Samsung TV B652T: Unsupported video
serp2002
Post Sat Apr 25, 2015 9:29 am
Hallo there,
one of my tv's can't play mkv video.
I use serviio pro 1.4.1.2 under Ubuntu 14.04.
For that tv i set profile "SAMSUNG TV B series", and for one file got "unsupported video".
I set logging level to DEBUG for "org.serviio", but i can't see any information about try to transcode that file when i try to play it. I want see ffmpeg command line options, but i don't know how to do that.
Can anyone help me?
ffmpeg version:
ffmpeg version 2.5.2 Copyright (c) 2000-2014 the FFmpeg developers
built on Dec 25 2014 00:04:42 with gcc 4.8 (Ubuntu 4.8.2-19ubuntu1)
configuration: --extra-libs=-ldl --prefix=/opt/ffmpeg --enable-avresample --disable-debug --enable-nonfree --enable-gpl --enable-version3 --enable-libpulse --enable-libopencore-amrnb --enable-libopencore-amrwb --disable-decoder=amrnb --disable-decoder=amrwb --enable-libx264 --enable-libx265 --enable-libfdk-aac --enable-libvorbis --enable-libmp3lame --enable-libopus --enable-libvpx --enable-libspeex --enable-libass --enable-avisynth --enable-libsoxr --enable-libxvid --enable-libvo-aacenc
libavutil 54. 15.100 / 54. 15.100
libavcodec 56. 13.100 / 56. 13.100
libavformat 56. 15.102 / 56. 15.102
libavdevice 56. 3.100 / 56. 3.100
libavfilter 5. 2.103 / 5. 2.103
libavresample 2. 1. 0 / 2. 1. 0
libswscale 3. 1.101 / 3. 1.101
libswresample 1. 1.100 / 1. 1.100
libpostproc 53. 3.100 / 53. 3.100
mediainfo of bad file:
Unique ID                                : 250717326051756771866474228855502269348 (0xBC9E668C8A5D5481B2B0361C929BEBA4)
Complete name                            : Rio  2011 1080р.mkv
File size                                : 4.42 GiB
Duration                                 : 1h 35mn
Overall bit rate                         : 6 596 Kbps
Movie name                               : Rip by victordan 95
Encoded date                             : UTC 2011-07-09 19:17:33
Writing application                      : mkvmerge v4.6.0 ('Still Crazy After All These Years') built on Mar 10 2011 02:50:32
Writing library                          : libebml v1.2.0 + libmatroska v1.1.0
Muxing mode                              : Header stripping
Duration                                 : 1h 35mn
Bit rate                                 : 5 832 Kbps
Maximum bit rate                         : 15.0 Mbps
Height                                   : 800 pixels
Display aspect ratio                     : 2.40:1
Bits/(Pixel*Frame)                       : 0.158
Stream size                              : 3.82 GiB (86%)
Writing library                          : x264 core 115 r1995 c1e60b9
Encoding settings                        : cabac=1 / ref=4 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=3 / sliced_threads=0 / slices=4 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=1 / constrained_intra=0 / bframes=3 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=1 / keyint=24 / keyint_min=1 / scenecut=40 / intra_refresh=0 / rc_lookahead=24 / rc=2pass / mbtree=1 / bitrate=5832 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=15000 / vbv_bufsize=15000 / nal_hrd=vbr / ip_ratio=1.10 / aq=1:1.00
Audio #1
Duration                                 : 1h 35mn
Bit rate                                 : 384 Kbps
Stream size                              : 264 MiB (6%)
Audio #2
Duration                                 : 1h 35mn
Bit rate                                 : 384 Kbps
Post Sun Apr 26, 2015 12:14 am
Re: Samsung TV B652T: Unsupported video
Unless I missed it when I looked at that profile, your file isn't being transcoded. There is no MKV specific line that covers High@L4.1, and the wildcard line is for L4.2 and greater.
First, do you have any other files with the same video codec that do play? If so, there could be something wrong with the file. If you have no other High@L4.1 videos, then change the generic line
<Matches container="*" vCodec="h264" profile="high" levelGreaterThan="4.2" />
to
<Matches container="*" vCodec="h264" profile="high" levelGreaterThan="4.0" />
After changing that line, remember that you must either reboot the computer or restart the Serviio service. Just closing and opening the console does not do this, nor does the button on the console that says "Stop Server". This button only controls the DLNA server, not the background service.
serp2002
Post Sun Apr 26, 2015 2:24 am
I do what you say, and it do not help. Rio.mkv sill not play. It show "unsupported video".
Bad file, i can play on LG TV. If it corrupted, why it plaing on other tv?
I think, there need debug.
I have file (High@L4.1), that playing fine:
Unique ID                                : 188204440902675043299919145086551171050 (0x8D96DB59DFA2D6CFB4977D25F6999FEA)
Complete name                            : Frozen 2013 1080р.mkv
File size                                : 5.70 GiB
Duration                                 : 1h 42mn
Overall bit rate                         : 7 987 Kbps
Movie name                               : Frozen.(2013).BDRip.1080p.[envy]
Encoded date                             : UTC 2014-03-02 18:17:36
Writing application                      : mkvmerge v5.8.0 ('No Sleep / Pillow') built on Sep  2 2012 15:37:04
Writing library                          : libebml v1.2.3 + libmatroska v1.3.0
Format settings, ReFrames                : 5 frames
Duration                                 : 1h 42mn
Bit rate                                 : 6 974 Kbps
Height                                   : 856 pixels
Display aspect ratio                     : 2.25:1
Bits/(Pixel*Frame)                       : 0.177
Stream size                              : 4.86 GiB (85%)
Title                                    : Холодное сердце.(2013).BDRip.1080p.[envy]
Writing library                          : x264 core 140 r2377 1ca7bb9
Encoding settings                        : cabac=1 / ref=5 / deblock=1:-1:-1 / analyse=0x3:0x133 / me=umh / subme=11 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=48 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=7 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc=2pass / mbtree=0 / bitrate=6974 / ratetol=2.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=2:0.80
Audio #1
Duration                                 : 1h 42mn
Bit rate                                 : 384 Kbps
Stream size                              : 281 MiB (5%)
Title                                    : dub
Language                                 : Russian
Audio #2
Duration                                 : 1h 42mn
Bit rate                                 : 640 Kbps
Stream size                              : 468 MiB (8%)
Title                                    : Eng
Text #1
Format                                   : UTF-8
Codec ID                                 : S_TEXT/UTF8
Codec ID/Info                            : UTF-8 Plain Text
Title                                    : rus full
Language                                 : Russian
Text #2
Format                                   : UTF-8
Title                                    : eng full
Menu
00:00:00.000                             : :Chapter 01
00:05:59.817                             : :Chapter 02
00:11:37.946                             : :Chapter 03
00:19:53.734                             : :Chapter 04
00:31:03.194                             : :Chapter 05
00:38:39.483                             : :Chapter 06
00:44:21.283                             : :Chapter 07
00:50:51.506                             : :Chapter 08
00:57:48.381                             : :Chapter 09
01:02:57.398                             : :Chapter 10
01:09:36.046                             : :Chapter 11
01:13:34.868                             : :Chapter 12
01:18:07.599                             : :Chapter 13
01:22:33.740                             : :Chapter 14
01:27:10.808                             : :Chapter 15
01:32:33.506                             : :Chapter 16
01:42:12.793                             : :Chapter 17
So, i think ffmpeg do not transcode bad file.
serp2002
Post Sun Apr 26, 2015 3:12 am
In log file:
2015-04-26 13:03:16,063 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1229, format MATROSKA and profile Samsung TV (B-series)
2015-04-26 13:03:16,064 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/x-mkv,Content-Length: 4747298119,Date: Sun, 26 Apr 2015 03:03:16 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/1.4.1.2,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=MATROSKA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,MediaInfo.sec: SEC_Duration=5757000;]]
2015-04-26 13:03:16,075 DEBUG [ServiioHttpService] Incoming request from /192.168.254.50:4301: GET /resource/1229/MEDIA_ITEM/MATROSKA-0/ORIGINAL HTTP/1.0, headers = [Range: bytes=0-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 192.168.254.200:8895]]
2015-04-26 13:03:16,075 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.254.50
2015-04-26 13:03:16,076 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.254.50, Profile=Samsung TV (B-series)'
2015-04-26 13:03:16,076 DEBUG [ResourceDeliveryProcessor] Request for resource 1229 and type 'MEDIA_ITEM' received
2015-04-26 13:03:16,076 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1229 (local)
2015-04-26 13:03:16,076 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1229)
2015-04-26 13:03:16,076 DEBUG [VideoDAOImpl] Reading a Video (id = 1229)
2015-04-26 13:03:16,076 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1229, format MATROSKA and profile Samsung TV (B-series)
2015-04-26 13:03:16,076 DEBUG [VideoDeliveryEngine] Delivering item '1229' for client 'Identifier=192.168.254.50, Profile=Samsung TV (B-series)'
2015-04-26 13:03:16,077 DEBUG [VideoDeliveryEngine] Delivering file 'Rio (Рио) 2011 1080р.mkv' in native format
2015-04-26 13:03:16,077 DEBUG [MediaItemDAOImpl] Getting file of media item 1229
2015-04-26 13:03:16,077 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 1229) as read
2015-04-26 13:03:16,099 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2015-04-26 13:03:16,099 DEBUG [GETMethodProcessor] Stream entity has length: 4747298119
2015-04-26 13:03:16,100 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-mkv,Content-Length: 4747298119,Date: Sun, 26 Apr 2015 03:03:16 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/1.4.1.2,Cache-control: no-cache,Content-Range: bytes 0-4747298118/4747298119,contentFeatures.dlna.org: DLNA.ORG_PN=MATROSKA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2015-04-26 13:03:16,118 DEBUG [WebServer] I/O error: Connection reset
2015-04-26 13:03:16,119 DEBUG [ServiioHttpService] Incoming request from /192.168.254.50:2888: GET /resource/1229/MEDIA_ITEM/MATROSKA-0/ORIGINAL HTTP/1.0, headers = [Range: bytes=40-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 192.168.254.200:8895]]
2015-04-26 13:03:16,119 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.254.50
2015-04-26 13:03:16,120 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.254.50, Profile=Samsung TV (B-series)'
2015-04-26 13:03:16,120 DEBUG [ResourceDeliveryProcessor] Request for resource 1229 and type 'MEDIA_ITEM' received
2015-04-26 13:03:16,120 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1229 (local)
2015-04-26 13:03:16,120 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1229)
2015-04-26 13:03:16,124 DEBUG [VideoDAOImpl] Reading a Video (id = 1229)
2015-04-26 13:03:16,125 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1229, format MATROSKA and profile Samsung TV (B-series)
2015-04-26 13:03:16,125 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1229 (local)
2015-04-26 13:03:16,125 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1229)
2015-04-26 13:03:16,125 DEBUG [VideoDAOImpl] Reading a Video (id = 1229)
2015-04-26 13:03:16,126 DEBUG [VideoDeliveryEngine] Delivering item '1229' for client 'Identifier=192.168.254.50, Profile=Samsung TV (B-series)'
2015-04-26 13:03:16,126 DEBUG [VideoDeliveryEngine] Delivering file 'Rio (Рио) 2011 1080р.mkv' in native format
2015-04-26 13:03:16,126 DEBUG [MediaItemDAOImpl] Getting file of media item 1229
2015-04-26 13:03:16,126 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 1229) as read
2015-04-26 13:03:16,138 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2015-04-26 13:03:16,138 DEBUG [GETMethodProcessor] Stream entity has length: 4747298079
2015-04-26 13:03:16,139 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-mkv,Content-Length: 4747298079,Date: Sun, 26 Apr 2015 03:03:16 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/1.4.1.2,Cache-control: no-cache,Content-Range: bytes 40-4747298118/4747298119,contentFeatures.dlna.org: DLNA.ORG_PN=MATROSKA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2015-04-26 13:03:16,158 DEBUG [WebServer] I/O error: Connection reset
2015-04-26 13:03:16,160 DEBUG [ServiioHttpService] Incoming request from /192.168.254.50:3140: GET /resource/1229/MEDIA_ITEM/MATROSKA-0/ORIGINAL HTTP/1.0, headers = [Range: bytes=105-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 192.168.254.200:8895]]
2015-04-26 13:03:16,160 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.254.50
2015-04-26 13:03:16,161 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.254.50, Profile=Samsung TV (B-series)'
2015-04-26 13:03:16,161 DEBUG [ResourceDeliveryProcessor] Request for resource 1229 and type 'MEDIA_ITEM' received
2015-04-26 13:03:16,161 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1229 (local)
2015-04-26 13:03:16,161 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1229)
2015-04-26 13:03:16,161 DEBUG [VideoDAOImpl] Reading a Video (id = 1229)
2015-04-26 13:03:16,161 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1229, format MATROSKA and profile Samsung TV (B-series)
2015-04-26 13:03:16,162 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1229 (local)
2015-04-26 13:03:16,162 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1229)
2015-04-26 13:03:16,162 DEBUG [VideoDAOImpl] Reading a Video (id = 1229)
2015-04-26 13:03:16,162 DEBUG [VideoDeliveryEngine] Delivering item '1229' for client 'Identifier=192.168.254.50, Profile=Samsung TV (B-series)'
2015-04-26 13:03:16,162 DEBUG [VideoDeliveryEngine] Delivering file 'Rio (Рио) 2011 1080р.mkv' in native format
2015-04-26 13:03:16,162 DEBUG [MediaItemDAOImpl] Getting file of media item 1229
2015-04-26 13:03:16,163 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 1229) as read
2015-04-26 13:03:16,176 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2015-04-26 13:03:16,176 DEBUG [GETMethodProcessor] Stream entity has length: 4747298014
2015-04-26 13:03:16,176 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-mkv,Content-Length: 4747298014,Date: Sun, 26 Apr 2015 03:03:16 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/1.4.1.2,Cache-control: no-cache,Content-Range: bytes 105-4747298118/4747298119,contentFeatures.dlna.org: DLNA.ORG_PN=MATROSKA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2015-04-26 13:03:16,195 DEBUG [WebServer] I/O error: Connection reset
2015-04-26 13:03:16,197 DEBUG [ServiioHttpService] Incoming request from /192.168.254.50:4308: GET /resource/1229/MEDIA_ITEM/MATROSKA-0/ORIGINAL HTTP/1.0, headers = [Range: bytes=4151-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 192.168.254.200:8895]]
2015-04-26 13:03:16,197 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.254.50
2015-04-26 13:03:16,198 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.254.50
2015-04-26 13:03:16,198 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.254.50, Profile=Samsung TV (B-series)'
2015-04-26 13:03:16,198 DEBUG [ResourceDeliveryProcessor] Request for resource 1229 and type 'MEDIA_ITEM' received
2015-04-26 13:03:16,198 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1229 (local)
2015-04-26 13:03:16,198 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1229)
2015-04-26 13:03:16,199 DEBUG [VideoDAOImpl] Reading a Video (id = 1229)
2015-04-26 13:03:16,199 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1229, format MATROSKA and profile Samsung TV (B-series)
2015-04-26 13:03:16,199 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1229 (local)
2015-04-26 13:03:16,199 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1229)
2015-04-26 13:03:16,199 DEBUG [VideoDeliveryEngine] Delivering item '1229' for client 'Identifier=192.168.254.50, Profile=Samsung TV (B-series)'
2015-04-26 13:03:16,199 DEBUG [VideoDeliveryEngine] Delivering file 'Rio (Рио) 2011 1080р.mkv' in native format
2015-04-26 13:03:16,199 DEBUG [MediaItemDAOImpl] Getting file of media item 1229
2015-04-26 13:03:16,199 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 1229) as read
2015-04-26 13:03:16,215 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2015-04-26 13:03:16,215 DEBUG [GETMethodProcessor] Stream entity has length: 4747293968
2015-04-26 13:03:16,215 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-mkv,Content-Length: 4747293968,Date: Sun, 26 Apr 2015 03:03:16 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/1.4.1.2,Cache-control: no-cache,Content-Range: bytes 4151-4747298118/4747298119,contentFeatures.dlna.org: DLNA.ORG_PN=MATROSKA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2015-04-26 13:03:16,232 DEBUG [WebServer] I/O error: Connection reset
2015-04-26 13:03:16,234 DEBUG [ServiioHttpService] Incoming request from /192.168.254.50:1734: GET /resource/1229/MEDIA_ITEM/MATROSKA-0/ORIGINAL HTTP/1.0, headers = [Range: bytes=4347-,getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming,Host: 192.168.254.200:8895]]
2015-04-26 13:03:16,234 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.254.50
2015-04-26 13:03:16,235 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.254.50
2015-04-26 13:03:16,235 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.254.50, Profile=Samsung TV (B-series)'
2015-04-26 13:03:16,235 DEBUG [ResourceDeliveryProcessor] Request for resource 1229 and type 'MEDIA_ITEM' received
2015-04-26 13:03:16,235 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1229 (local)
2015-04-26 13:03:16,235 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1229)
2015-04-26 13:03:16,235 DEBUG [VideoDAOImpl] Reading a Video (id = 1229)
2015-04-26 13:03:16,236 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1229, format MATROSKA and profile Samsung TV (B-series)
2015-04-26 13:03:16,236 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1229 (local)
2015-04-26 13:03:16,236 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1229)
2015-04-26 13:03:16,236 DEBUG [VideoDAOImpl] Reading a Video (id = 1229)
2015-04-26 13:03:16,236 DEBUG [VideoDeliveryEngine] Delivering item '1229' for client 'Identifier=192.168.254.50, Profile=Samsung TV (B-series)'
2015-04-26 13:03:16,237 DEBUG [VideoDeliveryEngine] Delivering file 'Rio (Рио) 2011 1080р.mkv' in native format
2015-04-26 13:03:16,237 DEBUG [MediaItemDAOImpl] Getting file of media item 1229
2015-04-26 13:03:16,237 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 1229) as read
2015-04-26 13:03:16,252 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2015-04-26 13:03:16,252 DEBUG [GETMethodProcessor] Stream entity has length: 4747293772
2015-04-26 13:03:16,252 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/x-mkv,Content-Length: 4747293772,Date: Sun, 26 Apr 2015 03:03:16 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/1.4.1.2,Cache-control: no-cache,Content-Range: bytes 4347-4747298118/4747298119,contentFeatures.dlna.org: DLNA.ORG_PN=MATROSKA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*]]
2015-04-26 13:03:16,270 DEBUG [WebServer] I/O error: Connection reset
"Delivering file 'Rio (Рио) 2011 1080р.mkv' in native format"??
How i can check my profile? That file do not match rule for transcoding?
Post Sun Apr 26, 2015 3:26 pm
Sometimes one brand of player has no problem with a file, while another might. This could be why your LG TV can play it while the Samsung can't.
Since the log shows for certain the file is not being transcoded, then I must assume you didn't modify the profile as I mentioned above. No fault of yours, it can be difficult to get yourself to the right place in the profile.
If you are using a text editor that displays line number (such as Notepad ++), the line I'm looking at is #208. This is the very first profile after the initial Generic profile. On line 208, change the line as I mentioned above. The important part is the levelGreaterThan section. Just in case for some reason your line numbers don't match mine, you need the line that says "<Matches container="*" vCodec="h264" profile="high" levelGreaterThan="4.2" />". Change the 4.2 to 4.0.
Remember, the Serviio process must be stopped and restarted. The best way to do this is to reboot the computer. I've been away from Linux for so long I can't remember the easiest way to restart a background process, so a reboot makes sure it's done.
Try this, and then see if its still not transcoding.
Post Sun Apr 26, 2015 10:56 pm
The file has header compression (header stripping). Try removing it - you may then be able to play it natively. See http://wiki.serviio.org/doku.php?id=header_com
serp2002
Post Sun Apr 26, 2015 11:17 pm
i check twice. That's my <transcoding> section of "Samsung TV B series " profile.
           <!-- Transcode all h264 video with HIGH/MAIN > Level 4.1 on MPEG-TS stream with MPEG2VIDEO and ac3 audio transcoding -->
         <Video targetContainer="m2ts" targetVCodec="mpeg2video" targetACodec="ac3" aBitrate="192">
            <Matches container="*" vCodec="h264" profile="high_10" />
            <Matches container="*" vCodec="h264" profile="main" levelGreaterThan="4.0" />
            <!-- transcode MKV with DST/FLAC audio to AC3, remux into mpeg2ts -->
            <!-- transcode H264 MP4 files with LPCM audio -->
            <Video targetContainer="m2ts" targetACodec="ac3">
                <Matches container="matroska" vCodec="h264" aCodec="dca" />
                <Matches container="matroska" vCodec="h264" aCodec="dts-hd" />
                <Matches container="mp4" vCodec="h264" aCodec="lpcm" />
                <Matches container="mpegts" vCodec="h264" aCodec="truehd" />
                <Matches container="matroska" vCodec="vc1" />
                <Matches container="mpegts" aCodec="mp2" />
                <Matches container="ogg" vCodec="mpeg4" />
                <Matches container="3gp" aCodec="amrnb" />
                <Matches container="wtv" vCodec="h264" />
            <!-- transcode unsupported codec/container combinations into mpeg2ts -->
            <Video targetContainer="m2ts" targetACodec="ac3" targetVCodec="mpeg2video">
                <Matches container="asf" vCodec="wmv2" />
                <Matches container="mp4" vCodec="dvvideo" />
                <Matches container="flv" />
                <Matches container="ogg" />
                <Matches container="rm" />
            <!-- For dvr-ms files force mpeg2video transcoding to fix monotone timestamps problems-->
            <Video targetContainer="m2ts" targetACodec="ac3" forceVTranscoding="true">
                <Matches container="asf" vCodec="mpeg2video" />
                <Matches container="asf" vCodec="mpeg1video" />
            <Video targetContainer="m2ts">
                <Matches container="wtv" />
            <!-- transcode audio only for wmv with wmapro -->
            <Video targetContainer="asf" targetACodec="ac3" aBitrate="256">
                <Matches container="asf" aCodec="wmapro" />
                <Matches container="asf" />
                <Matches container="mp4" />
                <Matches container="flac" />
                <Matches container="adts" />
                <Matches container="mp2" />
                <Matches container="wavpack" />
                <Matches container="mpc" />
                 <Matches container="ape" />
            </Audio>
Post Mon Apr 27, 2015 12:37 pm
OK, your profile looks good. Not sure why it isn't being transcoded.
Give DenyAll's suggestion a try. He knows his stuff about internal file structures. :D
serp2002
Post Fri May 01, 2015 4:48 am
thank you for all who helps. Mkvmerge is solve my problem.
Tinanana1122
Post Sat May 30, 2015 2:10 am
My (mid-level 2011 46" Smart) Samsung is having some difficulties as well w/ the .mkv, although it is able to locate, access, & playback that encoding via the HDD USB specific hub on the lower right side. (When facing the TV) As I purchased this TV 2nd Hand via Craigslist 16 months ago I did not receive any of the manuals/documentation upon purchase, but I did extensive research prior to purchase & this was actually the 1st time to try either HDD &/or .mkv since purchase. The "AllShare" software started up immed. upon insertion of a bus powered Seagate GoFlex 1TB HDD. custodiasamsung
Post Sat May 30, 2015 3:36 am
Not all MKV's are created equally. Please post MediaInfo details for the file that is not playing. Does it play other types of video via Serviio (eg. MP4's. other MKV's?).
Users browsing this forum: Baidu [Spider], Google [Bot] and 11 guests
