Problem with Feed expiry interval
momchil
Post Mon Oct 10, 2016 6:50 pm
On every restart Serviio 1.7 check all online feeds. My "Feed expiry interval" is set to 99999.
How I can stop this recheck every time?
momchil
Post Tue Oct 11, 2016 4:19 pm
Re: Problem with Feed expiry interval
Up!
Post Tue Oct 11, 2016 8:33 pm
That's how it works. The expiry dates for feeds are in memory, so restart will erase it. The technical metadata is cached though (if the plugin creator decides it) so the slow part wont happen again even after restart.
momchil
Post Tue Oct 11, 2016 9:28 pm
I don't have any plugin. Only "Online sources" in Library.
And? I can't stop this recheck?
Post Wed Oct 12, 2016 12:31 pm
What are your online sources? simple feeds?
No, you can't.
momchil
Post Wed Oct 12, 2016 4:58 pm
I have more than 100 feeds... Pf...
I will return to 1.5.2 or I will change the code.
Post Thu Oct 13, 2016 7:27 am
Are you saying 1.5.2 didn't refresh them? There should be no change AFAIK.
momchil
Post Fri Oct 14, 2016 5:35 pm
Yes, no change...
What is this "fixed metadata caching for online content" in changelog for 1.7.1? No more rescan after every restart?
jk50
Post Sat Oct 15, 2016 6:33 am
I believe I have the same problem . Serviio 1.7 and 1.7.1 both do the full metadata check on all online sources every time
serviio is started. This is definitely different behavior from version 1.6.1 or earlier. This happens on two different linux setups,
one kubuntu 14.4 using oracle java 8.0_45, the other neon 16.4 using openjdk 8.0_91. I also get errors in the log for every online
source from both serviio 1.7 and 1.7.1 like the following.
2016-10-13 13:03:18,296 ERROR [IndexedDiskCache] Region [online_technical_metadata] Failure updating element, key: http://127.0.0.1:8001/cgi-bin/cable.sh?2 old: null
java.io.NotSerializableException: org.serviio.library.local.AudioTrack
   at java.io.ObjectOutputStream.writeObject0(ObjectOutputStream.java:1184)
   at java.io.ObjectOutputStream.writeObject(ObjectOutputStream.java:348)
   at java.util.ArrayList.writeObject(ArrayList.java:762)
   at sun.reflect.GeneratedMethodAccessor11.invoke(Unknown Source)
   at java.io.ObjectStreamClass.invokeWriteObject(ObjectStreamClass.java:1028)
   at java.io.ObjectOutputStream.writeSerialData(ObjectOutputStream.java:1496)
   at java.io.ObjectOutputStream.writeOrdinaryObject(ObjectOutputStream.java:1432)
   at java.io.ObjectOutputStream.writeObject0(ObjectOutputStream.java:1178)
   at java.io.ObjectOutputStream.defaultWriteFields(ObjectOutputStream.java:1548)
   at java.io.ObjectOutputStream.writeSerialData(ObjectOutputStream.java:1509)
   at org.apache.jcs.utils.serialization.StandardSerializer.serialize(StandardSerializer.java:50)
   at org.apache.jcs.auxiliary.disk.indexed.IndexedDisk.serialize(IndexedDisk.java:288)
   at org.apache.jcs.auxiliary.disk.indexed.IndexedDiskCache.doUpdate(IndexedDiskCache.java:430)
   at org.apache.jcs.auxiliary.disk.AbstractDiskCache$MyCacheListener.handlePut(AbstractDiskCache.java:603)
   at org.apache.jcs.engine.CacheEventQueue$PutEvent.doRun(CacheEventQueue.java:688)
   at org.apache.jcs.engine.CacheEventQueue$AbstractCacheEvent.run(CacheEventQueue.java:607)
   at org.apache.jcs.engine.CacheEventQueue$QProcessor.run(CacheEventQueue.java:575)
All the same online sources work fine in version 1.6.1 .
Post Mon Oct 17, 2016 8:01 am
^ this error should be what was fixed in 1.7.1. Is it still happening?
jk50
Post Mon Oct 17, 2016 11:58 am
Yes , I just checked it again ,still getting errors like the following in linux version 1.7.1
2016-10-17 07:44:42,681 ERROR [IndexedDiskCache] Region [online_technical_metadata] Failure updating element, key: http://127.0.0.1:8001/cgi-bin/cable.sh?2 old: null
   at sun.reflect.GeneratedMethodAccessor12.invoke(Unknown Source)
Post Mon Oct 17, 2016 6:00 pm
What if you remove the feed from library, Save and add it again?
jk50
Post Mon Oct 17, 2016 7:14 pm
Ok , I started version 1.7.1 , let it run till it finished checking all online sources and settled down.
Checked the log , for every online source same previously mentioned error. I removed a source , hit save , added same source again.
Checked the log again and the removed and replaced source got the same error again
2016-10-17 14:38:58,155 ERROR [IndexedDiskCache] Region [online_technical_metadata] Failure updating element, key: http://127.0.0.1:8001/cgi-bin/dvd2.sh?/media/ex3/Video/K3b.iso old: null
Post Tue Oct 18, 2016 8:48 am
Thanks, I will try to release a patch.
Post Tue Oct 18, 2016 8:30 pm
I have released 1.7.1.1 which should fix the feed error above. get it on the download page.
momchil
Post Tue Oct 18, 2016 8:42 pm
zip wrote:I have released 1.7.1.1 which should fix the feed error above. get it on the download page.
momchil wrote:Yes, no change...
Post Wed Oct 19, 2016 7:41 am
This fixes the error jk50 had.
It will still rescan feeds on restart, as it was always doing (AFAIK), but it will now not invoke ffmpeg for all the items, as they will be properly cached.
jk50
Post Wed Oct 19, 2016 11:47 am
Version 1.7.1.1 is working well ,thank you.
momchil
Post Sun Oct 23, 2016 10:42 am
I have installed XUPNPD on my OpenWRT router.
Now Serviio is only for video files.
Sorry, zip, but rescan of online content after every start is not a good solution.
lagunaa
Post Thu Oct 27, 2016 12:41 pm
Just be aware of new version 1.7.1.1 at http://www.serviio.org/download because of this forum post.
Why didn't you post it on the Announcements / News section as usual?
Neither https://bitbucket.org/xnejp03/serviio/issues mentioned that new version.
Cheers.
