Can't see video
http://www.lg.com/us/home-video/lg-BP540-blu-ray-player
petertohen wrote:All the folders show "There is no playable movie content" on my LG BP 550. Using the same media server I see all the content on a LG BP540. Any ideas on how to fix this? Thanks!
Miles_Gonzalez wrote:There could be a lot of reasons caused this problem, please check if your videos are DRM protected or if just have any special codec. If it is caused by the codec, then use a free software such as freemake or handbrake to help you transcode the video to a new format. Else if it is caused by that the movies are DRM enabled. I would just suggest you to see if it is possible to crack it by itunes video converter windows 8. Getting rid of DRM protection will enable you to watch iTunes movies anywhere as well as save them for backup. Anyway, sincerely hope this help you solve the problem and you can enjoy iTunes movies anywhere.
Users browsing this forum: Baidu [Spider], Google [Bot] and 51 guests
