Compatible devices list
What is the DLNA device you use Serviio with?
Samsung TV
239
30%
Sony TV
100
12%
Panasonic TV
64
8%
Other TV
41
5%
WDTV Live
51
6%
LG BD-xxx
21
3%
XBox 360
51
6%
Playstation 3
82
10%
Other (specify in the forum please)
161
20%
Total votes : 810
siren215
Post Wed Aug 12, 2015 6:51 am
Re: Compatible devices list
Sony KDL-40EX520
XBOX 360
IPAD2(Any IOS Device)
Nexus 5(Any Android Device)
summera
Post Sun Sep 06, 2015 3:31 am
I had a problem with my WDTV seeing Serviio at first, but it was because I was running PS3 Media Server at the same time.After I ran it by itself, it worked fine.
newby
Post Sun Dec 06, 2015 9:58 am
last years serviio work fine on:
Samsung LE46C750 and UE55SE6100
Android Tablets with serviigo
Apple ipad 3 with 8palyer
and other DLNA players
Last time.... after installation with windows 10 64bit pro.... serviio have a problem with communikation. i have send a message in other folder.
rgsurplus
Post Fri Feb 19, 2016 8:15 pm
works ok with sony 580 bluray
no nice thumbs or description (metatags)
I don't transcode works with 710 config some movies don't show up
skiaccianos
Post Wed Feb 24, 2016 7:29 pm
Sony KDL EX710 (2010), at home.
Everithings works with serviio 1.6, tested on my intel based (2008) laptop with both Ubuntu and Oracle Linux 7 (here you need some extra stuff: to enable epel and nux repo for ffmpeg and to grab libfribidi from nux/retired).
Running Serviio - for several years now - on Debian and Win boxes.
R850R biker, sysadmin & DBA, FOSS and Linux enthusiast (desktop_is_home_dir)
freaknik
Post Thu Feb 25, 2016 3:14 pm
Panasonic Bluray bdt-230 player
chromecast
Android phones, chinese android tablet, ipod touch back when that worked.
Serviio works on everything for me. I'm using 1.5 pro still with metadata turned off and its fast and reliable. Only thing that would make it better is more plugins for vaughlive.tv, streamlive.to, etc.
Rosales_Network
Post Mon Mar 14, 2016 4:22 am
I use Google Chrome Cast to cast to my tv since they are not smart. it woks well with the chrome cast no drops if you are running it from the source, If you run it via WLAN you might see delays.
and for the mobile I use a thrid party app to open and cast from my server
rivalcomp
Post Thu Apr 28, 2016 4:56 pm
First of all thanks for this great server. I've tried nearly all of them: MediaTomb, Plex, TwonkyServer, etc., all of them had some issues but I think I've found the ultimate solution... and finally QNAP is officially supported now... :)
Regarding device compatibility I have some problem with my Freecom MusicPal. In the server's settings it doesn't stick to the Playstation 3 profile. Why PS3 profile? I found that profile working with .flac files I have. With PS3 profile Serviio transcodes it to LPCM 48KHz. The problem is: after I restart the Musicpal, the profile always reverts back to Generic DLNA. So .flac files don't show up in list. I have to set it back to PS3, so everything is working again... until the next restart of the player.
I've already tried with other profiles (Toshiba Regza for example, that transcodes flac to mp3), the problem remains, it always reverts back to Generic profile. Other devices (like my TV) doesn't have this problem, it sticks to Samsung H series profile (set it manually because Serviio thought that is was a J series).
Do you have any idea? Thanks.
QNAP TS-469L, Serviio 1.6.1
Post Sat Apr 30, 2016 9:57 am
Try assigning a reserved IP to your Freecom device, then assign it to to PS3 profile. It should then be sticky.
If that doesn't work please start a new topic in the Support & Help area.
LIF
Post Tue Aug 23, 2016 7:46 am
I have a 2016 Sony Bravia KDL48R550C television which works well with Serviio but only using the Sony Bravia TV (2009) Profile.
The device name shows as NFLC SDK v1.5 in the Console status.
delphin
Post Sat Sep 17, 2016 9:23 am
I use Serviio with a Pioneer N50 A Network streamer, and find it to be the best server software I've tried. I have notice a big improvement in access times with 1.7
singerg
Post Sun Sep 18, 2016 8:13 pm
I use Serviio on an iMac, with Roku 2 as a client. Since I find no Roku group, I will post my question here. Serviio and the Roku work great, except that I have no capability to fast forward or reverse.
Tedward
Post Wed Dec 21, 2016 11:03 pm
Samsung UN46EH5300 TV
Samsung UN55KS8000 TV
BubbleUPnP on Samsung Galaxy S6
ServiiGo on Samsung Galaxy S6
Tedward
Oh, and WD TV Live
mariad
Post Thu Apr 06, 2017 6:55 am
I use ServiiGo on Samsung Galaxy S7
Luckyfriend222
Post Sat May 27, 2017 8:01 am
Serviio on Fedora
Samsung HT-E4500K BR player
Samsung UA55K7351KXXA
Jean-Max
Post Fri Jun 02, 2017 6:09 am
My TV Samsung 48' 4K UE48 HU7500 finds easily Serviio server of my networked W10 PC (1Gb wired ethernet)
I use Profile named "Samsung TV / Player (H-series)"
MKV, TS, MP4 videos are correctly played
I don't use Serviio for Music and Photos
Edit June 17: No change with 1.9 Beta 1
Jean-Max
Sherwood A+P-965 | Inwall JM-LAB | TV Samsung UE48HU7500 | Proj Sony sxrd W40 | Media Player Zbox AD10 | Dvb-T Panasonic DMR-BWT700 | Dvb-T HDHomerun Connect 2 | Nas Thecus N7700Pro | PC Windows 10 + Serviio Pro 1.9.1
Jean-Max
Post Fri Jun 02, 2017 2:20 pm
My (DVB-T + HDD + BD) Panasonic DMR-BWT 700 finds easily Serviio server 1.8 Pro installed on my networked W10-64 PC (1Gb wired ethernet)
I used fixed IP on the Panasonic device and I chosen the Serviio Profile named "Panasonic BD Player"
MKV, M2TS, TS, VOB, MPG (even DV & HDV) videos are correctly played
AVI and MP4 are not read, but it's not a true problem for me
Jean-Max
Jean-Max
Post Sat Jun 17, 2017 12:39 pm
My TV Philips 32PFL 7665/12 finds easily Serviio server 1.9 Beta 1 installed on my networked W10-64 PC (1Gb wired Ethernet)
I used fixed IP on the Philips TV device and I let unchanged the Serviio Profile named "Philips (2010-)"
MKV, MP4, MPG, VOB videos are correctly played
TS, M2TS are not read
Jean-Max
421ImLate
Post Tue Jun 20, 2017 6:14 am
Samsung UN46C6800
Using Serviio Pro 1.7.1.1 The only problem I have is Serviio seems to lose my files list after not using it for a couple of days. Start Serviio on the TV and hit the Videos or Music icon and I get "No video/music files have been loaded", so I have to go to the console on my computer and reload all the drives.
Return to User experiences
Users browsing this forum: Google [Bot] and 10 guests
