Mon Mar 07, 2016 9:35 pm by Paul C
I will try out the logging (not done it before).
In the meantime I enclose screenshots. The last file was removed and an additional file added at end of playlist.
The change (Good-sounds-1) was made at 17.49 and still not updated after 3 1/2 hours.
The audio file has been there for 9 months (also other server updated OK) - see screenshot. (Files are selected from pull-down list in M3U Creator).
I have now noted that new file Good-sounds-2 has not appeared (it used to under earlier versions - that is how I got around the issue previously).
- Attachments
- playlist-issue-1.jpg (408.45 KiB) Viewed 8954 times
- playlist-issue-4.jpg (335.9 KiB) Viewed 8956 times
- playlist-issue-3.jpg (241.88 KiB) Viewed 8956 times
Paul C on Mon Mar 07, 2016 10:09 pm, edited 5 times in total.
