Serviio and Synology Ds216play
• Page 1 of 2 • 1, 2
Cant find java and serviio on a repository. Only minecraft and some other crap. It means that my nas doesnt supported? Thanks.
Re: Serviio and Synology Ds216play
For now yes. But hopefully you can help me to get it supported.
Please log in via SSH as root (same password as for admin).
Then post back here with the results of:
Thanks!
Thanks!
Thank you! Here it is:
Synology> cat /proc/cpuinfo
processor : 0
model name : ARMv7 Processor rev 0 (v7l)
BogoMIPS : 2989.26
Features : swp half thumb fastmult vfp edsp neon vfpv3 tls
CPU implementer : 0x41
CPU architecture: 7
CPU variant : 0x3
CPU part : 0xc09
CPU revision : 0
processor : 1
BogoMIPS : 2989.26
CPU architecture: 7
CPU variant : 0x3
CPU part : 0xc09
CPU revision : 0
Hardware : STi SoC with Flattened Device Tree
Revision : 0000
Serial : 0000000000000000
Synology> uname -a
processor : 0
BogoMIPS : 2989.26
CPU architecture: 7
CPU variant : 0x3
CPU part : 0xc09
CPU revision : 0
processor : 1
BogoMIPS : 2989.26
CPU architecture: 7
CPU variant : 0x3
CPU part : 0xc09
CPU revision : 0
Revision : 0000
Synology> uname -a
It looks like you didn't hit return after the second command (uname -a).
patters wrote:It looks like you didn't hit return after the second command (uname -a).
sorry about that
Synology> uname -a
Linux Synology 3.10.35 #5644 SMP Thu Nov 12 17:16:21 CST 2015 armv7l GNU/Linux synology_monaco_ds216play
Can you try this and report the ffmpeg result?
Try to install the Java 8 package now - I've added support for the DS216play. When you look at the Java package log in Package Center do you see the HotSpot version number?
I'm interested to get the hardware transcoding working ASAP on the DS216play. Could you install VideoStation and post back here with the output from:
- Code:
./ffmpeg
ffmpeg version 2.7.1-compiled_by_patters_for_Serviio Copyright (c) 2000-2015 the FFmpeg developers
built with gcc 4.6.4 (crosstool-NG 1.18.0) 20130102 (prerelease)
configuration: --arch=arm --cpu=cortex-a9 --enable-thumb --enable-cross-compile --cross-prefix=/usr/local/arm-cortexa9-linux-gnueabi/bin/arm-cortexa9-linux-gnueabi- --target-os=linux --prefix=/usr/local/arm-cortexa9-linux-gnueabi --enable-shared --disable-static --enable-pic --disable-ffplay --disable-ffserver --disable-debug --enable-pthreads --enable-libmp3lame --enable-librtmp --enable-libass --enable-libspeex --enable-gpl --enable-libx264 --enable-gnutls --pkg-config=pkg-config --extra-version=compiled_by_patters_for_Serviio
libavutil 54. 27.100 / 54. 27.100
libavcodec 56. 41.100 / 56. 41.100
libavformat 56. 36.100 / 56. 36.100
libavdevice 56. 4.100 / 56. 4.100
libavfilter 5. 16.101 / 5. 16.101
libswscale 3. 1.101 / 3. 1.101
libswresample 1. 2.100 / 1. 2.100
libpostproc 53. 3.100 / 53. 3.100
- Code:
/var/packages/VideoStation/target/bin/ffmpeg
ffmpeg version 2.0.2 Copyright (c) 2000-2013 the FFmpeg developers
built on Nov 12 2015 18:48:36 with gcc 4.8.3 (crosstool-NG git+85622fd-dirty) 20140106 (prerelease)
configuration: --prefix=/usr/pkg --incdir='${prefix}/include/ffmpeg' --arch=armv7 --target-os=linux --cross-prefix=/usr/local/arm-cortexa9hf-linux-gnueabi/bin/arm-cortexa9hf-linux-gnueabi- --enable-cross-compile --enable-optimizations --enable-pic --enable-gpl --enable-version3 --enable-nonfree --enable-libfaac --enable-encoders --enable-pthreads --disable-muxer=image2 --disable-muxer=image2pipe --disable-swscale-alpha --disable-ffplay --disable-doc --disable-devices --disable-bzlib --disable-altivec --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libmp3lame --disable-decoder=amrnb --disable-encoder=zmbv --cc=/usr/local/arm-cortexa9hf-linux-gnueabi/bin/arm-cortexa9hf-linux-gnueabi-ccache-gcc --enable-shared --disable-static --disable-encoder=dca --disable-encoder=ac3 --disable-encoder=ac3_fixed --disable-encoder=eac3 --disable-decoder=dca --disable-decoder=eac3 --disable-decoder=truehd --disable-vaapi --enable-libfdk-aac
libavutil 52. 38.100 / 52. 38.100
libavcodec 55. 18.102 / 55. 18.102
libavformat 55. 12.100 / 55. 12.100
libavdevice 55. 3.100 / 55. 3.100
libavfilter 3. 79.101 / 3. 79.101
I managed to get Java 8 installed. Logs show "Java HotSpot(TM) Embedded Client VM (build 25.65-b01, mixed mode)"
Synology> cd /volume1/@tmp
Synology> mkdir ffmpeg
mkdir: can't create directory 'ffmpeg': File exists
Synology> cd ffmpeg
Synology> wget http://packages.pcloadletter.co.uk/down ... eon.tar.xz
--2015-12-15 21:21:47-- http://packages.pcloadletter.co.uk/down ... eon.tar.xz
Resolving packages.pcloadletter.co.uk... 82.147.22.211
Connecting to packages.pcloadletter.co.uk|82.147.22.211|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 6495564 (6.2M) [application/x-tar]
Saving to: 'serviio1.5-native-armhfneon.tar.xz.1'
100%[===================================================================================================================================================================================================>] 6,495,564 907KB/s in 13s
2015-12-15 21:22:00 (497 KB/s) - 'serviio1.5-native-armhfneon.tar.xz.1' saved [6495564/6495564]
Synology> tar xvJf serviio1.5-native-armhfneon.tar.xz
fc-cache
ffmpeg
libass.so.5
libavcodec.so.56
libavdevice.so.56
libavfilter.so.5
libavformat.so.56
libavutil.so.54
libfontconfig.so.1
libfribidi.so.0
libgnutls.so.28
libhogweed.so.2
libnettle.so.4
libpostproc.so.53
librtmp.so.1
libspeex.so.1
libswresample.so.1
libswscale.so.3
libx264.so.146
Synology> ./ffmpeg
Synology> cd ffmpeg
fc-cache
ffmpeg
libass.so.5
libavcodec.so.56
libavdevice.so.56
libavfilter.so.5
libavformat.so.56
libavutil.so.54
libfontconfig.so.1
libfribidi.so.0
libgnutls.so.28
libhogweed.so.2
libnettle.so.4
libpostproc.so.53
librtmp.so.1
libspeex.so.1
libswresample.so.1
libswscale.so.3
libx264.so.146
Synology> ./ffmpeg
Ok thanks for that, I have enough to add support to Serviio.
That's strange about VideoStation though. That ffmpeg shows no evidence of hardware transcoding support at all. There are two possibilities - either it does not have working support (possibly coming in DSM 6.0), or perhaps there is another build of ffmpeg somewhere on the system.
- Code:
find -name ffmpeg
find: ./proc/6091: No such file or directory
./usr/syno/bin/ffmpeg
./volume1/@tmp/ffmpeg
./volume1/@tmp/ffmpeg/ffmpeg
./volume1/@appstore/VideoStation/apparmor/abstractions.pkg/VideoStation/ffmpeg
./volume1/@appstore/VideoStation/bin/ffmpeg
./volume1/@appstore/VideoStation/lib/ffmpeg
Not sure if it helps you out, but i've also run ./usr/syno/bin/ffmpeg resulting in:
- Code:
SyNas> ./usr/syno/bin/ffmpeg
built on Oct 1 2015 22:02:54 with gcc 4.8.3 (crosstool-NG git+85622fd-dirty) 20140106 (prerelease)
configuration: --prefix=/usr/syno --incdir='${prefix}/include/ffmpeg' --arch=arm --target-os=linux --cross-prefix=/usr/local/arm-cortexa9hf-linux-gnueabi/bin/arm-cortexa9hf-linux-gnueabi- --enable-cross-compile --enable-optimizations --enable-pic --enable-gpl --enable-shared --disable-static --enable-version3 --enable-nonfree --enable-libfaac --enable-encoders --enable-pthreads --disable-bzlib --disable-protocol=rtp --disable-muxer=image2 --disable-muxer=image2pipe --disable-swscale-alpha --disable-ffserver --disable-ffplay --disable-devices --disable-bzlib --disable-altivec --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libmp3lame --disable-vaapi --disable-decoder=amrnb --disable-encoder=zmbv --disable-encoder=dca --disable-encoder=ac3 --disable-encoder=ac3_fixed --disable-encoder=eac3 --disable-decoder=dca --disable-decoder=eac3 --disable-decoder=truehd --cc=/usr/local/arm-cortexa9hf-linux-gnueabi/bin/arm-cortexa9hf-linux-gnueabi-ccache-gcc
patters wrote:Ok thanks for that, I have enough to add support to Serviio.
Dear patters! Could you please let us know when you will add ds216play support to serviio. Thanks!
It's done
Hi everone,
I have Serviio 1.5.2 installed on Synology DS216play/DSM 5.2. How to check if Serviio use hardware transcoding? (.mkvs freeze on Sharp Aquos TV, I must wait about 10sec to start any movie)
Wojtel
Wojtel
patters wrote:It's done
Excellent!!! Thanks a million!
Working like a charm on my DS216Play.
Very slow Serviio start on my Samsung TV(when browsing folders). From time to time "lost network connection" window during movie viewing. built-in DLNA and ds-video widget works fine. Any ideas?
wojtas40 wrote:Hi everone,
Wojtel
Anyone help?
It's not hardware transcoding I'm afraid. Without that feature, the DS216play is quite a weak CPU system compared to the Intel ones. The only models which are currently supported for hardware transcoding with Serviio are the DS214play and DS415play. I hope to add support for the Braswell models (DS216+, DS716+) and the DS216play later, but I will need Synology to publish their source code for DSM 6.0 first.
The new videostation (version 2.0-1132) seems to have compiled ffmpeg with some different options than before:
Is there any way I can assist you, in making Serviio for Synology DS216play, hardware encoding compatible?
- Code:
ffmpeg version 2.7.1 Copyright (c) 2000-2015 the FFmpeg developers
built with gcc 4.9.3 (crosstool-NG 1.20.0) 20150311 (prerelease)
configuration: --prefix=/usr/pkg --incdir='${prefix}/include/ffmpeg' --arch=armv7 --target-os=linux --cross-prefix=/usr/local/arm-unknown-linux-gnueabi/bin/arm-unknown-linux-gnueabi- --enable-cross-compile --enable-optimizations --enable-pic --enable-gpl --enable-version3 --enable-nonfree --enable-libfaac --enable-encoders --enable-pthreads --disable-muxer=image2 --disable-muxer=image2pipe --disable-swscale-alpha --disable-ffplay --disable-ffserver --disable-doc --disable-devices --disable-bzlib --disable-altivec --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libmp3lame --disable-decoder=amrnb --disable-encoder=zmbv --cc=/usr/local/arm-unknown-linux-gnueabi/bin/arm-unknown-linux-gnueabi-ccache-gcc --enable-shared --disable-static --enable-libfdk-aac
It looks like synology finally released the gpl source code and toolkits.
https://sourceforge.net/projects/dsgpl/
Yep, I spotted that just before Christmas and got new FFmpeg binaries for DSM 6.0 built. Nearly ready to release Serviio 1.8 for Synology.
Users browsing this forum: Baidu [Spider] and 12 guests
