Bookmarking on Samsung C series
luiz_borges
Post Wed Mar 16, 2011 9:27 pm
Re: Bookmarking on Samsung C series
Cerberus, I thought it might be relevant since the way to select a file is the same (Select Video -> Browse to the right folder -> Select file -> Play). DNLA, USB and DVD-ROM all work like that, so I guess it must be somewhat related.
If anything, I think DNLA has LESS resources than DVD or USB, since with the latter I can use the fast-forward and rewind buttons, and with DNLA I can only use the arrows.
fireyone
Post Wed Mar 16, 2011 9:33 pm
zip wrote:No need to set any setting, just use Samsung profile.
I don't have the player, but other said after you play the video, there is a blue button displayed for a few seconds that enables you to resume. Some also had to restart/unplug the TV/player for it to pick up this new Serviio feature (probably caches it)
Unplugging the TV and walking away for 20 minutes, then plugging it back in did not fix the issue. I also tried different methods of resuming the file, including resuming with powering off the TV and without.
Post Wed Mar 16, 2011 9:35 pm
luiz_borges wrote:Cerberus, I thought it might be relevant since the way to select a file is the same (Select Video -> Browse to the right folder -> Select file -> Play). DNLA, USB and DVD-ROM all work like that, so I guess it must be somewhat related.
Agreed but my point was we HAD it working but something broke, so we know it possible but not sure why it not constant.
FFWD and RWD dont work well on any DLNA device so far samsung seem to work the best with it < and > buttons.
sorry if i sounded blunt but if we add to many other things to the mix we may never get it working and that would be a real loss to us ppl using samsung products and to serviio as a whole..
Post Wed Mar 16, 2011 10:12 pm
here the log for you ZIP.
serviio.zip
detailed log
(176.32 KiB) Downloaded 862 times
Chz
Post Thu Mar 17, 2011 9:46 pm
It's working just fine for DiVX files on my C650. I tested it on Family Guy just now, and it tells you to hit the blue D to resume - works flawlessly.
sohail579
Post Fri Mar 18, 2011 2:58 am
its not working on my c7000 plasma either!
Post Fri Mar 18, 2011 3:07 pm
is it possible that it only works with specific file types? (e.g. only those that you can use FFWD/REV for)
fireyone
Post Fri Mar 18, 2011 3:13 pm
zip wrote:is it possible that it only works with specific file types? (e.g. only those that you can use FFWD/REV for)
I have tried with .avi (divx),.mkv, and .mp4. None has worked. And of course with Samsung TVs we cannot actually use the FFWD and REW buttons on served files. Those are the only file types I have.
Post Fri Mar 18, 2011 3:58 pm
you can ffwd/rev with the arrow keys (on some files only)
fireyone
Post Fri Mar 18, 2011 4:06 pm
Oh, in that case, I can do that with all the files I have tried to do so. None have the resume function though.
Post Fri Mar 18, 2011 8:34 pm
fireyone wrote:Oh, in that case, I can do that with all the files I have tried to do so. None have the resume function though.
i second that ffwd and rw function work even though resume does not..
Post Fri Mar 18, 2011 10:01 pm
I'm buying a C series LED tomorrow, so I'll be able to test it too :-)
drago17
Post Sat Mar 19, 2011 1:02 am
zip wrote:I'm buying a C series LED tomorrow, so I'll be able to test it too :-)
what model?
Post Sat Mar 19, 2011 7:55 am
sweet :) more samsung support coming :D if zip has it to test on :D
Mayki
Post Sat Mar 19, 2011 10:12 am
So I rejoiced prematurely, bookmarks, I suddenly stopped working, I did not change anything, one day it worked flawlessly, the other day that it does not work at all. Any idea? :idea: Serviio 0.5.1. Samsung TV UE40C6620.
Takže jsem se radoval předčasně, záložky mi z ničeho nic přestaly fungovat, nic jsem neměnil, jeden den to fungovalo bezchybně, druhý den to už nefunguje vůbec. Nějaký nápad?
Post Sat Mar 19, 2011 5:11 pm
______ UPDATE ______
For some reason bookmark have stopped working or work erracticly and at the moment the serviio team have no idea why, we are working to get this sorted and will post back here once we fix this, if you find you can get bookmarks working consistantly and can explain exactly how you made this work then please post, otherwise you will just need to wait till its sorted. :)
Post Sun Mar 20, 2011 12:02 pm
what model?
Bought UE40C6530 ... nice TV, but :
1) the DLNA UI sucks, on my B650 it's much better, especially DVD thumbnails are not stretched
2) ffwd/rew with arrows only works by jumping 20secs or so, on B650 the longer you hold it the further you get in the film
Bookmarks don't work for me either, will try to investigate. Could it be firmware based? Did those who had it working update firmware recently?
Post Sun Mar 20, 2011 12:20 pm
zip wrote:
what model?
Bought LE40C6530 ... nice TV, but :
1) ok
2) Yer that what i said, maybe it work slightly differently on C series and code just need tweaking ?
3) nope mine actualy work for a few file after i did last firmware update.
zaphod7501
Post Sun Mar 20, 2011 1:14 pm
Speaking from pretty much a zero knowledge base - could it have anything to do with the fact that the player/TV always shows up as an "Unrecognized device" rather than as some specific Samsung machine ?
Post Sun Mar 20, 2011 2:19 pm
zaphod7501 wrote:Speaking from pretty much a zero knowledge base - could it have anything to do with the fact that the player/TV always shows up as an "Unrecognized device" rather than as some specific Samsung machine ?
nope as samsung devices are auto detected and dont show up as Unrecognised.
Users browsing this forum: Google [Bot] and 19 guests
