Minimize to Tray
I see no option to cause it to minimize to the system tray.
It's kind of big and ugly to leave open like that at all times.
cuf wrote:I just installed v1.6 on Win7 x64 and I'm feeling pretty stupid. Clicking 'X' closes Serviio. Clicking '-' minimizes to the taskbar.
cuf wrote:Okay, so it's a wrapper and not a true console, but that's semantics. It would still be nice to be able to minimize the wrapper it to the tray and give it back the 'Force Refresh' right-click option.
anniebody wrote:As a follow up Serviio no longer works at all!
1.5.2 would not let me install over the later crappy version 1.6.2, so I had to uninstall Serviio completely.
After a clean reinstall of 1.5 2 and restoration of my library I got an error message 500 which wouldn't let me use my previous library settings. Tried starting the library again from scratch but still had the error and the files showed a mix of metadata (which I never use) with an incmplete list. Forcing a library update just kept giving me the 500 error.
Another uninstall and re-install of Serviio, but this time decided I would have to manually set it up again from scratch: if only...
First I got a missing node.dll error. As I couldn't find this file anywhere on my existing system, nor my previous backup,I assumed it was never needed and unstallled and re-installled again.
This time no node.dll error but a missing /jre file.
Updated Java 32 and 64 bit to latest versions, but still the error.
Uninstalled Java completely and reinstalled the latest 32 and 64 bit versions. Still the error.
Uninstalled and re-installed Serviio and the java error no longer shows, but a new error message stating the Serviio service is not running.
When I manually start the service it stops again after a couple of seconds. Cannot run the Serviio console using the bat file either.
I think the substantial changes made in 1.6.2 have screwed up my Serviio for good. I have changed nothing on my system but now Serviio will not work at all. So much for progress. Another 6 hours wasted on crappy software.
If it worked before 1.6.2 why doesn't it now work with 1.5.2 or has 1.6.2 now made it impossible for me to go back?
Anyone know of how I can get Serviio working again, or do I now have to look for an alternative?
Users browsing this forum: Baidu [Spider] and 30 guests
