How to Turn off Password in media browser
lemconphils
Post Wed Jul 05, 2017 7:05 am
Good day,
Is there a way to disable no password requirement or direct access to serviio media browser without password?
Post Wed Jul 05, 2017 12:29 pm
Re: How to Turn off Password in media browser
lemconphils wrote:Good day,
No, there isn't. Password is mandatory.
Post Wed Jul 05, 2017 5:19 pm
Check out the serviio.cdsAnonymousAccess setting at http://www.serviio.org/component/conten ... properties
lemconphils
Post Thu Jul 06, 2017 12:10 am
Hi, it is possible to edit login script http:// <ip address> :23424/mediabrowser/#/login and where can i find the login credentials?
Post Thu Jul 06, 2017 1:05 am
lemconphils wrote:Hi, it is possible to edit login script http:// <ip address> :23424/mediabrowser/#/login and where can i find the login credentials?
What is it you are trying to do? DenyAll showed you how to remove the password requirement.
cara
Post Thu Feb 02, 2023 7:00 am
Is there a way to disable no password requirement or direct access to serviio media browser without password? nyt wordle
password is required, there is no way to disable it.
Users browsing this forum: No registered users and 65 guests
