Norton Says "ServiioService.exe" Unsafe
PW_in_Irvine
Post Fri Nov 11, 2016 8:08 pm
Norton Security (Norton Power Eraser) finds that "c:\Program Files\Serviio\bin\ServiioService.exe" is "bad" and recommends that it be removed.
Info:
Windows 10 x64
Norton Security v. 22.8.0.50
Serviio Pro v. 1.7.1
Properties of subject file: ServiioService.exe, size: 413,696, created: Monday, October 10, 2016, 2:22:30 AM
I sent the subject file to Norton for its analysis but it hasn't responded to me yet (not that I expect it will). Does my version of ServiioService.exe (as described above) agree as to size, date and time with the unadulterated version that is part of Serviio 1.7.1, or do I possibly have a corrupted version?
Thx.
Post Sat Nov 12, 2016 1:24 am
Re: Norton Says "ServiioService.exe" Unsafe
I've heard of this occasionally in the past. The AV scanner is looking for something that the application does that it thinks is a potential issue. They need to update their internal application whitelist.
PW_in_Irvine
Post Tue Nov 15, 2016 12:59 am
atc98092 wrote:I've heard of this occasionally in the past. The AV scanner is looking for something that the application does that it thinks is a potential issue. They need to update their internal application whitelist.
Thank you for your response.
Nevertheless, before I tell Norton "File Insight" to trust ServiioService.exe on my computer, can someone please confirm that the file properties that I posted above conform with Serviio ver. 1.7.1 instances of ServiioService.exe? That is, even if ServiioService.exe eventually makes Norton's "whitelist," I want to make sure that I'm not running a corrupted version of it, especially since Norton says that the instance of the file that I'm running is "bad" and wants to remove it.
Thanks much.
Users browsing this forum: Baidu [Spider] and 18 guests
