Can't see video
petertohen
Post Thu Jan 25, 2018 7:48 am
Can't see video
All the folders show "There is no playable movie content" on my LG BP 550. Using the same media server I see all the content on a LG BP540. Any ideas on how to fix this? Thanks!
http://www.lg.com/us/home-video/lg-BP540-blu-ray-player
Miles_Gonzalez
Post Fri Feb 02, 2018 10:52 am
Re: Can't see video
There could be a lot of reasons caused this problem, please check if your videos are DRM protected or if just have any special codec. If it is caused by the codec, then use a free software such as freemake or handbrake to help you transcode the video to a new format. Else if it is caused by that the movies are DRM enabled. I would just suggest you to see if it is possible to crack it by itunes video converter windows 8. Getting rid of DRM protection will enable you to watch iTunes movies anywhere as well as save them for backup. Anyway, sincerely hope this help you solve the problem and you can enjoy iTunes movies anywhere.
Post Fri Feb 02, 2018 1:27 pm
Re: Can't see video
petertohen wrote:All the folders show "There is no playable movie content" on my LG BP 550. Using the same media server I see all the content on a LG BP540. Any ideas on how to fix this? Thanks!
What profile has Serviio assigned to your player? It might not be the correct one, and isn't recognizing the files as playable.
Post Fri Feb 02, 2018 1:28 pm
Re: Can't see video
Miles_Gonzalez wrote:There could be a lot of reasons caused this problem, please check if your videos are DRM protected or if just have any special codec. If it is caused by the codec, then use a free software such as freemake or handbrake to help you transcode the video to a new format. Else if it is caused by that the movies are DRM enabled. I would just suggest you to see if it is possible to crack it by itunes video converter windows 8. Getting rid of DRM protection will enable you to watch iTunes movies anywhere as well as save them for backup. Anyway, sincerely hope this help you solve the problem and you can enjoy iTunes movies anywhere.
If one player can see the files, but the other can't, this wouldn't be the issue.
