Problem with Feed expiry interval
On every restart Serviio 1.7 check all online feeds. My "Feed expiry interval" is set to 99999.
How I can stop this recheck every time?
2016-10-13 13:03:18,296 ERROR [IndexedDiskCache] Region [online_technical_metadata] Failure updating element, key: http://127.0.0.1:8001/cgi-bin/cable.sh?2 old: null
java.io.NotSerializableException: org.serviio.library.local.AudioTrack
at java.io.ObjectOutputStream.writeObject0(ObjectOutputStream.java:1184)
at java.io.ObjectOutputStream.writeObject(ObjectOutputStream.java:348)
at java.util.ArrayList.writeObject(ArrayList.java:762)
at sun.reflect.GeneratedMethodAccessor11.invoke(Unknown Source)
at java.io.ObjectStreamClass.invokeWriteObject(ObjectStreamClass.java:1028)
at java.io.ObjectOutputStream.writeSerialData(ObjectOutputStream.java:1496)
at java.io.ObjectOutputStream.writeOrdinaryObject(ObjectOutputStream.java:1432)
at java.io.ObjectOutputStream.writeObject0(ObjectOutputStream.java:1178)
at java.io.ObjectOutputStream.defaultWriteFields(ObjectOutputStream.java:1548)
at java.io.ObjectOutputStream.writeSerialData(ObjectOutputStream.java:1509)
at org.apache.jcs.utils.serialization.StandardSerializer.serialize(StandardSerializer.java:50)
at org.apache.jcs.auxiliary.disk.indexed.IndexedDisk.serialize(IndexedDisk.java:288)
at org.apache.jcs.auxiliary.disk.indexed.IndexedDiskCache.doUpdate(IndexedDiskCache.java:430)
at org.apache.jcs.auxiliary.disk.AbstractDiskCache$MyCacheListener.handlePut(AbstractDiskCache.java:603)
at org.apache.jcs.engine.CacheEventQueue$PutEvent.doRun(CacheEventQueue.java:688)
at org.apache.jcs.engine.CacheEventQueue$AbstractCacheEvent.run(CacheEventQueue.java:607)
at org.apache.jcs.engine.CacheEventQueue$QProcessor.run(CacheEventQueue.java:575)
2016-10-17 07:44:42,681 ERROR [IndexedDiskCache] Region [online_technical_metadata] Failure updating element, key: http://127.0.0.1:8001/cgi-bin/cable.sh?2 old: null
at sun.reflect.GeneratedMethodAccessor12.invoke(Unknown Source)
2016-10-17 14:38:58,155 ERROR [IndexedDiskCache] Region [online_technical_metadata] Failure updating element, key: http://127.0.0.1:8001/cgi-bin/dvd2.sh?/media/ex3/Video/K3b.iso old: null
zip wrote:I have released 1.7.1.1 which should fix the feed error above. get it on the download page.
momchil wrote:Yes, no change...
What is this "fixed metadata caching for online content" in changelog for 1.7.1? No more rescan after every restart?
