Plugins
Ramses2
Post Wed Feb 03, 2016 8:56 pm
Plugins
Hi
Just a question. How can i install plugins with Serviio 1.6 ?
I have an iMac
Thank's for your answer
Post Wed Feb 03, 2016 10:23 pm
Re: Plugins
Ramses2
Post Thu Feb 04, 2016 5:58 am
Re: Plugins
zip wrote:http://serviio.org/index.php?option=com_content&view=article&id=42
Many thank's
Ramses2
Post Thu Feb 04, 2016 12:12 pm
Re: Plugins
I have put the plugins in / Library / Application Support / Serviio / plugins, but how do you see these plugins from my TV?
Post Thu Feb 04, 2016 1:38 pm
Re: Plugins
The same way as you watch files only they are in the online category rather than one of the other presentation categories. If nothing shows up either you did not add the online feed correctly or your plugin does not work. You need to view the DEBUG log to determine the problem.
Ramses2
Post Thu Feb 04, 2016 2:07 pm
Re: Plugins
jhb50 wrote:The same way as you watch files only they are in the online category rather than one of the other presentation categories. If nothing shows up either you did not add the online feed correctly or your plugin does not work. You need to view the DEBUG log to determine the problem.
When I restored my Mac, I post the debug file
Ramses2
Post Thu Feb 04, 2016 3:16 pm
Re: Plugins
Here is my Debug Log
(337.72 KiB) Downloaded 225 times
Post Thu Feb 04, 2016 9:12 pm
Re: Plugins
That section of the log is just a repeating error with no earlier part of the log to give them context..
2016-02-04 16:22:15,775 ERROR [DiscoverySSDPMessageListener] Cannot open multicast socket,will try again
java.net.BindException: Address already in use
   at java.net.PlainDatagramSocketImpl.bind0(Native Method)
   at java.net.AbstractPlainDatagramSocketImpl.bind(AbstractPlainDatagramSocketImpl.java:94)
   at java.net.DatagramSocket.bind(DatagramSocket.java:392)
   at java.net.MulticastSocket.<init>(MulticastSocket.java:172)
   at java.net.MulticastSocket.<init>(MulticastSocket.java:136)
   at org.serviio.util.MultiCastUtils.startMultiCastSocketForListening(MultiCastUtils.java:47)
   at org.serviio.upnp.discovery.DiscoverySSDPMessageListener.run(DiscoverySSDPMessageListener.java:89)
You need to do a clean start of serviio, and immediately try and play the online sources, then post the whole debug log.
Ramses2
Post Thu Feb 04, 2016 9:16 pm
Re: Plugins
jhb50 wrote:You need to do a clean start of serviio, and immediately try and play the online sources, then post the whole debug log.
How to make a clean start Serviio?
Post Thu Feb 04, 2016 10:00 pm
Re: Plugins
same way you started it to get the debug log, but first erase the serviio.log files in the serviio/logs directory
Ramses2
Post Thu Feb 04, 2016 10:23 pm
Re: Plugins
jhb50 wrote:same way you started it to get the debug log, but first erase the serviio.log files in the serviio/logs directory
My serviio log after clean restart
(2.87 KiB) Downloaded 220 times
Post Fri Feb 05, 2016 4:52 am
Re: Plugins
That simply says you have an error that prevented Serviio from starting. I can't help you with that.
Post Fri Feb 05, 2016 10:50 pm
Re: Plugins
It says the address is in use. I don't know if it is referring to the IP address of the computer, or something to do with the database. I suggest reinstalling Serviio as the first step.
Samsung NU7100 4K TV, Samsung JU7100 4K TV, Sony BDP-S3500, Sharp 4K Roku TV, Insignia Roku TV, Roku Ultra, Premiere and Stick, Nvidia Shield, Yamaha RX-V583 AVR.
Primary server: Intel i5-6400, 8 gig ram, Windows 10 Pro, 22 TB hard drive space | Test server Windows 10 Pro, AMD Phenom II X4 965, 8 gig ram
Return to General discussion
