Sun Aug 30, 2015 6:07 am by tuareg64ve
I repost for reference.
tuareg64ve wrote:Hi all,
I have started to implement a pluging for the above European TV.
The plugin really works when I launch manually.
If I catch the contentUrl string and use it with ffplay I can really display the channel in my Linux Mint 17.2 laptop.
I get the following output:
- Code:
Input #0, flv, from 'rtmp://cp135358.live.edgefcs.net/live/dw_fl_tv-asiaplus_h@s82220?auth=daEb0dTa3a5c5bPdNd0dXdXdNddcrd6drdw-bv4Dlb-b4-oItuoBxDumEDw&aifp=001 playpath=dw_fl_tv-asiaplus_h@s82220?auth=daEb0dTa3a5c5bPdNd0dXdXdNddcrd6drdw-bv4Dlb-b4-oItuoBxDumEDw&aifp=001 swfUrl=http://www.dw.com/js/jwplayer/player.swf swfVfy=1':
Deutsche Welle :
© Deutsche Welle:
description :
keywords :
rating :
Livestream DW-TV EUROPA:
presetname : DWVIDEOENC4A
creationdate : Fri Aug 28 16:00:46 2015
videodevice : Osprey-700 HD Video Device 1
avclevel : 31
avcprofile : 66
videokeyframe_frequency: 5
audiodevice : SDI Input 1 (Osprey-700 HD 1)
audiochannels : 2
audioinputvolume: 95
Duration: N/A, start: 0.000000, bitrate: 1048 kb/s
Stream #0:0: Video: h264 (Baseline), yuv420p(tv), 720x400 [SAR 1:1 DAR 9:5], 1048 kb/s, 25 fps, 25 tbr, 1k tbn, 50 tbc
Stream #0:1: Audio: aac (LC), 44100 Hz, stereo, fltp
3.47 A-V: 0.032 fd= 63 aq= 20KB vq= 172KB sq= 0B f=64/43
In my Samsung TV I get "Format not supported".
The following are the supported format:
- Samsung A formats
- dwlive_scr1.jpg (52.38 KiB) Viewed 45714 times
What do you think?
