Serviio 1.6 not updating playlists in library
Paul C
Post Mon Mar 07, 2016 8:17 pm
Serviio 1.6 seems more robust in automatically updating audio files in the library than the previous version.
However I still have a problem with playlist updating which existed in the earlier version.
If I add additional files to an existing playlist it does not update but if I create a new playlist by changing the playlist filename, i.e.Sounds-1 to Sounds-2, the new playlist immediately appears.
Post Mon Mar 07, 2016 8:43 pm
Re: Serviio 1.6 not updating playlists in library
Post detailed log of when you edit a playlist. Are you sure the audio file already exists in your Serviio library?
Paul C
Post Mon Mar 07, 2016 9:35 pm
I will try out the logging (not done it before).
In the meantime I enclose screenshots. The last file was removed and an additional file added at end of playlist.
The change (Good-sounds-1) was made at 17.49 and still not updated after 3 1/2 hours.
The audio file has been there for 9 months (also other server updated OK) - see screenshot. (Files are selected from pull-down list in M3U Creator).
I have now noted that new file Good-sounds-2 has not appeared (it used to under earlier versions - that is how I got around the issue previously).
Paul C
Post Mon Mar 07, 2016 9:38 pm
Screenshot of the Serviio console.
Post Thu Mar 10, 2016 9:10 pm
need that detailed log file at the point of you making a change to the playlist.
Also the edited playlist file would be helpful (the actual m3u file, not a screenshot)
Paul C
Post Wed Jun 06, 2018 8:17 pm
NOT SOLVED - Re: Serviio 1.6 not updating playlists in libra
I thought the developer has resolved this issue or by setting the "Use the poller mechanism for monitoring this folder" option under shared folders/edit for the shared folder of the the playlist folder as at 1.9.1.
I updated one existing playlist RS-2 by adding two tracks (worked OK) and then removed a track (worked OK).
I then created a new playlist RS-3 but this was not recognised.
I re-edited it and changed its' name to RS-3a and it was recognised.
So still have an issue.
Users browsing this forum: Baidu [Spider] and 261 guests
