Re: PACKAGE: Serviio 1.8 - Synology NAS, with HW transcoding
patters wrote:...Which NAS do you have Illico?
illico@SynoDS116:~$ uname -a
Linux SynoDS116 3.10.77 #8451 SMP Wed Aug 17 05:12:58 CST 2016 armv7l GNU/Linux synology_armada38x_ds116
illico@SynoDS116:~$ cat /proc/cpuinfo
processor : 0
model name : ARMv7 Processor rev 1 (v7l)
BogoMIPS : 3719.16
Features : swp half thumb fastmult vfp edsp neon vfpv3 tls
CPU implementer : 0x41
CPU architecture: 7
CPU variant : 0x4
CPU part : 0xc09
CPU revision : 1
processor : 1
BogoMIPS : 3726.54
CPU architecture: 7
CPU variant : 0x4
CPU part : 0xc09
CPU revision : 1
Hardware : Marvell Armada 380/381/382/383/384/385/388 (Device Tree)
Revision : 0000
Serial : 0000000000000000
8u121 Update Release Notes
January 17, 2017
2017-01-27 14:24:32,000 Starting Serviio
Java HotSpot(TM) Embedded Client VM warning: G1 GC is disabled in this release.
2017-01-27 14:24:34,352 INFO [MediaServer] ------------------------------------------------------------------------
2017-01-27 14:24:34,355 INFO [MediaServer] Serviio DLNA media streaming server v 1.8 (rev. cc55b64588cc)
2017-01-27 14:24:34,356 INFO [MediaServer] Petr Nejedly 2009-2015
2017-01-27 14:24:34,356 INFO [MediaServer] http://www.serviio.org
2017-01-27 14:24:34,356 INFO [MediaServer] Java 1.8.0_121-Oracle Corporation arm
2017-01-27 14:24:34,356 INFO [MediaServer] OS Linux 3.2.40
2017-01-27 14:24:34,357 INFO [MediaServer] File encoding: UTF-8
2017-01-27 14:24:34,655 INFO [MediaServer] Headless mode enabled: true
2017-01-27 14:24:34,656 INFO [MediaServer] User: root
2017-01-27 14:24:34,656 INFO [MediaServer] User home dir: /root
2017-01-27 14:24:34,656 INFO [MediaServer] Temp dir: /tmp
2017-01-27 14:24:34,656 INFO [MediaServer] ------------------------------------------------------------------------
2017-01-27 14:24:34,721 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2017-01-27 14:24:34,786 INFO [DatabaseManager] Using DERBY database language
2017-01-27 14:24:40,083 INFO [DBSchemaUpdateExecutor] Updating DB schema
2017-01-27 14:24:44,721 INFO [DBSchemaUpdateExecutor] Dropping search index
2017-01-27 14:24:44,733 INFO [SearchManager] Starting up search engine
2017-01-27 14:24:45,559 INFO [DBSchemaUpdateExecutor] Cleaning temporary cache
2017-01-27 14:24:45,658 INFO [WebServer] Socket buffer set to 65535 bytes
2017-01-27 14:24:45,660 INFO [Device] Created UPnP Device with UUID: 06ad804e-6285-371f-8f66-eef7f1ef4b64, bound address: 192.168.0.160
2017-01-27 14:24:46,004 INFO [DBSchemaUpdateExecutor] Cleaning persistent cache
2017-01-27 14:24:46,060 WARN [IndexedDiskCache] Region [online_technical_metadata] Reseting cache
2017-01-27 14:24:46,484 INFO [RestletServer] Starting HTTP/1.1 Restlet server (/console) exposed on port 23423
2017-01-27 14:24:46,495 INFO [RestletServer] Starting HTTP/1.1 Restlet server (/rest) exposed on port 23423
2017-01-27 14:24:46,497 INFO [RestletServer] Starting HTTPS/1.1 Restlet server (/console) exposed on port 23523
2017-01-27 14:24:46,498 INFO [RestletServer] Starting HTTPS/1.1 Restlet server (/rest) exposed on port 23523
2017-01-27 14:24:46,850 ERROR [MediaServer] An unexpected error occured. Ending the application. Message: Can not initialize cryptographic mechanism
java.lang.ExceptionInInitializerError
at javax.crypto.JceSecurityManager.<clinit>(JceSecurityManager.java:65)
at javax.crypto.Cipher.getConfiguredPermission(Cipher.java:2587)
at javax.crypto.Cipher.getMaxAllowedKeyLength(Cipher.java:2611)
at sun.security.ssl.CipherSuite$BulkCipher.isUnlimited(CipherSuite.java:535)
at sun.security.ssl.CipherSuite$BulkCipher.<init>(CipherSuite.java:507)
at sun.security.ssl.CipherSuite.<clinit>(CipherSuite.java:614)
at sun.security.ssl.SSLContextImpl.getApplicableCipherSuiteList(SSLContextImpl.java:293)
at sun.security.ssl.SSLContextImpl.access$100(SSLContextImpl.java:41)
at sun.security.ssl.SSLContextImpl$AbstractTLSContext.<clinit>(SSLContextImpl.java:424)
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Class.java:264)
at java.security.Provider$Service.getImplClass(Provider.java:1634)
at java.security.Provider$Service.newInstance(Provider.java:1592)
at sun.security.jca.GetInstance.getInstance(GetInstance.java:236)
at sun.security.jca.GetInstance.getInstance(GetInstance.java:164)
at javax.net.ssl.SSLContext.getInstance(SSLContext.java:156)
at org.restlet.engine.ssl.DefaultSslContextFactory.createSslContext(DefaultSslContextFactory.java:369)
at org.restlet.ext.simple.HttpsServerHelper.start(HttpsServerHelper.java:98)
at org.restlet.Server.start(Server.java:588)
at org.restlet.Component.startServers(Component.java:637)
at org.restlet.Component.start(Component.java:562)
at org.serviio.restlet.RestletServer.startComponent(RestletServer.java:172)
at org.serviio.restlet.RestletServer.runServer(RestletServer.java:80)
at org.serviio.MediaServer.main(MediaServer.java:128)
Caused by: java.lang.SecurityException: Can not initialize cryptographic mechanism
at javax.crypto.JceSecurity.<clinit>(JceSecurity.java:88)
... 24 more
Caused by: java.lang.SecurityException: Invalid signature file digest for Manifest main attributes
at sun.security.util.SignatureFileVerifier.processImpl(SignatureFileVerifier.java:314)
at sun.security.util.SignatureFileVerifier.process(SignatureFileVerifier.java:268)
at java.util.jar.JarVerifier.processEntry(JarVerifier.java:316)
at java.util.jar.JarVerifier.update(JarVerifier.java:228)
at java.util.jar.JarFile.initializeVerifier(JarFile.java:383)
at java.util.jar.JarFile.getInputStream(JarFile.java:450)
at javax.crypto.JceSecurity.loadPolicies(JceSecurity.java:300)
at javax.crypto.JceSecurity.setupJurisdictionPolicies(JceSecurity.java:262)
at javax.crypto.JceSecurity.access$000(JceSecurity.java:48)
at javax.crypto.JceSecurity$1.run(JceSecurity.java:80)
at javax.crypto.JceSecurity.<clinit>(JceSecurity.java:77)
... 24 more
2017-01-27 14:24:46,860 WARN [IndexedDiskCache] Region [subtitles] Disk cache not shutdown properly, shutting down now.
2017-01-27 14:24:46,864 WARN [IndexedDiskCache] Region [tokens] Disk cache not shutdown properly, shutting down now.
2017-01-27 14:24:46,862 WARN [IndexedDiskCache] Region [online_technical_metadata] Disk cache not shutdown properly, shutting down now.
2017-01-27 14:24:46,869 WARN [IndexedDiskCache] Region [subtitles_metadata] Disk cache not shutdown properly, shutting down now.
2017-01-27 14:24:46,872 WARN [IndexedDiskCache] Region [thumbnails] Disk cache not shutdown properly, shutting down now.
patters wrote:Can you try to use the Java 8 Embedded package from my repo instead of the Synology package?
patters wrote:Since the error mentions cipher mechanisms being the problem, can you confirm whether you installed Java 8 Embedded with our without the unlimited strength cryptography option. AFAIK it isn't normally necessary, but perhaps it may fix the issue you're seeing.
darthnic wrote:patters wrote:Since the error mentions cipher mechanisms being the problem, can you confirm whether you installed Java 8 Embedded with our without the unlimited strength cryptography option. AFAIK it isn't normally necessary, but perhaps it may fix the issue you're seeing.
Without
2017-01-30 12:43:01,283 INFO [MediaServer] ------------------------------------------------------------------------
2017-01-30 12:43:01,287 INFO [MediaServer] Serviio DLNA media streaming server v 1.8 (rev. cc55b64588cc)
2017-01-30 12:43:01,287 INFO [MediaServer] Petr Nejedly 2009-2015
2017-01-30 12:43:01,287 INFO [MediaServer] http://www.serviio.org
2017-01-30 12:43:01,288 INFO [MediaServer] Java 1.8.0_121-Oracle Corporation arm
2017-01-30 12:43:01,288 INFO [MediaServer] OS Linux 3.2.40
2017-01-30 12:43:01,288 INFO [MediaServer] File encoding: UTF-8
2017-01-30 12:43:01,756 INFO [MediaServer] Headless mode enabled: true
2017-01-30 12:43:01,757 INFO [MediaServer] User: root
2017-01-30 12:43:01,757 INFO [MediaServer] User home dir: /root
2017-01-30 12:43:01,757 INFO [MediaServer] Temp dir: /tmp
2017-01-30 12:43:01,757 INFO [MediaServer] ------------------------------------------------------------------------
2017-01-30 12:43:01,902 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2017-01-30 12:43:02,033 INFO [DatabaseManager] Using DERBY database language
2017-01-30 12:43:04,472 WARN [DBConnectionPool] Can't create a new connection for jdbc:derby:db;create=true
java.sql.SQLException: Failed to start database 'db' with class loader sun.misc.Launcher$AppClassLoader@1f96302, see the next exception for details.
at org.apache.derby.impl.jdbc.EmbedConnection.bootDatabase(Unknown Source)
at org.apache.derby.impl.jdbc.EmbedConnection.<init>(Unknown Source)
at org.apache.derby.jdbc.InternalDriver$1.run(Unknown Source)
at org.apache.derby.jdbc.InternalDriver.getNewEmbedConnection(Unknown Source)
at org.apache.derby.jdbc.InternalDriver.connect(Unknown Source)
at org.apache.derby.jdbc.AutoloadedDriver.connect(Unknown Source)
at java.sql.DriverManager.getConnection(DriverManager.java:664)
at java.sql.DriverManager.getConnection(DriverManager.java:270)
at org.serviio.db.DBConnectionPool.newConnection(DBConnetionPool.java:186)
at org.serviio.db.DBConnectionPool.getConnection(DBConnetionPool.java:123)
at org.serviio.db.DBConnectionPool.getConnection(DBConnetionPool.java:149)
at org.serviio.db.DatabaseManager.getConnection(DatabaseManager.java:71)
at org.serviio.db.DatabaseManager.getConnection(DatabaseManager.java:64)
at org.serviio.update.dao.DBLogDAOImpl.isScriptPresent(DBLogDAOImpl.java:49)
at org.serviio.update.DBSchemaUpdateExecutor.updateDBSchema(DBSchemaUpdateExecutor.java:80)
at org.serviio.MediaServer.main(MediaServer.java:125)
Caused by: ERROR XJ040: Failed to start database 'db' with class loader sun.misc.Launcher$AppClassLoader@1f96302, see the next exception for details.
at org.apache.derby.impl.jdbc.SQLExceptionFactory.wrapArgsForTransportAcrossDRDA(Unknown Source)
... 22 more
Caused by: java.lang.ArrayIndexOutOfBoundsException: 0
at sun.nio.cs.UTF_8$Encoder.encode(UTF_8.java:716)
at java.lang.StringCoding$StringEncoder.encode(StringCoding.java:304)
at java.lang.StringCoding.encode(StringCoding.java:344)
at java.lang.String.getBytes(String.java:918)
at java.io.UnixFileSystem.getBooleanAttributes0(Native Method)
at java.io.UnixFileSystem.getBooleanAttributes(UnixFileSystem.java:242)
at java.io.File.exists(File.java:819)
at org.apache.derby.impl.store.raw.data.RAFContainer.privGetFileName(Unknown Source)
at org.apache.derby.impl.store.raw.data.RAFContainer.run(Unknown Source)
at org.apache.derby.impl.store.raw.data.RAFContainer.openContainer(Unknown Source)
at org.apache.derby.impl.store.raw.data.RAFContainer4.openContainer(Unknown Source)
at org.apache.derby.impl.store.raw.data.FileContainer.setIdent(Unknown Source)
at org.apache.derby.impl.store.raw.data.FileContainer.setIdentity(Unknown Source)
at org.apache.derby.impl.services.cache.ConcurrentCache.find(Unknown Source)
at org.apache.derby.impl.store.raw.data.BaseDataFileFactory.openContainer(Unknown Source)
at org.apache.derby.impl.store.raw.data.BaseDataFileFactory.openDroppedContainer(Unknown Source)
at org.apache.derby.impl.store.raw.xact.Xact.openDroppedContainer(Unknown Source)
at org.apache.derby.impl.store.raw.data.ContainerBasicOperation.findContainer(Unknown Source)
at org.apache.derby.impl.store.raw.data.ContainerBasicOperation.needsRedo(Unknown Source)
at org.apache.derby.impl.store.raw.log.FileLogger.redo(Unknown Source)
at org.apache.derby.impl.store.raw.log.LogToFile.recover(Unknown Source)
at org.apache.derby.impl.store.raw.RawStore.boot(Unknown Source)
at org.apache.derby.impl.services.monitor.BaseMonitor.boot(Unknown Source)
at org.apache.derby.impl.services.monitor.TopService.bootModule(Unknown Source)
at org.apache.derby.impl.services.monitor.BaseMonitor.startModule(Unknown Source)
at org.apache.derby.impl.services.monitor.FileMonitor.startModule(Unknown Source)
at org.apache.derby.iapi.services.monitor.Monitor.bootServiceModule(Unknown Source)
at org.apache.derby.impl.store.access.RAMAccessManager$5.run(Unknown Source)
at org.apache.derby.impl.store.access.RAMAccessManager.bootServiceModule(Unknown Source)
at org.apache.derby.impl.store.access.RAMAccessManager.boot(Unknown Source)
at org.apache.derby.impl.db.BasicDatabase$5.run(Unknown Source)
at org.apache.derby.impl.db.BasicDatabase.bootServiceModule(Unknown Source)
at org.apache.derby.impl.db.BasicDatabase.bootStore(Unknown Source)
at org.apache.derby.impl.db.BasicDatabase.boot(Unknown Source)
at org.apache.derby.impl.services.monitor.BaseMonitor.bootService(Unknown Source)
at org.apache.derby.impl.services.monitor.BaseMonitor.startProviderService(Unknown Source)
at org.apache.derby.impl.services.monitor.BaseMonitor.findProviderAndStartService(Unknown Source)
at org.apache.derby.impl.services.monitor.BaseMonitor.startPersistentService(Unknown Source)
at org.apache.derby.iapi.services.monitor.Monitor.startPersistentService(Unknown Source)
at org.apache.derby.impl.jdbc.EmbedConnection$4.run(Unknown Source)
at org.apache.derby.impl.jdbc.EmbedConnection.startPersistentService(Unknown Source)
... 19 more
2017-01-30 12:43:06,495 ERROR [MediaServer] An unexpected error occured. Ending the application. Message: null
at org.serviio.update.dao.DBLogDAOImpl.isScriptPresent(DBLogDAOImpl.java:50)
darthnic wrote:darthnic wrote:patters wrote:Since the error mentions cipher mechanisms being the problem, can you confirm whether you installed Java 8 Embedded with our without the unlimited strength cryptography option. AFAIK it isn't normally necessary, but perhaps it may fix the issue you're seeing.
Without
Just for the hell of it I tried installing your java 8 package with unlimited strength and then try to run Serviio again.
The log now reports this
- Code:
... 22 more
... 19 more
Users browsing this forum: Majestic-12 [Bot] and 7 guests
