Deutsche Welle Live TV plugin implementation started
tuareg64ve
Post Sat Aug 29, 2015 3:58 pm
Hi all,
I am pleased to announce the first version of DWLive pluging for the above European TV.
DWLive.groovy
DWLive plugin
(5.2 KiB) Downloaded 3497 times
You may need to add the following statement to your profile.xml for the profile you are using.
<OnlineTranscoding>
              <Video targetContainer="mpegts" targetVCodec="mpeg2video" maxVBitrate="30000" targetACodec="ac3" aBitrate="384">
</OnlineTranscoding>
let me know your opininions.
stefana888
Post Sat Aug 29, 2015 6:12 pm
Re: Deutsche Welle Live TV plugin implementation started
Online transcode like this, perhaps.
<OnlineTranscoding>
tuareg64ve
Post Sat Aug 29, 2015 9:25 pm
Should I have to put it in the application-profiles.xml file ?
stefana888
Post Sat Aug 29, 2015 9:57 pm
tuareg64ve wrote:Should I have to put it in the application-profiles.xml file ?
Yes. I suppose you have A or B series Samsung. Is the profile already not working?
Post Sat Aug 29, 2015 10:30 pm
No..in profile.xml under the profile for the device you have selected for your TV in the Serviio console
tuareg64ve
Post Sun Aug 30, 2015 5:51 am
I am using Samsung A. The profile is already working for other sources.
I have added the statement above and it works now.
I am very happy for my first serviio plugin! :-)
tuareg64ve
Post Sun Aug 30, 2015 6:07 am
I repost for reference.
tuareg64ve wrote:Hi all,
I have started to implement a pluging for the above European TV.
The plugin really works when I launch manually.
If I catch the contentUrl string and use it with ffplay I can really display the channel in my Linux Mint 17.2 laptop.
I get the following output:
Input #0, flv, from 'rtmp://cp135358.live.edgefcs.net/live/dw_fl_tv-asiaplus_h@s82220?auth=daEb0dTa3a5c5bPdNd0dXdXdNddcrd6drdw-bv4Dlb-b4-oItuoBxDumEDw&aifp=001 playpath=dw_fl_tv-asiaplus_h@s82220?auth=daEb0dTa3a5c5bPdNd0dXdXdNddcrd6drdw-bv4Dlb-b4-oItuoBxDumEDw&aifp=001 swfUrl=http://www.dw.com/js/jwplayer/player.swf swfVfy=1':
    Deutsche Welle  :
    &amp;#169; Deutsche Welle:
    description     :
    keywords        :
    rating          :
    Livestream DW-TV EUROPA:
    presetname      : DWVIDEOENC4A
    creationdate    : Fri Aug 28 16:00:46 2015
    videodevice     : Osprey-700 HD Video Device 1
    avclevel        : 31
    avcprofile      : 66
    videokeyframe_frequency: 5
    audiodevice     : SDI Input 1 (Osprey-700 HD 1)
    audiochannels   : 2
    audioinputvolume: 95
  Duration: N/A, start: 0.000000, bitrate: 1048 kb/s
    Stream #0:0: Video: h264 (Baseline), yuv420p(tv), 720x400 [SAR 1:1 DAR 9:5], 1048 kb/s, 25 fps, 25 tbr, 1k tbn, 50 tbc
    Stream #0:1: Audio: aac (LC), 44100 Hz, stereo, fltp
   3.47 A-V:  0.032 fd=  63 aq=   20KB vq=  172KB sq=    0B f=64/43
In my Samsung TV I get "Format not supported".
The following are the supported format:
Samsung A formats
What do you think?
Return to Plugin development
