Can I set a transcoding bitrate threshold?
ami289
Post Sat Aug 15, 2015 9:12 am
Hey guys,
I'm kinda newbie to this whole transcoding thing, and am not a native english speaker so I'll try my best to be as clear as I can.
Here is a little background to my problem,
It may be kind of long, but will give you a better understanding of my issue, so perhaps you, the more experienced guys, will have suggestions for me that will resolve my issue, but in another way than what I'm asking for.
My cable company is also my ISP, so my cables receiver is also my router.
It has a built-in DLNA client feature (not sure what the correct term is, but I mean that if I set my PC as a DLNA server, I can connect, and watch videos, using my cables receiver's interface).
My computer (the DLNA server) connected to the router/cables receiver (DLNA client) directly with ethernet cable.
Both ports, on my PC and my router/cables receiver, and ethernet cable, are capable of 1GBit/sec.
Everything was working great for a while without transcoding,
But recently I've got my hands on several remuxed mkv's.
Those remuxed mkv's playback was really choppy, both the audio and the video, and after reading on the internet and on those forums I've encountered posts of people mentioning that DLNA have a maximum bitrate limit that it can handle,
Hence the use of transcoding.
Now all the videos are playing great, but I have several 'side-effects' of using transcoding.
First- now all subtitles are out of sync.
For all movies, subtitles appear about 1 second before the audio and video.
Second- Current playback time, and total playback time are always 00:00, instead of showing actual times,
Third- Which I'm guessing is, to some extent, related to the issue above, I've lost the ability to fast forward/backward.
Out of around 80 mkv's, I only have about 5 mkv's that needs to be transcoded,
And after a quick look at several of the mkv's infos, it seems that the video bitrate is the only way I can differentiate between them.
So currently I can either disable transcoding, and loose the ability to watch those 5 remuxed mkv's (maybe will be more in the future), or continue transcoding, and 'suffer' from the issues mentioned above for all of the videos.
Is there a way I can set some sort of bitrate threshold, that transcoding will only happen for mkv's with higher bitrate than this threshold?
Thanks in advance guys.
Post Sat Aug 15, 2015 1:25 pm
Re: Can I set a transcoding bitrate threshold?
You should post the ffmpeg output for both types of mkv's. You should also post what serviio profile you are using for your DLNA router. Finally you should set DEBUG on and post the part of the log that shows when you play and transcode the problem mkv.
This will provide the info needed to help you, rather than us trying to guess what is happening.
ami289
Post Sat Aug 15, 2015 5:40 pm
Hi jhb50,
Here is my transcoding profile-
<Profile id="mkvcustombitrate" name="MKV Transcoding (Bitrate)" extendsProfileId="1">
      <Detection>
         <UPnPSearch>
            <ModelName>Sagemcom STB</ModelName>
         </UPnPSearch>
           </Detection>
      <DeviceDescription>
         <FriendlyName>PC</FriendlyName>
         <ModelName>HOT FiberBox</ModelName>
      </DeviceDescription>
      <!-- Transcode MKV's -->
         <Video targetContainer="mpegts" targetVCodec="mpeg2video" maxVBitrate="20000" targetACodec="ac3" forceInheritance="true">
      <!-- AVI Support -->
         <Video targetContainer="mpegts" forceInheritance="true">
            <Matches container="avi" />
Here are 2 ffmpeg outputs, received by using the -i flag:
This is the output for one remuxed video, that without transcoding video and audio are stuttering-
ffmpeg version 2.4.git Copyright (c) 2000-2014 the FFmpeg developers
  built on Nov 19 2014 22:12:09 with gcc 4.7.2 (GCC)
  configuration: --enable-static --disable-shared --disable-ffplay --disable-ffserver --enable-memalign-hack --enable-libmp3lame --enable-libass --enable-librtmp --enable-fontconfig --enable-libfreetype --enable-zlib --enable-libx264 --enable-libspeex --extra-libs='-lrtmp -lpolarssl -lws2_32 -lwinmm -lexpat -lfreetype-lfribidi -lz' --arch=x86 --enable-runtime-cpudetect --enable-pthreads --target-os=mingw32 --cross-prefix=i686-w64-mingw32- --enable-gpl --pkg-config=pkg-config
  libavutil      54. 14.100 / 54. 14.100
  libavcodec     56. 12.101 / 56. 12.101
  libavformat    56. 14.100 / 56. 14.100
  libavdevice    56.  3.100 / 56.  3.100
  libavfilter     5.  2.103 /  5.  2.103
  libswscale      3.  1.101 /  3.  1.101
  libswresample   1.  1.100 /  1.  1.100
  libpostproc    53.  3.100 / 53.  3.100
[matroska,webm @ 01E0F760] Could not find codec parameters for stream 2 (Subtitle: hdmv_pgs_subtitle): unspecified size
Consider increasing the value for the 'analyzeduration' and 'probesize' options
Input #0, matroska,webm, from 'k:\Last Action Hero 1993-UHD.mkv':
    encoder         : libebml v1.3.0 + libmatroska v1.4.1
    creation_time   : 2015-04-09 08:12:49
  Duration: 02:10:54.85, start: 0.000000, bitrate: 31246 kb/s
    Chapter #0:0: start 0.000000, end 533.866667
      title           : Introduction
    Chapter #0:1: start 533.866667, end 893.767867
      title           : Start
    Chapter #0:2: start 893.767867, end 1350.015333
      title           : Focus
    Chapter #0:3: start 1350.015333, end 1832.121956
      title           : First Action Hero
    Chapter #0:4: start 1832.121956, end 2524.647111
      title           : Wyle E. Coyote
    Chapter #0:5: start 2524.647111, end 2894.975400
      title           : Tough Guys and Handcuffs
    Chapter #0:6: start 2894.975400, end 3178.633778
      title           : Precinct Reality
    Chapter #0:7: start 3178.633778, end 3397.602533
      title           : A Preview, a Passport and a Warning
    Chapter #0:8: start 3397.602533, end 4024.895867
      title           : Jack Slater Iv
    Chapter #0:9: start 4024.895867, end 4416.537111
      title           : An Eye for Evil
    Chapter #0:10: start 4416.537111, end 4820.941111
      title           : Sicilian Funeral Arrangements
    Chapter #0:11: start 4820.941111, end 5054.591200
      title           : Frank's Farewell and Tony's Hello
    Chapter #0:12: start 5054.591200, end 6047.666622
      title           : Bonneville, Desert Eagle, and a Dynamite Drive-By
    Chapter #0:13: start 6047.666622, end 6435.095333
      title           : "Close Your Eyes, Stay Flat, and Don't Move."
    Chapter #0:14: start 6435.095333, end 6963.831867
      title           : No Hand, New Tunes
    Chapter #0:15: start 6963.831867, end 7854.848000
      title           : Playing Chicken
    Stream #0:0(eng): Video: h264 (High), yuv420p, 1920x1080 [SAR 1:1 DAR 16:9], 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default)
    Stream #0:1(eng): Audio: dts (DTS-HD MA), 48000 Hz, 5.1(side), fltp, 1536 kb/s (default)
    Stream #0:2(eng): Subtitle: hdmv_pgs_subtitle (default)
And this is the output for a 'standard' mkv file, that works perfectly without any transcoding-
Input #0, matroska,webm, from 'k:\Cinderella.2015.1080p.BluRay.x264-SPARKS\Cinderella.2015.1080p.BluRay.x264-SPARKS.mkv':
    encoder         : libebml v1.3.0 + libmatroska v1.4.0
    creation_time   : 2015-06-18 11:37:05
  Duration: 01:45:22.07, start: 0.000000, bitrate: 10399 kb/s
    Chapter #0:0: start 0.000000, end 395.437000
      title           : 00:00:00.000
    Chapter #0:1: start 395.437000, end 838.588000
      title           : 00:06:35.437
    Chapter #0:2: start 838.588000, end 1076.117000
      title           : 00:13:58.588
    Chapter #0:3: start 1076.117000, end 1325.574000
      title           : 00:17:56.117
    Chapter #0:4: start 1325.574000, end 1596.762000
      title           : 00:22:05.574
    Chapter #0:5: start 1596.762000, end 1877.876000
      title           : 00:26:36.762
    Chapter #0:6: start 1877.876000, end 2077.701000
      title           : 00:31:17.876
    Chapter #0:7: start 2077.701000, end 2319.400000
      title           : 00:34:37.701
    Chapter #0:8: start 2319.400000, end 2574.697000
      title           : 00:38:39.400
    Chapter #0:9: start 2574.697000, end 3172.753000
      title           : 00:42:54.697
    Chapter #0:10: start 3172.753000, end 3793.957000
      title           : 00:52:52.753
    Chapter #0:11: start 3793.957000, end 4254.667000
      title           : 01:03:13.957
    Chapter #0:12: start 4254.667000, end 4606.352000
      title           : 01:10:54.667
    Chapter #0:13: start 4606.352000, end 4841.754000
      title           : 01:16:46.352
    Chapter #0:14: start 4841.754000, end 5136.089000
      title           : 01:20:41.754
    Chapter #0:15: start 5136.089000, end 5307.177000
      title           : 01:25:36.089
    Chapter #0:16: start 5307.177000, end 5951.529000
      title           : 01:28:27.177
    Chapter #0:17: start 5951.529000, end 6322.070000
      title           : 01:39:11.529
    Stream #0:0(eng): Video: h264 (High), yuv420p, 1920x808, SAR 1:1 DAR 240:101, 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default)
    Stream #0:1(eng): Audio: dts (DTS), 48000 Hz, 5.1(side), fltp, 1536 kb/s (default)
And here is the serviio log from when starting to play the video-
There seems to be a lot of duplicates, but this is the whole log that was generated after selecting the file for playback
2015-08-15 20:33:59,120 DEBUG [ServiioHttpService] Incoming request from /192.168.1.2:57620: GET /resource/1008/MEDIA_ITEM/MPEG_TS_SD_EU_ISO-0/ORIGINAL HTTP/1.1, headers = [User-Agent: SAGEMCOM/2.0,Host: 192.168.1.22:8895,Accept: */*]]
2015-08-15 20:33:59,120 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.2
2015-08-15 20:33:59,123 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.2
2015-08-15 20:33:59,123 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.2, Profile=MKV Transcoding (Bitrate)'
2015-08-15 20:33:59,124 DEBUG [ResourceDeliveryProcessor] Request for resource 1008 and type 'MEDIA_ITEM' received
2015-08-15 20:33:59,124 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1008 (local)
2015-08-15 20:33:59,124 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1008)
2015-08-15 20:33:59,124 DEBUG [VideoDAOImpl] Reading a Video (id = 1008)
2015-08-15 20:33:59,125 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1008, format MPEG_TS_SD_EU_ISO and profile MKV Transcoding (Bitrate)
2015-08-15 20:33:59,125 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file Last Action Hero 1993-UHD.mkv
2015-08-15 20:33:59,125 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "Last Action Hero 1993-UHD.mkv": MPEG_TS_SD_EU_ISO
2015-08-15 20:33:59,125 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "Last Action Hero 1993-UHD.mkv": MPEG_TS_SD_NA_ISO
2015-08-15 20:33:59,125 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "Last Action Hero 1993-UHD.mkv": MPEG_TS_SD_KO_ISO
2015-08-15 20:33:59,125 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1008 (local)
2015-08-15 20:33:59,125 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1008)
2015-08-15 20:33:59,125 DEBUG [VideoDAOImpl] Reading a Video (id = 1008)
2015-08-15 20:33:59,126 DEBUG [VideoDeliveryEngine] Delivering item '1008' for client 'Identifier=192.168.1.2, Profile=MKV Transcoding (Bitrate)'
2015-08-15 20:33:59,126 DEBUG [VideoDeliveryEngine] Delivering file 'Last Action Hero 1993-UHD.mkv' using transcoding
2015-08-15 20:33:59,126 DEBUG [AbstractTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'Identifier=192.168.1.2, Profile=MKV Transcoding (Bitrate)'
2015-08-15 20:33:59,127 DEBUG [FileBasedTranscodingDeliveryStrategy] Sending transcoding stream
2015-08-15 20:33:59,127 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "Last Action Hero 1993-UHD.mkv": MPEG_TS_SD_EU_ISO
2015-08-15 20:33:59,127 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "Last Action Hero 1993-UHD.mkv": MPEG_TS_SD_NA_ISO
2015-08-15 20:33:59,127 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "Last Action Hero 1993-UHD.mkv": MPEG_TS_SD_KO_ISO
2015-08-15 20:33:59,127 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 1008) as read
2015-08-15 20:33:59,128 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:33:59,132 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2015-08-15 20:33:59,132 DEBUG [GETMethodProcessor] Stream entity has length: 50000000000
2015-08-15 20:33:59,132 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2015-08-15 20:33:59,132 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Cache-control: no-cache,Connection: close,Date: Sat, 15 Aug 2015 17:33:59 GMT,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.5.2,transferMode.dlna.org: Streaming]]
2015-08-15 20:33:59,138 DEBUG [ServiioHttpService] Incoming request from /192.168.1.2:57621: HEAD /resource/1008/MEDIA_ITEM/MPEG_TS_SD_EU_ISO-0/ORIGINAL HTTP/1.0, headers = [Host: 192.168.1.22:8895,Accept: */*]]
2015-08-15 20:33:59,138 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.2
2015-08-15 20:33:59,139 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.2
2015-08-15 20:33:59,140 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.2, Profile=MKV Transcoding (Bitrate)'
2015-08-15 20:33:59,140 DEBUG [ResourceDeliveryProcessor] Request for resource 1008 and type 'MEDIA_ITEM' received
2015-08-15 20:33:59,140 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1008 (local)
2015-08-15 20:33:59,140 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1008)
2015-08-15 20:33:59,141 DEBUG [VideoDAOImpl] Reading a Video (id = 1008)
2015-08-15 20:33:59,141 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1008, format MPEG_TS_SD_EU_ISO and profile MKV Transcoding (Bitrate)
2015-08-15 20:33:59,141 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file Last Action Hero 1993-UHD.mkv
2015-08-15 20:33:59,141 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "Last Action Hero 1993-UHD.mkv": MPEG_TS_SD_EU_ISO
2015-08-15 20:33:59,141 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "Last Action Hero 1993-UHD.mkv": MPEG_TS_SD_NA_ISO
2015-08-15 20:33:59,142 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "Last Action Hero 1993-UHD.mkv": MPEG_TS_SD_KO_ISO
2015-08-15 20:33:59,142 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Length: 50000000000,Content-Type: video/mpeg,Cache-control: no-cache,Connection: close,Date: Sat, 15 Aug 2015 17:33:59 GMT,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.5.2,transferMode.dlna.org: Streaming]]
2015-08-15 20:33:59,144 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2015-08-15 20:33:59,149 DEBUG [ServiioHttpService] Incoming request from /192.168.1.2:57622: GET /resource/1008/MEDIA_ITEM/MPEG_TS_SD_EU_ISO-0/ORIGINAL HTTP/1.1, headers = [User-Agent: SAGEMCOM/2.0,Host: 192.168.1.22:8895,Accept: */*]]
2015-08-15 20:33:59,149 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.2
2015-08-15 20:33:59,150 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.2
2015-08-15 20:33:59,150 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.2, Profile=MKV Transcoding (Bitrate)'
2015-08-15 20:33:59,150 DEBUG [ResourceDeliveryProcessor] Request for resource 1008 and type 'MEDIA_ITEM' received
2015-08-15 20:33:59,150 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1008 (local)
2015-08-15 20:33:59,150 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1008)
2015-08-15 20:33:59,151 DEBUG [VideoDAOImpl] Reading a Video (id = 1008)
2015-08-15 20:33:59,153 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1008, format MPEG_TS_SD_EU_ISO and profile MKV Transcoding (Bitrate)
2015-08-15 20:33:59,161 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file Last Action Hero 1993-UHD.mkv
2015-08-15 20:33:59,162 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "Last Action Hero 1993-UHD.mkv": MPEG_TS_SD_EU_ISO
2015-08-15 20:33:59,162 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "Last Action Hero 1993-UHD.mkv": MPEG_TS_SD_NA_ISO
2015-08-15 20:33:59,162 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "Last Action Hero 1993-UHD.mkv": MPEG_TS_SD_KO_ISO
2015-08-15 20:33:59,162 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1008 (local)
2015-08-15 20:33:59,162 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1008)
2015-08-15 20:33:59,163 DEBUG [VideoDAOImpl] Reading a Video (id = 1008)
2015-08-15 20:33:59,163 DEBUG [VideoDeliveryEngine] Delivering item '1008' for client 'Identifier=192.168.1.2, Profile=MKV Transcoding (Bitrate)'
2015-08-15 20:33:59,163 DEBUG [VideoDeliveryEngine] Delivering file 'Last Action Hero 1993-UHD.mkv' using transcoding
2015-08-15 20:33:59,163 DEBUG [AbstractTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'Identifier=192.168.1.2, Profile=MKV Transcoding (Bitrate)'
2015-08-15 20:33:59,164 DEBUG [FileBasedTranscodingDeliveryStrategy] Sending transcoding stream
2015-08-15 20:33:59,164 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "Last Action Hero 1993-UHD.mkv": MPEG_TS_SD_EU_ISO
2015-08-15 20:33:59,164 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "Last Action Hero 1993-UHD.mkv": MPEG_TS_SD_NA_ISO
2015-08-15 20:33:59,164 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "Last Action Hero 1993-UHD.mkv": MPEG_TS_SD_KO_ISO
2015-08-15 20:33:59,164 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 1008) as read
2015-08-15 20:33:59,168 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2015-08-15 20:33:59,168 DEBUG [GETMethodProcessor] Stream entity has length: 50000000000
2015-08-15 20:33:59,168 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2015-08-15 20:33:59,168 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Cache-control: no-cache,Connection: close,Date: Sat, 15 Aug 2015 17:33:59 GMT,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.5.2,transferMode.dlna.org: Streaming]]
2015-08-15 20:33:59,170 DEBUG [WebServer] I/O error: Connection reset by peer: socket write error
2015-08-15 20:33:59,172 DEBUG [ServiioHttpService] Incoming request from /192.168.1.2:57623: GET /resource/1008/MEDIA_ITEM/MPEG_TS_SD_EU_ISO-0/ORIGINAL HTTP/1.1, headers = [User-Agent: SAGEMCOM/2.0,Host: 192.168.1.22:8895,Accept: */*]]
2015-08-15 20:33:59,172 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.2
2015-08-15 20:33:59,175 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.2
2015-08-15 20:33:59,179 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.2, Profile=MKV Transcoding (Bitrate)'
2015-08-15 20:33:59,179 DEBUG [ResourceDeliveryProcessor] Request for resource 1008 and type 'MEDIA_ITEM' received
2015-08-15 20:33:59,179 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1008 (local)
2015-08-15 20:33:59,179 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1008)
2015-08-15 20:33:59,179 DEBUG [VideoDAOImpl] Reading a Video (id = 1008)
2015-08-15 20:33:59,180 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1008, format MPEG_TS_SD_EU_ISO and profile MKV Transcoding (Bitrate)
2015-08-15 20:33:59,180 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file Last Action Hero 1993-UHD.mkv
2015-08-15 20:33:59,180 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "Last Action Hero 1993-UHD.mkv": MPEG_TS_SD_EU_ISO
2015-08-15 20:33:59,180 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "Last Action Hero 1993-UHD.mkv": MPEG_TS_SD_NA_ISO
2015-08-15 20:33:59,180 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "Last Action Hero 1993-UHD.mkv": MPEG_TS_SD_KO_ISO
2015-08-15 20:33:59,180 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1008 (local)
2015-08-15 20:33:59,180 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1008)
2015-08-15 20:33:59,180 DEBUG [VideoDAOImpl] Reading a Video (id = 1008)
2015-08-15 20:33:59,181 DEBUG [VideoDeliveryEngine] Delivering item '1008' for client 'Identifier=192.168.1.2, Profile=MKV Transcoding (Bitrate)'
2015-08-15 20:33:59,181 DEBUG [VideoDeliveryEngine] Delivering file 'Last Action Hero 1993-UHD.mkv' using transcoding
2015-08-15 20:33:59,181 DEBUG [AbstractTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'Identifier=192.168.1.2, Profile=MKV Transcoding (Bitrate)'
2015-08-15 20:33:59,182 DEBUG [FileBasedTranscodingDeliveryStrategy] Sending transcoding stream
2015-08-15 20:33:59,182 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "Last Action Hero 1993-UHD.mkv": MPEG_TS_SD_EU_ISO
2015-08-15 20:33:59,182 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "Last Action Hero 1993-UHD.mkv": MPEG_TS_SD_NA_ISO
2015-08-15 20:33:59,182 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "Last Action Hero 1993-UHD.mkv": MPEG_TS_SD_KO_ISO
2015-08-15 20:33:59,182 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 1008) as read
2015-08-15 20:33:59,183 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2015-08-15 20:33:59,183 DEBUG [GETMethodProcessor] Stream entity has length: 50000000000
2015-08-15 20:33:59,183 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2015-08-15 20:33:59,184 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Cache-control: no-cache,Connection: close,Date: Sat, 15 Aug 2015 17:33:59 GMT,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.5.2,transferMode.dlna.org: Streaming]]
2015-08-15 20:33:59,201 DEBUG [WebServer] I/O error: Software caused connection abort: socket write error
2015-08-15 20:33:59,208 DEBUG [ServiioHttpService] Incoming request from /192.168.1.2:57624: GET /resource/1008/MEDIA_ITEM/MPEG_TS_SD_EU_ISO-0/ORIGINAL HTTP/1.1, headers = [Range: bytes=49999999624-,User-Agent: SAGEMCOM/2.0,Host: 192.168.1.22:8895,Accept: */*]]
2015-08-15 20:33:59,208 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.2
2015-08-15 20:33:59,209 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.2, Profile=MKV Transcoding (Bitrate)'
2015-08-15 20:33:59,209 DEBUG [ResourceDeliveryProcessor] Request for resource 1008 and type 'MEDIA_ITEM' received
2015-08-15 20:33:59,209 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1008 (local)
2015-08-15 20:33:59,209 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1008)
2015-08-15 20:33:59,209 DEBUG [VideoDAOImpl] Reading a Video (id = 1008)
2015-08-15 20:33:59,209 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1008, format MPEG_TS_SD_EU_ISO and profile MKV Transcoding (Bitrate)
2015-08-15 20:33:59,209 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file Last Action Hero 1993-UHD.mkv
2015-08-15 20:33:59,209 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "Last Action Hero 1993-UHD.mkv": MPEG_TS_SD_EU_ISO
2015-08-15 20:33:59,209 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "Last Action Hero 1993-UHD.mkv": MPEG_TS_SD_NA_ISO
2015-08-15 20:33:59,209 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "Last Action Hero 1993-UHD.mkv": MPEG_TS_SD_KO_ISO
2015-08-15 20:33:59,210 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1008 (local)
2015-08-15 20:33:59,210 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1008)
2015-08-15 20:33:59,210 DEBUG [VideoDAOImpl] Reading a Video (id = 1008)
2015-08-15 20:33:59,210 DEBUG [VideoDeliveryEngine] Delivering item '1008' for client 'Identifier=192.168.1.2, Profile=MKV Transcoding (Bitrate)'
2015-08-15 20:33:59,210 DEBUG [VideoDeliveryEngine] Delivering file 'Last Action Hero 1993-UHD.mkv' using transcoding
2015-08-15 20:33:59,210 DEBUG [AbstractTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'Identifier=192.168.1.2, Profile=MKV Transcoding (Bitrate)'
2015-08-15 20:33:59,210 DEBUG [FileBasedTranscodingDeliveryStrategy] Sending transcoding stream
2015-08-15 20:33:59,211 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "Last Action Hero 1993-UHD.mkv": MPEG_TS_SD_EU_ISO
2015-08-15 20:33:59,211 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "Last Action Hero 1993-UHD.mkv": MPEG_TS_SD_NA_ISO
2015-08-15 20:33:59,211 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "Last Action Hero 1993-UHD.mkv": MPEG_TS_SD_KO_ISO
2015-08-15 20:33:59,211 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 1008) as read
2015-08-15 20:33:59,212 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2015-08-15 20:33:59,212 DEBUG [GETMethodProcessor] Stream entity has length: 376
2015-08-15 20:33:59,212 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2015-08-15 20:33:59,212 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/mpeg,Cache-control: no-cache,Connection: close,Content-Range: bytes 49999999624-49999999999/50000000000,Date: Sat, 15 Aug 2015 17:33:59 GMT,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.5.2,transferMode.dlna.org: Streaming]]
2015-08-15 20:33:59,228 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:33:59,330 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:33:59,432 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:33:59,535 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:33:59,637 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:33:59,740 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:01,584 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:01,697 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:01,792 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:01,988 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:02,091 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:02,193 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:02,302 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:02,398 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:02,500 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:02,602 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:02,704 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:02,806 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:02,908 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:03,010 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:03,113 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:03,215 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:03,318 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:03,420 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:03,522 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:03,625 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:03,727 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:03,830 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:03,931 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:04,033 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:04,136 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:04,238 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:04,341 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:04,442 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:04,546 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:04,648 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:04,650 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:04,750 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:04,751 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:04,852 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:04,854 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:04,955 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:04,956 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:05,057 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:05,058 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:05,159 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:05,161 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:05,262 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:05,263 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:05,365 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:05,466 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:05,467 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:05,568 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:05,570 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:05,671 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:05,773 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:05,774 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:05,875 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:05,876 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:05,977 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:05,978 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:06,080 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:06,182 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:06,284 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:06,285 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:06,386 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:06,387 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:06,489 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:06,490 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:06,591 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:06,693 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:06,694 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:06,795 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:06,796 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:06,897 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:06,898 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:07,000 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:07,001 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:07,102 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:07,205 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:07,306 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:07,307 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:07,409 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:07,410 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:07,511 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:07,512 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:07,615 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:07,616 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:07,717 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:07,718 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:07,818 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:07,921 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:08,022 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:08,023 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:08,125 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:08,127 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:08,227 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:08,228 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:08,329 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:08,331 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:08,431 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:08,433 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:08,534 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:08,535 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:08,636 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:08,637 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:08,738 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:08,739 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:08,840 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:08,841 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:08,943 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:08,944 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:09,045 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:09,046 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:09,148 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:09,149 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:09,250 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:09,252 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
2015-08-15 20:34:09,333 DEBUG [ServiioHttpService] Incoming request from /192.168.1.2:57626: GET /resource/1008/MEDIA_ITEM/MPEG_TS_SD_EU_ISO-0/ORIGINAL HTTP/1.1, headers = [User-Agent: SAGEMCOM/2.0,Host: 192.168.1.22:8895,Accept: */*]]
2015-08-15 20:34:09,333 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.2
2015-08-15 20:34:09,334 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.2
2015-08-15 20:34:09,334 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.2, Profile=MKV Transcoding (Bitrate)'
2015-08-15 20:34:09,334 DEBUG [ResourceDeliveryProcessor] Request for resource 1008 and type 'MEDIA_ITEM' received
2015-08-15 20:34:09,334 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1008 (local)
2015-08-15 20:34:09,334 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1008)
2015-08-15 20:34:09,335 DEBUG [VideoDAOImpl] Reading a Video (id = 1008)
2015-08-15 20:34:09,335 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1008, format MPEG_TS_SD_EU_ISO and profile MKV Transcoding (Bitrate)
2015-08-15 20:34:09,335 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file Last Action Hero 1993-UHD.mkv
2015-08-15 20:34:09,335 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "Last Action Hero 1993-UHD.mkv": MPEG_TS_SD_EU_ISO
2015-08-15 20:34:09,335 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "Last Action Hero 1993-UHD.mkv": MPEG_TS_SD_NA_ISO
2015-08-15 20:34:09,335 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "Last Action Hero 1993-UHD.mkv": MPEG_TS_SD_KO_ISO
2015-08-15 20:34:09,335 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1008 (local)
2015-08-15 20:34:09,336 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1008)
2015-08-15 20:34:09,336 DEBUG [VideoDAOImpl] Reading a Video (id = 1008)
2015-08-15 20:34:09,336 DEBUG [VideoDeliveryEngine] Delivering item '1008' for client 'Identifier=192.168.1.2, Profile=MKV Transcoding (Bitrate)'
2015-08-15 20:34:09,336 DEBUG [VideoDeliveryEngine] Delivering file 'Last Action Hero 1993-UHD.mkv' using transcoding
2015-08-15 20:34:09,336 DEBUG [AbstractTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'Identifier=192.168.1.2, Profile=MKV Transcoding (Bitrate)'
2015-08-15 20:34:09,337 DEBUG [FileBasedTranscodingDeliveryStrategy] Sending transcoding stream
2015-08-15 20:34:09,337 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "Last Action Hero 1993-UHD.mkv": MPEG_TS_SD_EU_ISO
2015-08-15 20:34:09,337 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "Last Action Hero 1993-UHD.mkv": MPEG_TS_SD_NA_ISO
2015-08-15 20:34:09,337 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "Last Action Hero 1993-UHD.mkv": MPEG_TS_SD_KO_ISO
2015-08-15 20:34:09,337 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 1008) as read
2015-08-15 20:34:09,338 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2015-08-15 20:34:09,338 DEBUG [GETMethodProcessor] Stream entity has length: 50000000000
2015-08-15 20:34:09,338 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2015-08-15 20:34:09,338 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Cache-control: no-cache,Connection: close,Date: Sat, 15 Aug 2015 17:34:09 GMT,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.5.2,transferMode.dlna.org: Streaming]]
2015-08-15 20:34:09,343 DEBUG [ServiioHttpService] Incoming request from /192.168.1.2:57627: HEAD /resource/1008/MEDIA_ITEM/MPEG_TS_SD_EU_ISO-0/ORIGINAL HTTP/1.0, headers = [Host: 192.168.1.22:8895,Accept: */*]]
2015-08-15 20:34:09,343 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.2
2015-08-15 20:34:09,344 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.2
2015-08-15 20:34:09,344 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.1.2, Profile=MKV Transcoding (Bitrate)'
2015-08-15 20:34:09,345 DEBUG [ResourceDeliveryProcessor] Request for resource 1008 and type 'MEDIA_ITEM' received
2015-08-15 20:34:09,345 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1008 (local)
2015-08-15 20:34:09,345 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1008)
2015-08-15 20:34:09,345 DEBUG [VideoDAOImpl] Reading a Video (id = 1008)
2015-08-15 20:34:09,346 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1008, format MPEG_TS_SD_EU_ISO and profile MKV Transcoding (Bitrate)
2015-08-15 20:34:09,346 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file Last Action Hero 1993-UHD.mkv
2015-08-15 20:34:09,346 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "Last Action Hero 1993-UHD.mkv": MPEG_TS_SD_EU_ISO
2015-08-15 20:34:09,346 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "Last Action Hero 1993-UHD.mkv": MPEG_TS_SD_NA_ISO
2015-08-15 20:34:09,346 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file "Last Action Hero 1993-UHD.mkv": MPEG_TS_SD_KO_ISO
2015-08-15 20:34:09,346 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Length: 50000000000,Content-Type: video/mpeg,Cache-control: no-cache,Connection: close,Date: Sat, 15 Aug 2015 17:34:09 GMT,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/1.5.2,transferMode.dlna.org: Streaming]]
2015-08-15 20:34:09,352 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:InternetGatewayDevice:1 from address /192.168.1.23:61273s
Cheers
Post Sun Aug 16, 2015 2:29 am
Nothing obvious there.
There are lots of posts regarding stuttering. Search with "stutter". Some clients cannot handle high bit rates. You can test your files for their max bit rate using a bit rate viewer to see if that's the problem. Second possibility is that their level is too high ie: > 4.1 You can check this with h264info. And just transcode them. More in the wiki on this.
I have no idea why your subs go out of sync when transcoding. Note that your log does not show the transcode because the transcoded file (.stf) was previously created and is being reused. You need to manually delete it and play it again. That will then show you the generated ffmpeg transcode command in the log. You can then run that manually to see if there is any delay in the transcoding that would account for the bad sync. Finally you can rename it from .stf to .mpg rather than delete it and then you can test it with your subtitles to see if the sync exists when playing on the PC.
Best I can do for you.
ami289
Post Sun Aug 16, 2015 4:57 am
Hi jhb50,
Appreciate your reply,
After deleting the stf file, I've get this call to ffmpeg-
2015-08-16 07:49:00,059 DEBUG [FFMPEGWrapper] Invoking FFmpeg to transcode video file: K:\Last Action Hero 1993-UHD.mkv
2015-08-16 07:49:00,059 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\lib\ffmpeg.exe -threads auto -i K:\MyPack\Last Action Hero 1993-UHD.mkv -y -threads auto -c:v mpeg2video -pix_fmt yuv420p -b:v 20000k -maxrate:v 20000k -bufsize:v 20000k -r 24000/1001 -g 15 -c:a ac3 -b:a 192k -ac 2 -map 0:0 -map 0:1 -sn -f mpegts C:\Windows\TEMP\Serviio\transcoding-temp-1008-mkvcustombitrate-ORIGINAL.stf
Sorry if I wasn't clear enough, but as I've mentioned, I'm not an native english speaker.
As I mentioned in my original post-
I already know the reason for the stuttering is the high bitrate, this is why I use transcoding in the first place.
What I want to know is if there is a way I can set my transcoding profile that it will only transcode higher bitrate mkv's.
For instance-
Automatically transcode every mkv that has higher bitrate than 10mbp/s,
But no transcode mkv's that has lower bitrate than 10mbp/s
I don't care to 'suffer' the subtitles sync, and lack of ability to FF/FR if it is only in the 5 remuxed mkv's I have...
Also,
The profile is not the issue, since I have lower bitrates mkv's with level 5 that plays fine without transcoding,
While I have higher bitrates mkv's with level 4 that stutter if I don't transcode.
Any ideas mate?
Cheers
Post Sun Aug 16, 2015 1:29 pm
There is no way for Serviiio to determine if a file has a high peak bitrate prior to playing it or transcoding it.
What you could try is to change the .mkv of the 5 high bitrate videos to a container type you never use and transcode that type to mpeg2.
"container - compulsory; name of container; possible values: * (any), asf (WMV), mpeg (MPEG2PS), mpegts (MPEG2TS), mp4 (MPEG4, MOV), mjpeg, mpegvideo (MPEG1), matroska (MKV), avi, flv, wtv, ogg, 3gp, rtp, rtsp, applehttp, rm (RealMedia)"
ami289
Post Mon Aug 17, 2015 5:14 pm
Hi again jhb50,
I've just tried what you have suggested, about checking for subtitles sync on my pc,
That was extremly weird,
For some reason, after transcoding, VLC can open the file just fine (with either mpg or stf format),
But it does not seem to be able to play the file if I place subtitles in the same folder, or when trying to add the subtitles while playing the video.....
Does changing the video container, as you've suggested, mean to convert the video to a different kind?
Post Tue Aug 18, 2015 1:34 pm
I can't answer about VLC..just Serviio.
What .ext did you use, and did they transcode and your .mkv play native?
Changing the .ext does not change the file and if Serviio looks at the file signature (first few bytes) rather than the .ext then my idea will not work.
ami289
Post Sat Aug 22, 2015 6:17 pm
I didn't expected an answer about VLC,
What I meant by mentioning it is to show, that after serviio transcoding the video file, there is a problem 'attaching' subtitles to it, which could explain the subtitles delay in the playback on my serviio client device (though it does not explain why....),
Renaming the video files did not do the trick....I guess serviio still looks at the file signature, as you've suggested.....
Appreciate the idea and effort to help though....
Any other suggestions I might try mate?
Users browsing this forum: Baidu [Spider], Google [Bot] and 4 guests
