Plugins
• Page 1 of 1
Re: Plugins
Petr
Help translate Serviio
Re: Plugins
zip wrote:http://serviio.org/index.php?option=com_content&view=article&id=42
Many thank's
Re: Plugins
I have put the plugins in / Library / Application Support / Serviio / plugins, but how do you see these plugins from my TV?
Re: Plugins
The same way as you watch files only they are in the online category rather than one of the other presentation categories. If nothing shows up either you did not add the online feed correctly or your plugin does not work. You need to view the DEBUG log to determine the problem.
Re: Plugins
jhb50 wrote:The same way as you watch files only they are in the online category rather than one of the other presentation categories. If nothing shows up either you did not add the online feed correctly or your plugin does not work. You need to view the DEBUG log to determine the problem.
When I restored my Mac, I post the debug file
Re: Plugins
That section of the log is just a repeating error with no earlier part of the log to give them context..
You need to do a clean start of serviio, and immediately try and play the online sources, then post the whole debug log.
- Code:
2016-02-04 16:22:15,775 ERROR [DiscoverySSDPMessageListener] Cannot open multicast socket,will try again
java.net.BindException: Address already in use
at java.net.PlainDatagramSocketImpl.bind0(Native Method)
at java.net.AbstractPlainDatagramSocketImpl.bind(AbstractPlainDatagramSocketImpl.java:94)
at java.net.DatagramSocket.bind(DatagramSocket.java:392)
at java.net.MulticastSocket.<init>(MulticastSocket.java:172)
at java.net.MulticastSocket.<init>(MulticastSocket.java:136)
at org.serviio.util.MultiCastUtils.startMultiCastSocketForListening(MultiCastUtils.java:47)
at org.serviio.upnp.discovery.DiscoverySSDPMessageListener.run(DiscoverySSDPMessageListener.java:89)
Re: Plugins
jhb50 wrote:You need to do a clean start of serviio, and immediately try and play the online sources, then post the whole debug log.
How to make a clean start Serviio?
Re: Plugins
same way you started it to get the debug log, but first erase the serviio.log files in the serviio/logs directory
Re: Plugins
jhb50 wrote:same way you started it to get the debug log, but first erase the serviio.log files in the serviio/logs directory
My serviio log after clean restart
Re: Plugins
That simply says you have an error that prevented Serviio from starting. I can't help you with that.
Re: Plugins
Ramses2 wrote:jhb50 wrote:same way you started it to get the debug log, but first erase the serviio.log files in the serviio/logs directory
It says the address is in use. I don't know if it is referring to the IP address of the computer, or something to do with the database. I suggest reinstalling Serviio as the first step.
• Page 1 of 1
