Playback hangs after pausing
Does anybody know how to fix this?
Using a Samsung H6400 on LAN. Using generic DLNA profile as a Samsung H series is not listed.
143brian wrote:I found that fault happened when my desk top display entered standby.I set my desktop to pemanent display.Now all movies ok.Worked for me..
143brian wrote:Sry,desktop is still on,but black screen on moniter....i set my display to never switch off,instead off ,switch off after 1hr 30 mins
wnorthrup wrote:143brian wrote:Sry,desktop is still on,but black screen on moniter....i set my display to never switch off,instead off ,switch off after 1hr 30 mins
Thanks. Worth a shot.
zip wrote:Log looks normal. It's a pretty huge file (13GB), I see the request for the remainder of the file (assuming after the un-pause) and then later the TV closes the connection. Not sure why, but there is nothing in the log suggesting it's to do with the server.
Could be network quality (high bandwidth needed for these large files), the TV firmware not coping....
Users browsing this forum: Google [Bot] and 35 guests
