,597 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.2.sql' has been run
2015-03-27 16:47:18,597 DEBUG [DBLogDAOImpl] Checking if script 'script-0.5.sql' has been run
2015-03-27 16:47:18,597 DEBUG [DBLogDAOImpl] Checking if script 'script-0.5.1.sql' has been run
2015-03-27 16:47:18,597 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.sql' has been run
2015-03-27 16:47:18,612 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.1.sql' has been run
2015-03-27 16:47:18,612 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.2.sql' has been run
2015-03-27 16:47:18,612 DEBUG [DBLogDAOImpl] Checking if script 'script-1.0.sql' has been run
2015-03-27 16:47:18,612 DEBUG [DBLogDAOImpl] Checking if script 'script-1.1.sql' has been run
2015-03-27 16:47:18,612 DEBUG [DBLogDAOImpl] Checking if script 'script-1.2.sql' has been run
2015-03-27 16:47:18,612 DEBUG [DBLogDAOImpl] Checking if script 'script-1.2.1.sql' has been run
2015-03-27 16:47:18,612 DEBUG [DBLogDAOImpl] Checking if script 'script-1.3.sql' has been run
2015-03-27 16:47:18,612 DEBUG [DBLogDAOImpl] Checking if script 'script-1.4.sql' has been run
2015-03-27 16:47:18,612 DEBUG [DBLogDAOImpl] Checking if script 'script-1.5.sql' has been run
2015-03-27 16:47:18,643 DEBUG [LicensingManager] Updating license
2015-03-27 16:47:18,659 DEBUG [ConfigEntryDAOImpl] Reading all ConfigEntries
2015-03-27 16:47:18,675 DEBUG [LicenseValidator] Validating license file (372 bytes)
2015-03-27 16:47:18,972 INFO [MediaServer] ------------------------------------------------------------------------
2015-03-27 16:47:18,972 INFO [MediaServer] License: PRO (NORMAL, id: 6a4b77e2-e9cc-4282-98b8-ac5238d1802b)
2015-03-27 16:47:18,972 DEBUG [LocalAddressResolverStrategy] Resolving host IP address automatically
2015-03-27 16:47:19,565 INFO [Device] Created UPnP Device with UUID: 90775982-25b4-38fa-940e-be80e85deb5a, bound address: 192.168.0.4
Any help is greatly appreciated, thanks.
hs_err_pid3352.log
(44.5 KiB) Downloaded 662 times
Post Sun Mar 29, 2015 12:52 pm
It looks like the last call was to retrieve the network interfaces on your PC. Try to upgrade your network card driver.
schmidty00
Post Thu Apr 02, 2015 3:32 pm
zip wrote:It looks like the last call was to retrieve the network interfaces on your PC. Try to upgrade your network card driver.
I went out and found the latest driver for this PC's network card and updated it manually as Microsoft XP was using a generic one. I'll keep an eye on it for another week and see if anything else gets written to the log file. Maybe it could be just as simple as a driver out-of-date. ;)
schmidty00
Post Wed Apr 08, 2015 10:17 pm
Well that didn't seem to be it.
2015-04-03 12:31:38|Serviio service and console restarted
2015-04-05 01:06:28|Serviio service and console restarted
2015-04-07 19:09:25|Serviio service and console restarted
It has restarted 3 more times since I updated the network card driver. Other thoughts?
Post Thu Apr 09, 2015 12:43 am
Now that 1.5.2 is out try upgrading your Serviio - I'm 99% sure it won't fix the issue, but will be a necessary step at some stage, so perhaps upgrade whilst waiting for zip to come back to you.
schmidty00
Post Tue Apr 14, 2015 1:50 am
I updated to 1.5.2. Now I wait.
2015-04-10 16:05:55|Serviio service and console restarted
2015-04-12 11:40:28|Serviio service and console restarted
2015-04-12 18:00:34|Serviio service and console restarted
2015-04-13 06:04:54|Serviio service and console restarted
2015-04-13 12:54:25|Serviio service and console restarted
schmidty00
Post Wed Apr 22, 2015 4:50 pm
Since the upgrade, Serviio has NOT crashed or restarted according to my log file.
I'll keep monitoring it, but maybe that "glitch" was fixed in v1.5.2.
Post Wed Apr 22, 2015 9:53 pm
DenyAll wrote:I'm 99% sure it won't fix the issue...
doh! but a good doh! :D Glad it's fixed.
Post Fri Apr 24, 2015 3:55 pm
1.5.2 has a new Java, so maybe that helped :-)
Users browsing this forum: No registered users and 58 guests
