Serviio and Synology Ds216play
Everlast
Post Wed Dec 09, 2015 12:42 pm
Cant find java and serviio on a repository. Only minecraft and some other crap. It means that my nas doesnt supported? Thanks.
patters
Post Sat Dec 12, 2015 1:26 pm
Re: Serviio and Synology Ds216play
For now yes. But hopefully you can help me to get it supported.
Please log in via SSH as root (same password as for admin).
Then post back here with the results of:
cat /proc/cpuinfo
uname -a
Thanks!
Everlast
Post Sat Dec 12, 2015 5:13 pm
Thank you! Here it is:
Synology> cat /proc/cpuinfo
processor : 0
model name : ARMv7 Processor rev 0 (v7l)
BogoMIPS : 2989.26
Features : swp half thumb fastmult vfp edsp neon vfpv3 tls
CPU implementer : 0x41
CPU architecture: 7
CPU variant : 0x3
CPU part : 0xc09
CPU revision : 0
processor : 1
BogoMIPS : 2989.26
CPU architecture: 7
CPU variant : 0x3
CPU part : 0xc09
CPU revision : 0
Hardware : STi SoC with Flattened Device Tree
Revision : 0000
Serial : 0000000000000000
Synology> uname -a
patters
Post Sun Dec 13, 2015 12:05 pm
It looks like you didn't hit return after the second command (uname -a).
Everlast
Post Sun Dec 13, 2015 3:08 pm
patters wrote:It looks like you didn't hit return after the second command (uname -a).
sorry about that
Synology> uname -a
Linux Synology 3.10.35 #5644 SMP Thu Nov 12 17:16:21 CST 2015 armv7l GNU/Linux synology_monaco_ds216play
patters
Post Mon Dec 14, 2015 12:17 pm
Can you try this and report the ffmpeg result?
cd /volume1/@tmp
mkdir ffmpeg
cd ffmpeg
wget http://packages.pcloadletter.co.uk/downloads/serviio1.5-native-armhfneon.tar.xz
tar xvJf serviio1.5-native-armhfneon.tar.xz
./ffmpeg
Try to install the Java 8 package now - I've added support for the DS216play. When you look at the Java package log in Package Center do you see the HotSpot version number?
I'm interested to get the hardware transcoding working ASAP on the DS216play. Could you install VideoStation and post back here with the output from:
/var/packages/VideoStation/target/bin/ffmpeg
nire
Post Tue Dec 15, 2015 12:08 pm
./ffmpeg
ffmpeg version 2.7.1-compiled_by_patters_for_Serviio Copyright (c) 2000-2015 the FFmpeg developers
  built with gcc 4.6.4 (crosstool-NG 1.18.0) 20130102 (prerelease)
  configuration: --arch=arm --cpu=cortex-a9 --enable-thumb --enable-cross-compile --cross-prefix=/usr/local/arm-cortexa9-linux-gnueabi/bin/arm-cortexa9-linux-gnueabi- --target-os=linux --prefix=/usr/local/arm-cortexa9-linux-gnueabi --enable-shared --disable-static --enable-pic --disable-ffplay --disable-ffserver --disable-debug --enable-pthreads --enable-libmp3lame --enable-librtmp --enable-libass --enable-libspeex --enable-gpl --enable-libx264 --enable-gnutls --pkg-config=pkg-config --extra-version=compiled_by_patters_for_Serviio
  libavutil      54. 27.100 / 54. 27.100
  libavcodec     56. 41.100 / 56. 41.100
  libavformat    56. 36.100 / 56. 36.100
  libavdevice    56.  4.100 / 56.  4.100
  libavfilter     5. 16.101 /  5. 16.101
  libswscale      3.  1.101 /  3.  1.101
  libswresample   1.  2.100 /  1.  2.100
  libpostproc    53.  3.100 / 53.  3.100
ffmpeg version 2.0.2 Copyright (c) 2000-2013 the FFmpeg developers
  built on Nov 12 2015 18:48:36 with gcc 4.8.3 (crosstool-NG git+85622fd-dirty) 20140106 (prerelease)
  configuration: --prefix=/usr/pkg --incdir='${prefix}/include/ffmpeg' --arch=armv7 --target-os=linux --cross-prefix=/usr/local/arm-cortexa9hf-linux-gnueabi/bin/arm-cortexa9hf-linux-gnueabi- --enable-cross-compile --enable-optimizations --enable-pic --enable-gpl --enable-version3 --enable-nonfree --enable-libfaac --enable-encoders --enable-pthreads --disable-muxer=image2 --disable-muxer=image2pipe --disable-swscale-alpha --disable-ffplay --disable-doc --disable-devices --disable-bzlib --disable-altivec --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libmp3lame --disable-decoder=amrnb --disable-encoder=zmbv --cc=/usr/local/arm-cortexa9hf-linux-gnueabi/bin/arm-cortexa9hf-linux-gnueabi-ccache-gcc --enable-shared --disable-static --disable-encoder=dca --disable-encoder=ac3 --disable-encoder=ac3_fixed --disable-encoder=eac3 --disable-decoder=dca --disable-decoder=eac3 --disable-decoder=truehd --disable-vaapi --enable-libfdk-aac
  libavutil      52. 38.100 / 52. 38.100
  libavcodec     55. 18.102 / 55. 18.102
  libavformat    55. 12.100 / 55. 12.100
  libavdevice    55.  3.100 / 55.  3.100
  libavfilter     3. 79.101 /  3. 79.101
I managed to get Java 8 installed. Logs show "Java HotSpot(TM) Embedded Client VM (build 25.65-b01, mixed mode)"
Everlast
Post Tue Dec 15, 2015 5:16 pm
Synology> cd /volume1/@tmp
Synology> mkdir ffmpeg
mkdir: can't create directory 'ffmpeg': File exists
Synology> cd ffmpeg
Synology> wget http://packages.pcloadletter.co.uk/down ... eon.tar.xz
--2015-12-15 21:21:47-- http://packages.pcloadletter.co.uk/down ... eon.tar.xz
Resolving packages.pcloadletter.co.uk... 82.147.22.211
Connecting to packages.pcloadletter.co.uk|82.147.22.211|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 6495564 (6.2M) [application/x-tar]
Saving to: 'serviio1.5-native-armhfneon.tar.xz.1'
100%[===================================================================================================================================================================================================>] 6,495,564 907KB/s in 13s
2015-12-15 21:22:00 (497 KB/s) - 'serviio1.5-native-armhfneon.tar.xz.1' saved [6495564/6495564]
Synology> tar xvJf serviio1.5-native-armhfneon.tar.xz
fc-cache
ffmpeg
libass.so.5
libavcodec.so.56
libavdevice.so.56
libavfilter.so.5
libavformat.so.56
libavutil.so.54
libfontconfig.so.1
libfribidi.so.0
libgnutls.so.28
libhogweed.so.2
libnettle.so.4
libpostproc.so.53
librtmp.so.1
libspeex.so.1
libswresample.so.1
libswscale.so.3
libx264.so.146
Synology> ./ffmpeg
patters
Post Wed Dec 16, 2015 10:57 am
Ok thanks for that, I have enough to add support to Serviio.
That's strange about VideoStation though. That ffmpeg shows no evidence of hardware transcoding support at all. There are two possibilities - either it does not have working support (possibly coming in DSM 6.0), or perhaps there is another build of ffmpeg somewhere on the system.
nire
Post Wed Dec 16, 2015 12:15 pm
find -name ffmpeg
find: ./proc/6091: No such file or directory
./usr/syno/bin/ffmpeg
./volume1/@tmp/ffmpeg
./volume1/@tmp/ffmpeg/ffmpeg
./volume1/@appstore/VideoStation/apparmor/abstractions.pkg/VideoStation/ffmpeg
./volume1/@appstore/VideoStation/bin/ffmpeg
./volume1/@appstore/VideoStation/lib/ffmpeg
Not sure if it helps you out, but i've also run ./usr/syno/bin/ffmpeg resulting in:
SyNas> ./usr/syno/bin/ffmpeg
  built on Oct  1 2015 22:02:54 with gcc 4.8.3 (crosstool-NG git+85622fd-dirty) 20140106 (prerelease)
  configuration: --prefix=/usr/syno --incdir='${prefix}/include/ffmpeg' --arch=arm --target-os=linux --cross-prefix=/usr/local/arm-cortexa9hf-linux-gnueabi/bin/arm-cortexa9hf-linux-gnueabi- --enable-cross-compile --enable-optimizations --enable-pic --enable-gpl --enable-shared --disable-static --enable-version3 --enable-nonfree --enable-libfaac --enable-encoders --enable-pthreads --disable-bzlib --disable-protocol=rtp --disable-muxer=image2 --disable-muxer=image2pipe --disable-swscale-alpha --disable-ffserver --disable-ffplay --disable-devices --disable-bzlib --disable-altivec --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libmp3lame --disable-vaapi --disable-decoder=amrnb --disable-encoder=zmbv --disable-encoder=dca --disable-encoder=ac3 --disable-encoder=ac3_fixed --disable-encoder=eac3 --disable-decoder=dca --disable-decoder=eac3 --disable-decoder=truehd --cc=/usr/local/arm-cortexa9hf-linux-gnueabi/bin/arm-cortexa9hf-linux-gnueabi-ccache-gcc
Everlast
Post Mon Dec 21, 2015 5:52 am
patters wrote:Ok thanks for that, I have enough to add support to Serviio.
Dear patters! Could you please let us know when you will add ds216play support to serviio. Thanks!
patters
Post Fri Jan 08, 2016 1:32 pm
It's done :)
wojtas40
Post Mon Jan 11, 2016 10:21 pm
Hi everone,
I have Serviio 1.5.2 installed on Synology DS216play/DSM 5.2. How to check if Serviio use hardware transcoding? (.mkvs freeze on Sharp Aquos TV, I must wait about 10sec to start any movie)
Wojtel
nire
Post Tue Jan 12, 2016 3:23 pm
patters wrote:It's done :)
Excellent!!! Thanks a million!
Working like a charm on my DS216Play.
Everlast
Post Sun Jan 17, 2016 1:52 pm
Very slow Serviio start on my Samsung TV(when browsing folders). From time to time "lost network connection" window during movie viewing. built-in DLNA and ds-video widget works fine. Any ideas?
wojtas40
Post Sun Jan 24, 2016 10:12 pm
wojtas40 wrote:Hi everone,
Wojtel
Anyone help?
patters
Post Fri Jan 29, 2016 8:28 am
It's not hardware transcoding I'm afraid. Without that feature, the DS216play is quite a weak CPU system compared to the Intel ones. The only models which are currently supported for hardware transcoding with Serviio are the DS214play and DS415play. I hope to add support for the Braswell models (DS216+, DS716+) and the DS216play later, but I will need Synology to publish their source code for DSM 6.0 first.
nire
Post Mon Apr 18, 2016 12:25 pm
The new videostation (version 2.0-1132) seems to have compiled ffmpeg with some different options than before:
ffmpeg version 2.7.1 Copyright (c) 2000-2015 the FFmpeg developers
  built with gcc 4.9.3 (crosstool-NG 1.20.0) 20150311 (prerelease)
  configuration: --prefix=/usr/pkg --incdir='${prefix}/include/ffmpeg' --arch=armv7 --target-os=linux --cross-prefix=/usr/local/arm-unknown-linux-gnueabi/bin/arm-unknown-linux-gnueabi- --enable-cross-compile --enable-optimizations --enable-pic --enable-gpl --enable-version3 --enable-nonfree --enable-libfaac --enable-encoders --enable-pthreads --disable-muxer=image2 --disable-muxer=image2pipe --disable-swscale-alpha --disable-ffplay --disable-ffserver --disable-doc --disable-devices --disable-bzlib --disable-altivec --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libmp3lame --disable-decoder=amrnb --disable-encoder=zmbv --cc=/usr/local/arm-unknown-linux-gnueabi/bin/arm-unknown-linux-gnueabi-ccache-gcc --enable-shared --disable-static --enable-libfdk-aac
Is there any way I can assist you, in making Serviio for Synology DS216play, hardware encoding compatible?
nire
Post Tue Jan 03, 2017 7:22 am
It looks like synology finally released the gpl source code and toolkits.
https://sourceforge.net/projects/dsgpl/
patters
Post Thu Jan 05, 2017 11:15 pm
Yep, I spotted that just before Christmas and got new FFmpeg binaries for DSM 6.0 built. Nearly ready to release Serviio 1.8 for Synology.
Users browsing this forum: Baidu [Spider] and 10 guests
