Samsung c7000 Series - Not Showing up on TV
sad_story
Post Thu Mar 03, 2011 1:47 am
I have have tried diligently to go through the forums, but it seems that I cannot find the solution.
I have:
iMac (OSX 10.6.6)
Samsung C7000 (UN55 C7000 WF)
Samsung WiFi Dongle
I have used a few other DLNA servers and the seem to work (as in connect to Samsung). But want to/ try Serviio because of the others programs inability to transcode iTunes purchased content.
I have enclosed the log file and a few screenshots
Sharing
Screen shot 2011-03-02 at 17.36.16.png (95.69 KiB) Viewed 11763 times
Ping Test
Screen shot 2011-03-02 at 17.34.02.png (114.11 KiB) Viewed 11763 times
IP Address
Screen shot 2011-03-02 at 17.32.43.png (132.08 KiB) Viewed 11763 times
sad_story
Post Thu Mar 03, 2011 1:48 am
Re: Samsung c7000 Series - Not Showing up on TC
Continued ...
derby copy.log
Derby Log File
(633 Bytes) Downloaded 842 times
Firewall
Screen shot 2011-03-02 at 17.36.50.png (61.57 KiB) Viewed 11762 times
sad_story
Post Thu Mar 03, 2011 1:52 am
Log File
serviio copy.pdf
Serviio Log File
(77.44 KiB) Downloaded 957 times
Post Thu Mar 03, 2011 9:42 am
Re: Samsung c7000 Series - Not Showing up on TV
Is 10.37.129.2 the IP of your Mac? If not, put the proper one into Bound IP address field in the console.
Also, can you provide ffmpeg -i <file> for Echelon Conspiracy.m4v ?
sad_story
Post Thu Mar 03, 2011 6:34 pm
OK, Not sure what changed the AM, but the Serviio server was viewable from my Samsun c7000.
zip wrote:Is 10.37.129.2 the IP of your Mac? If not, put the proper one into Bound IP address field in the console.
That was done yesterday, sorry forgot to include the screenshot
zip wrote: Also, can you provide ffmpeg -i <file> for Echelon Conspiracy.m4v ?
I think I did this correctly. Here are the results for when I ran the command ffmpeg -i on the file (was I supposed to actually output a file, I got an error at the end "Output file must be specified"
ffmpeg -i results.rtf
results from running ffmpeg -i
(4.76 KiB) Downloaded 714 times
sad_story
Post Thu Mar 03, 2011 6:38 pm
I ran the command again this time naming an output file "test.m4v", included are the results as attachements, the test.m4v file is an empty file
ffmpeg results with output file test.rtf
results w output file test
(4.89 KiB) Downloaded 791 times
Post Fri Mar 04, 2011 11:00 am
that file seems to be DRM protected.. Is that right? In this case FFmpeg cannot get video information and the file is not added to the library. I doubt it would play on the TV anyway. The error message should be fixed though (I'll create a ticket).
thanks.
sad_story
Post Fri Mar 04, 2011 6:48 pm
aha, well, I guess it could be as I downloaded them from iTunes. There are however, other itunes moves/tv series that were downloaded, but seem to work... Odd. I wil have to look into that.
