patters
Post Sat Jan 07, 2017 2:27 am
Re: PACKAGE: Serviio 1.8 - Synology NAS, with HW transcoding
I have published a new version of the Serviio package - finally up to date!
Post Sat Jan 07, 2017 8:34 pm
Hy Patters and thanks for that job !
I have an audio issue with the new 1.8 version (that was working with previous 1.6 version). There were no audio on my Sony Bravia TV (2010).
The avi/MP4/MP3 that previously transcoded well, seems broken now.
Any ideas ?
Post Sat Jan 07, 2017 8:56 pm
I'd think maybe the ffmpeg wrapper is not right in regards to the multi-track delivery in Serviio 1.7.
patters
Post Sat Jan 07, 2017 11:47 pm
The wrapper is only invoked on the two NAS models I support for hardware transcoding - DS214Play and DS415Play because I have to alter the ffmpeg commandline for that. On any other Synology model: no wrapper.
Which NAS do you have Illico?
Post Sun Jan 08, 2017 8:36 am
patters wrote:...Which NAS do you have Illico?
a SynoDS116
illico@SynoDS116:~$ uname -a
Linux SynoDS116 3.10.77 #8451 SMP Wed Aug 17 05:12:58 CST 2016 armv7l GNU/Linux synology_armada38x_ds116
illico@SynoDS116:~$ cat /proc/cpuinfo
processor : 0
model name : ARMv7 Processor rev 1 (v7l)
BogoMIPS : 3719.16
Features : swp half thumb fastmult vfp edsp neon vfpv3 tls
CPU implementer : 0x41
CPU architecture: 7
CPU variant : 0x4
CPU part : 0xc09
CPU revision : 1
processor : 1
BogoMIPS : 3726.54
CPU architecture: 7
CPU variant : 0x4
CPU part : 0xc09
CPU revision : 1
Hardware : Marvell Armada 380/381/382/383/384/385/388 (Device Tree)
Revision : 0000
Serial : 0000000000000000
Later, last night, the sound reappeared !! Probably a library update was needed or something else, I simply restarted the serviio service.
Sorry for the disrupt and many thanks for all these builds.
nevets14
Post Tue Jan 10, 2017 12:49 am
Hey Patters,
Is there anyway to force the Serviio Pro Evaluation to expire immediately?
patters
Post Tue Jan 10, 2017 3:14 pm
Not that I'm aware of. That's all taken care of internally to Serviio so not something I have any visibility of.
kiskouli
Post Thu Jan 19, 2017 4:39 pm
Thank you Patters! all went fine from dsm 6 mandatory upgrade to 1.8 upgrade
No pb yet at this time :)
Quinny
Post Fri Jan 20, 2017 8:25 am
Coming from QNAP to Synology for my new NAS. Downloaded the Serviio 1.8 (many thanks Platters for the work on this) and says need Java. Did the Oracle Java/register stuff and it gives me
ejdk-8u121-linux-i586.tar.gz not 111 every time which will not work as says need 111.
Going mad in tiny tiny circles :(
EDIT - Hmm I do have bad luck with this stuff. Its super new.
8u121 Update Release Notes
January 17, 2017
Serviio fan. DLNA to Panasonic VT tvs, QNAP 651 and Synology 916 NAS boxes.
Quinny
Post Sun Jan 22, 2017 9:46 am
Java has been fixed so now able to download 121 and get working with 1.8. Yay :D
darthnic
Post Fri Jan 27, 2017 2:02 pm
Hey
I just updated Serviio and java to latest versions, but now Serviio won't start at all. I also tried removing everything and reinstalling and I tried to use the synology java pack.
I'm on a DS214+ (MARVELL Armada XP MV78230 1.33gHz)
Here's the serviio log:
2017-01-27 14:24:32,000 Starting Serviio
Java HotSpot(TM) Embedded Client VM warning: G1 GC is disabled in this release.
2017-01-27 14:24:34,352 INFO  [MediaServer] ------------------------------------------------------------------------
2017-01-27 14:24:34,355 INFO  [MediaServer] Serviio DLNA media streaming server v 1.8 (rev. cc55b64588cc)
2017-01-27 14:24:34,356 INFO  [MediaServer] Petr Nejedly 2009-2015
2017-01-27 14:24:34,356 INFO  [MediaServer] http://www.serviio.org
2017-01-27 14:24:34,356 INFO  [MediaServer] Java 1.8.0_121-Oracle Corporation arm
2017-01-27 14:24:34,356 INFO  [MediaServer] OS Linux 3.2.40
2017-01-27 14:24:34,357 INFO  [MediaServer] File encoding: UTF-8
2017-01-27 14:24:34,655 INFO  [MediaServer] Headless mode enabled: true
2017-01-27 14:24:34,656 INFO  [MediaServer] User: root
2017-01-27 14:24:34,656 INFO  [MediaServer] User home dir: /root
2017-01-27 14:24:34,656 INFO  [MediaServer] Temp dir: /tmp
2017-01-27 14:24:34,656 INFO  [MediaServer] ------------------------------------------------------------------------
2017-01-27 14:24:34,721 INFO  [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2017-01-27 14:24:34,786 INFO  [DatabaseManager] Using DERBY database language
2017-01-27 14:24:40,083 INFO  [DBSchemaUpdateExecutor] Updating DB schema
2017-01-27 14:24:44,721 INFO  [DBSchemaUpdateExecutor] Dropping search index
2017-01-27 14:24:44,733 INFO  [SearchManager] Starting up search engine
2017-01-27 14:24:45,559 INFO  [DBSchemaUpdateExecutor] Cleaning temporary cache
2017-01-27 14:24:45,658 INFO  [WebServer] Socket buffer set to 65535 bytes
2017-01-27 14:24:45,660 INFO  [Device] Created UPnP Device with UUID: 06ad804e-6285-371f-8f66-eef7f1ef4b64, bound address: 192.168.0.160
2017-01-27 14:24:46,004 INFO  [DBSchemaUpdateExecutor] Cleaning persistent cache
2017-01-27 14:24:46,060 WARN  [IndexedDiskCache] Region [online_technical_metadata] Reseting cache
2017-01-27 14:24:46,484 INFO  [RestletServer] Starting HTTP/1.1 Restlet server (/console) exposed on port 23423
2017-01-27 14:24:46,495 INFO  [RestletServer] Starting HTTP/1.1 Restlet server (/rest) exposed on port 23423
2017-01-27 14:24:46,497 INFO  [RestletServer] Starting HTTPS/1.1 Restlet server (/console) exposed on port 23523
2017-01-27 14:24:46,498 INFO  [RestletServer] Starting HTTPS/1.1 Restlet server (/rest) exposed on port 23523
2017-01-27 14:24:46,850 ERROR [MediaServer] An unexpected error occured. Ending the application. Message: Can not initialize cryptographic mechanism
java.lang.ExceptionInInitializerError
   at javax.crypto.JceSecurityManager.<clinit>(JceSecurityManager.java:65)
   at javax.crypto.Cipher.getConfiguredPermission(Cipher.java:2587)
   at javax.crypto.Cipher.getMaxAllowedKeyLength(Cipher.java:2611)
   at sun.security.ssl.CipherSuite$BulkCipher.isUnlimited(CipherSuite.java:535)
   at sun.security.ssl.CipherSuite$BulkCipher.<init>(CipherSuite.java:507)
   at sun.security.ssl.CipherSuite.<clinit>(CipherSuite.java:614)
   at sun.security.ssl.SSLContextImpl.getApplicableCipherSuiteList(SSLContextImpl.java:293)
   at sun.security.ssl.SSLContextImpl.access$100(SSLContextImpl.java:41)
   at sun.security.ssl.SSLContextImpl$AbstractTLSContext.<clinit>(SSLContextImpl.java:424)
   at java.lang.Class.forName0(Native Method)
   at java.lang.Class.forName(Class.java:264)
   at java.security.Provider$Service.getImplClass(Provider.java:1634)
   at java.security.Provider$Service.newInstance(Provider.java:1592)
   at sun.security.jca.GetInstance.getInstance(GetInstance.java:236)
   at sun.security.jca.GetInstance.getInstance(GetInstance.java:164)
   at javax.net.ssl.SSLContext.getInstance(SSLContext.java:156)
   at org.restlet.engine.ssl.DefaultSslContextFactory.createSslContext(DefaultSslContextFactory.java:369)
   at org.restlet.ext.simple.HttpsServerHelper.start(HttpsServerHelper.java:98)
   at org.restlet.Server.start(Server.java:588)
   at org.restlet.Component.startServers(Component.java:637)
   at org.restlet.Component.start(Component.java:562)
   at org.serviio.restlet.RestletServer.startComponent(RestletServer.java:172)
   at org.serviio.restlet.RestletServer.runServer(RestletServer.java:80)
   at org.serviio.MediaServer.main(MediaServer.java:128)
Caused by: java.lang.SecurityException: Can not initialize cryptographic mechanism
   at javax.crypto.JceSecurity.<clinit>(JceSecurity.java:88)
   ... 24 more
Caused by: java.lang.SecurityException: Invalid signature file digest for Manifest main attributes
   at sun.security.util.SignatureFileVerifier.processImpl(SignatureFileVerifier.java:314)
   at sun.security.util.SignatureFileVerifier.process(SignatureFileVerifier.java:268)
   at java.util.jar.JarVerifier.processEntry(JarVerifier.java:316)
   at java.util.jar.JarVerifier.update(JarVerifier.java:228)
   at java.util.jar.JarFile.initializeVerifier(JarFile.java:383)
   at java.util.jar.JarFile.getInputStream(JarFile.java:450)
   at javax.crypto.JceSecurity.loadPolicies(JceSecurity.java:300)
   at javax.crypto.JceSecurity.setupJurisdictionPolicies(JceSecurity.java:262)
   at javax.crypto.JceSecurity.access$000(JceSecurity.java:48)
   at javax.crypto.JceSecurity$1.run(JceSecurity.java:80)
   at javax.crypto.JceSecurity.<clinit>(JceSecurity.java:77)
   ... 24 more
2017-01-27 14:24:46,860 WARN  [IndexedDiskCache] Region [subtitles] Disk cache not shutdown properly, shutting down now.
2017-01-27 14:24:46,864 WARN  [IndexedDiskCache] Region [tokens] Disk cache not shutdown properly, shutting down now.
2017-01-27 14:24:46,862 WARN  [IndexedDiskCache] Region [online_technical_metadata] Disk cache not shutdown properly, shutting down now.
2017-01-27 14:24:46,869 WARN  [IndexedDiskCache] Region [subtitles_metadata] Disk cache not shutdown properly, shutting down now.
2017-01-27 14:24:46,872 WARN  [IndexedDiskCache] Region [thumbnails] Disk cache not shutdown properly, shutting down now.
patters
Post Sun Jan 29, 2017 1:42 pm
Can you try to use the Java 8 Embedded package from my repo instead of the Synology package?
darthnic
Post Sun Jan 29, 2017 7:23 pm
patters wrote:Can you try to use the Java 8 Embedded package from my repo instead of the Synology package?
I went back to embedded java 8 immediatly when the synology one didn't work, I only tried it because it worked for me previously when I had problems.
patters
Post Mon Jan 30, 2017 10:16 am
Since the error mentions cipher mechanisms being the problem, can you confirm whether you installed Java 8 Embedded with our without the unlimited strength cryptography option. AFAIK it isn't normally necessary, but perhaps it may fix the issue you're seeing.
darthnic
Post Mon Jan 30, 2017 10:23 am
patters wrote:Since the error mentions cipher mechanisms being the problem, can you confirm whether you installed Java 8 Embedded with our without the unlimited strength cryptography option. AFAIK it isn't normally necessary, but perhaps it may fix the issue you're seeing.
Without :)
darthnic
Post Mon Jan 30, 2017 11:49 am
Without :)
Just for the hell of it I tried installing your java 8 package with unlimited strength and then try to run Serviio again.
The log now reports this
2017-01-30 12:43:01,283 INFO  [MediaServer] ------------------------------------------------------------------------
2017-01-30 12:43:01,287 INFO  [MediaServer] Serviio DLNA media streaming server v 1.8 (rev. cc55b64588cc)
2017-01-30 12:43:01,287 INFO  [MediaServer] Petr Nejedly 2009-2015
2017-01-30 12:43:01,287 INFO  [MediaServer] http://www.serviio.org
2017-01-30 12:43:01,288 INFO  [MediaServer] Java 1.8.0_121-Oracle Corporation arm
2017-01-30 12:43:01,288 INFO  [MediaServer] OS Linux 3.2.40
2017-01-30 12:43:01,288 INFO  [MediaServer] File encoding: UTF-8
2017-01-30 12:43:01,756 INFO  [MediaServer] Headless mode enabled: true
2017-01-30 12:43:01,757 INFO  [MediaServer] User: root
2017-01-30 12:43:01,757 INFO  [MediaServer] User home dir: /root
2017-01-30 12:43:01,757 INFO  [MediaServer] Temp dir: /tmp
2017-01-30 12:43:01,757 INFO  [MediaServer] ------------------------------------------------------------------------
2017-01-30 12:43:01,902 INFO  [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2017-01-30 12:43:02,033 INFO  [DatabaseManager] Using DERBY database language
2017-01-30 12:43:04,472 WARN  [DBConnectionPool] Can't create a new connection for jdbc:derby:db;create=true
java.sql.SQLException: Failed to start database 'db' with class loader sun.misc.Launcher$AppClassLoader@1f96302, see the next exception for details.
   at org.apache.derby.impl.jdbc.EmbedConnection.bootDatabase(Unknown Source)
   at org.apache.derby.impl.jdbc.EmbedConnection.<init>(Unknown Source)
   at org.apache.derby.jdbc.InternalDriver$1.run(Unknown Source)
   at org.apache.derby.jdbc.InternalDriver.getNewEmbedConnection(Unknown Source)
   at org.apache.derby.jdbc.InternalDriver.connect(Unknown Source)
   at org.apache.derby.jdbc.AutoloadedDriver.connect(Unknown Source)
   at java.sql.DriverManager.getConnection(DriverManager.java:664)
   at java.sql.DriverManager.getConnection(DriverManager.java:270)
   at org.serviio.db.DBConnectionPool.newConnection(DBConnetionPool.java:186)
   at org.serviio.db.DBConnectionPool.getConnection(DBConnetionPool.java:123)
   at org.serviio.db.DBConnectionPool.getConnection(DBConnetionPool.java:149)
   at org.serviio.db.DatabaseManager.getConnection(DatabaseManager.java:71)
   at org.serviio.db.DatabaseManager.getConnection(DatabaseManager.java:64)
   at org.serviio.update.dao.DBLogDAOImpl.isScriptPresent(DBLogDAOImpl.java:49)
   at org.serviio.update.DBSchemaUpdateExecutor.updateDBSchema(DBSchemaUpdateExecutor.java:80)
   at org.serviio.MediaServer.main(MediaServer.java:125)
Caused by: ERROR XJ040: Failed to start database 'db' with class loader sun.misc.Launcher$AppClassLoader@1f96302, see the next exception for details.
   at org.apache.derby.impl.jdbc.SQLExceptionFactory.wrapArgsForTransportAcrossDRDA(Unknown Source)
   ... 22 more
Caused by: java.lang.ArrayIndexOutOfBoundsException: 0
   at sun.nio.cs.UTF_8$Encoder.encode(UTF_8.java:716)
   at java.lang.StringCoding$StringEncoder.encode(StringCoding.java:304)
   at java.lang.StringCoding.encode(StringCoding.java:344)
   at java.lang.String.getBytes(String.java:918)
   at java.io.UnixFileSystem.getBooleanAttributes0(Native Method)
   at java.io.UnixFileSystem.getBooleanAttributes(UnixFileSystem.java:242)
   at java.io.File.exists(File.java:819)
   at org.apache.derby.impl.store.raw.data.RAFContainer.privGetFileName(Unknown Source)
   at org.apache.derby.impl.store.raw.data.RAFContainer.run(Unknown Source)
   at org.apache.derby.impl.store.raw.data.RAFContainer.openContainer(Unknown Source)
   at org.apache.derby.impl.store.raw.data.RAFContainer4.openContainer(Unknown Source)
   at org.apache.derby.impl.store.raw.data.FileContainer.setIdent(Unknown Source)
   at org.apache.derby.impl.store.raw.data.FileContainer.setIdentity(Unknown Source)
   at org.apache.derby.impl.services.cache.ConcurrentCache.find(Unknown Source)
   at org.apache.derby.impl.store.raw.data.BaseDataFileFactory.openContainer(Unknown Source)
   at org.apache.derby.impl.store.raw.data.BaseDataFileFactory.openDroppedContainer(Unknown Source)
   at org.apache.derby.impl.store.raw.xact.Xact.openDroppedContainer(Unknown Source)
   at org.apache.derby.impl.store.raw.data.ContainerBasicOperation.findContainer(Unknown Source)
   at org.apache.derby.impl.store.raw.data.ContainerBasicOperation.needsRedo(Unknown Source)
   at org.apache.derby.impl.store.raw.log.FileLogger.redo(Unknown Source)
   at org.apache.derby.impl.store.raw.log.LogToFile.recover(Unknown Source)
   at org.apache.derby.impl.store.raw.RawStore.boot(Unknown Source)
   at org.apache.derby.impl.services.monitor.BaseMonitor.boot(Unknown Source)
   at org.apache.derby.impl.services.monitor.TopService.bootModule(Unknown Source)
   at org.apache.derby.impl.services.monitor.BaseMonitor.startModule(Unknown Source)
   at org.apache.derby.impl.services.monitor.FileMonitor.startModule(Unknown Source)
   at org.apache.derby.iapi.services.monitor.Monitor.bootServiceModule(Unknown Source)
   at org.apache.derby.impl.store.access.RAMAccessManager$5.run(Unknown Source)
   at org.apache.derby.impl.store.access.RAMAccessManager.bootServiceModule(Unknown Source)
   at org.apache.derby.impl.store.access.RAMAccessManager.boot(Unknown Source)
   at org.apache.derby.impl.db.BasicDatabase$5.run(Unknown Source)
   at org.apache.derby.impl.db.BasicDatabase.bootServiceModule(Unknown Source)
   at org.apache.derby.impl.db.BasicDatabase.bootStore(Unknown Source)
   at org.apache.derby.impl.db.BasicDatabase.boot(Unknown Source)
   at org.apache.derby.impl.services.monitor.BaseMonitor.bootService(Unknown Source)
   at org.apache.derby.impl.services.monitor.BaseMonitor.startProviderService(Unknown Source)
   at org.apache.derby.impl.services.monitor.BaseMonitor.findProviderAndStartService(Unknown Source)
   at org.apache.derby.impl.services.monitor.BaseMonitor.startPersistentService(Unknown Source)
   at org.apache.derby.iapi.services.monitor.Monitor.startPersistentService(Unknown Source)
   at org.apache.derby.impl.jdbc.EmbedConnection$4.run(Unknown Source)
   at org.apache.derby.impl.jdbc.EmbedConnection.startPersistentService(Unknown Source)
   ... 19 more
2017-01-30 12:43:06,495 ERROR [MediaServer] An unexpected error occured. Ending the application. Message: null
   at org.serviio.update.dao.DBLogDAOImpl.isScriptPresent(DBLogDAOImpl.java:50)
darthnic
Post Tue Jan 31, 2017 7:30 pm
darthnic wrote:
Without :)
   ... 22 more
   ... 19 more
And so just for the hell of it I downgraded to 1.6.0 and used the Syno java package and then it works. I'm baffled and annoyed :/
EDIT: and I then upgraded to serviio 1.8 and it works, kinda. Strange java stuff in the console and it can't play half of the videos.
Biker
Post Wed Mar 01, 2017 8:05 pm
has anyone tried Serviio with Synology DSM 6.1? Does it work?
Thanks,
Biker
ctrippel
Post Sat Mar 04, 2017 4:15 am
Just upgraded to Serviio 1.8, on Synology DS412+, DSM 6.1-15047-Update 1, Synology Java package 8.0.101-0011.
Serviio is still running updates on metadata, but videos appear to function correctly (almost exclusively m4v files).
Serviio web management interface, Status page is non-functional:
<IP>:23423/console/#/app/status
Looks like it's not rendering correctly. ALL device 'grid' element, input labels, and button text are showing as 'code':
{{'tab_status_connected_devices' | translate}}
{{'tab_status_connected_devices_overview' | translate}}
{{'tab_status_status_running' | translate}}
etc.
Transcoding page, looks like a checkbox label is wrong:
<IP>:23423/console/#/app/delivery/transcoding
Video settings 2nd checkbox label = 'tab_transcoding_include_all_audio_streams
Subtitles page, also looks like labels are wrong:
<IP>:23423/console/#/app/delivery/subtitles
All checkbox / textbox labels look like variable names: e.g. tab_subtitles_guess_character_encoding
Presentation page, one label looks wrong, all others Ok:
<IP>:23423/console/#/app/presentation
tab_presentation_include_rating_in_video_titles
Going to wait until after metadata rebuild before experimenting with Java packages to see if that resolves the web interface issue.
Biker
Post Sat Mar 04, 2017 9:32 am
Thank you for your reply, I'll be waiting for another update!
Users browsing this forum: Baidu [Spider] and 20 guests
