Problem Playing Back Mkv files on BDP-S370/B
achemen
Post Wed Mar 09, 2011 8:03 am
got the Sony BDP-S370/B,have problems playing back Mkv Files Via the Pendrive or Usb Drive when connected to the USB port of the player. i am trying to playback mkv file 1080p with DTS audio
here is the details from MediaInfo:
Unique ID                        : 196543444207911688720432203541843017824 (0x93DCE3F5027E35BAA559D37E74780060)
Complete name                    : C:\Documents and Settings\rop.BluRay.DTS.x264.mkv
Format                           : Matroska
File size                        : 57.0 MiB
Duration                         : 1mn 8s
Overall bit rate                 : 6 947 Kbps
Encoded date                     : UTC 2011-03-09 07:58:13
Writing application              : mkvmerge v3.4.0 ('Rapunzel') built on May 15 2010 09:38:20
Writing library                  : libebml v0.8.0 + libmatroska v0.9.0
Format profile                   : High@L4.1
Format settings, CABAC           : Yes
Format settings, ReFrames        : 5 frames
Codec ID                         : V_MPEG4/ISO/AVC
Duration                         : 1mn 8s
Bit rate                         : 5 299 Kbps
Width                            : 1 920 pixels
Height                           : 816 pixels
Display aspect ratio             : 2.35:1
Frame rate                       : 23.976 fps
Bits/(Pixel*Frame)               : 0.141
Stream size                      : 43.5 MiB (76%)
Title                            : Dean
Language                         : English
Format                           : DTS
Format/Info                      : Digital Theater Systems
Codec ID                         : A_DTS
Duration                         : 1mn 8s
Bit rate                         : 1 510 Kbps
Channel(s)                       : 6 channels
Channel positions                : Front: L C R, Side: L R, LFE
Bit depth                        : 16 bits
Delay relative to video          : 47ms
Stream size                      : 12.4 MiB (22%)
Title                            : DTS 1510kbps
Text
Format                           : ASS
Codec ID                         : S_TEXT/ASS
Codec ID/Info                    : Advanced Sub Station Alpha
Compression mode                 : Lossless
Title                            : Desman
Language                         : English
please advice how to go about playing this file
awaiting your hel
Post Wed Mar 09, 2011 1:50 pm
Re: Problem Playing Back Mkv files on BDP-S370/B
we are not support for SONY hardware here we only support the playing of files using a DLNA server ( serviio ) to stream to SONY devices not directly plugging a pen drive plugged to the device for this kinda help you should really go to SONYs support forums...
