How to Turn off Password in media browser
lemconphils
Post Wed Jul 05, 2017 7:05 am
Good day,
Is there a way to disable no password requirement or direct access to serviio media browser without password?
Post Wed Jul 05, 2017 12:29 pm
Re: How to Turn off Password in media browser
lemconphils wrote:Good day,
No, there isn't. Password is mandatory.
Post Wed Jul 05, 2017 5:19 pm
Check out the serviio.cdsAnonymousAccess setting at http://www.serviio.org/component/conten ... properties
lemconphils
Post Thu Jul 06, 2017 12:10 am
Hi, it is possible to edit login script http:// <ip address> :23424/mediabrowser/#/login and where can i find the login credentials?
Post Thu Jul 06, 2017 1:05 am
lemconphils wrote:Hi, it is possible to edit login script http:// <ip address> :23424/mediabrowser/#/login and where can i find the login credentials?
What is it you are trying to do? DenyAll showed you how to remove the password requirement.
cara
Post Thu Feb 02, 2023 7:00 am
Is there a way to disable no password requirement or direct access to serviio media browser without password? nyt wordle
password is required, there is no way to disable it.
