Serviio not refreshing
I have Serviio Pro latest version 1.9.1
I have keep library automatically updated selected but, the library is not updating. When I hit force refresh it take over 1 hour to actually refresh. What should I do to fix this?
atc98092 wrote:What operating system are you using? Is the drive connected to the same computer, or is it being accessed on the network?
When you configure your shared folder, there's a checkbox that says "Use the poller mechanism for monitoring this folder". Try this option and see if it monitors your shared folder better.
atc98092 wrote:I believe the next thing to try is enabling detailed logging, restart Serviio and force a refresh, then upload the log here. Then the developer can see if something looks amiss in the log when refreshing.
jannovik wrote:I don't understand this.
zip wrote:jannovik wrote:I don't understand this.
Is this from the start of the server? It looks like it never starts checking for any updates. I'll investigate.
the_hamburger wrote:Do you still want logs?
zip wrote:the_hamburger wrote:Do you still want logs?
Yes pls. From the start of the server with detailed logging on. Just the first 3 minutes of logs, really.
2018-03-20 00:01:30,229 INFO [UpdateChecker] Checking if a new version is available
2018-03-20 14:07:58,888 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (/Volumes/White/._Madam.Secretary.S04E14.720p.HDTV.X264-DIMENSION[eztv].mkv). Message: Unknown video file type.
2018-03-20 14:08:00,404 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (/Volumes/White/._The.Simpsons.S29E12.iNTERNAL.720p.WEB.x264-BAMBOOZLE[eztv].mkv). Message: Unknown video file type.
2018-03-20 14:08:23,919 INFO [RetryExec] I/O exception (java.net.SocketException) caught when processing request: Operation timed out (Read failed)
2018-03-20 14:08:23,919 INFO [RetryExec] Retrying request
2018-03-20 22:23:49,863 INFO [AbstractAVTranscodingDeliveryEngine] Cleaning transcode engine and its data
2018-03-20 22:23:49,896 INFO [WebServer] WebServer shutting down
2018-03-20 22:23:49,896 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2018-03-20 22:23:49,899 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2018-03-20 22:23:49,899 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2018-03-20 22:23:49,899 INFO [EventDispatcher] Leaving EventDispatcher
2018-03-20 22:23:51,532 INFO [WebServer] WebServer starting on port 8895
2018-03-20 22:23:51,532 INFO [Device] Updated bound IP address of Device with UUID: 00f06443-398c-3d99-ae1a-d31c171b4221, bound address: 192.168.1.115
2018-03-20 22:23:51,533 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2018-03-20 22:23:51,533 INFO [EventDispatcher] Starting EventDispatcher
2018-03-20 22:23:51,533 INFO [RendererSearchSender] Starting Renderer searcher process
2018-03-20 22:23:51,533 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface en1 (en1) and address 192.168.1.115, timeout = 0
2018-03-20 22:23:51,533 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2018-03-20 22:23:52,829 INFO [RendererManager] Stored a new renderer: uuid='e365c645-6338-45cc-85de-d1d1792b1e90', name = 'Unrecognized device', ipAddress='192.168.1.111', profile = '1', accessGroupId = '1'
2018-03-20 22:25:09,704 INFO [PlaybackEventsManager] Playback of media item 53864 (UFC.222.PPV.Cyborg.vs.Kunitskaya.HDTV.x264-Ebi [UFC.222.PPV.Cyborg.vs.Kunitskaya.HDTV.x264-Ebi.mp4]) has started at 0% on Identifier=192.168.1.107, Profile=Generic DLNA profile, Name=Unknown
2018-03-20 22:25:12,960 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2018-03-20 23:12:33,349 INFO [PlaybackEventsManager] Playback of media item 53864 (UFC.222.PPV.Cyborg.vs.Kunitskaya.HDTV.x264-Ebi [UFC.222.PPV.Cyborg.vs.Kunitskaya.HDTV.x264-Ebi.mp4]) has started at 0% on Identifier=192.168.1.116, Profile=Generic DLNA profile, Name=Unrecognized device
2018-03-20 23:13:20,232 INFO [PlaybackEventsManager] Playback of media item 53864 (UFC.222.PPV.Cyborg.vs.Kunitskaya.HDTV.x264-Ebi [UFC.222.PPV.Cyborg.vs.Kunitskaya.HDTV.x264-Ebi.mp4]) has stopped at 0% on Identifier=192.168.1.116, Profile=Generic DLNA profile, Name=Unrecognized device
2018-03-20 23:13:20,234 INFO [PlaybackEventsManager] Playback of media item 52644 (UFC.221.Prelims.HDTV.x264-Ebi [UFC.221.Prelims.HDTV.x264-Ebi.mp4]) has started at 0% on Identifier=192.168.1.116, Profile=Generic DLNA profile, Name=Unrecognized device
2018-03-20 23:28:16,556 INFO [PlaybackEventsManager] Playback of media item 52644 (UFC.221.Prelims.HDTV.x264-Ebi [UFC.221.Prelims.HDTV.x264-Ebi.mp4]) has stopped at 13% on Identifier=192.168.1.116, Profile=Generic DLNA profile, Name=Unrecognized device
2018-03-20 23:28:16,556 INFO [PlaybackEventsManager] Playback of media item 53837 (Toasted [The.Middle.S09E15.iNTERNAL.720p.WEB.x264-BAMBOOZLE[eztv].mkv]) has started at 0% on Identifier=192.168.1.116, Profile=Generic DLNA profile, Name=Unrecognized device
2018-03-20 23:29:04,942 INFO [PlaybackEventsManager] Playback of media item 53837 (Toasted [The.Middle.S09E15.iNTERNAL.720p.WEB.x264-BAMBOOZLE[eztv].mkv]) has stopped at 3% on Identifier=192.168.1.116, Profile=Generic DLNA profile, Name=Unrecognized device
2018-03-20 23:29:24,159 WARN [ResourceDeliveryProcessor] Error while processing resource, sending back 404 error. Message: /Volumes/WDTVLiveHub/TV/The Young Pope/The Young Pope Season 1 Mp4 720p/The Young Pope S01E03.mp4 (No such file or directory)
2018-03-20 23:29:24,167 WARN [ResourceDeliveryProcessor] Error while processing resource, sending back 404 error. Message: /Volumes/WDTVLiveHub/TV/The Young Pope/The Young Pope Season 1 Mp4 720p/The Young Pope S01E03.mp4 (No such file or directory)
2018-03-20 23:29:34,705 INFO [PlaybackEventsManager] Playback of media item 54061 (Day 422 [The.Good.Fight.S02E03.INTERNAL.720p.WEB.H264-DEFLATE[eztv].mkv]) has started at 0% on Identifier=192.168.1.116, Profile=Generic DLNA profile, Name=Unrecognized device
2018-03-20 23:35:26,698 INFO [PlaybackEventsManager] Playback of media item 54061 (Day 422 [The.Good.Fight.S02E03.INTERNAL.720p.WEB.H264-DEFLATE[eztv].mkv]) has stopped at 10% on Identifier=192.168.1.116, Profile=Generic DLNA profile, Name=Unrecognized device
2018-03-20 23:39:22,011 INFO [PlaybackEventsManager] Playback of media item 53844 (Can You Reverse the Curse? (1) [survivor.s36e01e02.720p.hdtv.x264-bajskorv.mkv]) has started at 0% on Identifier=192.168.1.116, Profile=Generic DLNA profile, Name=Unrecognized device
2018-03-21 00:01:28,482 INFO [UpdateChecker] Checking if a new version is available
2018-03-21 01:08:58,862 INFO [PlaybackEventsManager] Playback of media item 53844 (Can You Reverse the Curse? (1) [survivor.s36e01e02.720p.hdtv.x264-bajskorv.mkv]) has stopped at 100% on Identifier=192.168.1.116, Profile=Generic DLNA profile, Name=Unrecognized device
2018-03-21 01:26:29,458 INFO [PlaybackEventsManager] Playback of media item 53864 (UFC.222.PPV.Cyborg.vs.Kunitskaya.HDTV.x264-Ebi [UFC.222.PPV.Cyborg.vs.Kunitskaya.HDTV.x264-Ebi.mp4]) has stopped at 100% on Identifier=192.168.1.107, Profile=Generic DLNA profile, Name=Unknown
2018-03-21 18:40:12,547 INFO [PlaybackEventsManager] Playback of media item 53891 (Only Time Will Tell [survivor.s36e03.720p.hdtv.x264-bajskorv.mkv]) has started at 0% on Identifier=192.168.1.116, Profile=Generic DLNA profile, Name=Unrecognized device
2018-03-21 18:40:24,973 INFO [PlaybackEventsManager] Playback of media item 53891 (Only Time Will Tell [survivor.s36e03.720p.hdtv.x264-bajskorv.mkv]) has stopped at 0% on Identifier=192.168.1.116, Profile=Generic DLNA profile, Name=Unrecognized device
2018-03-21 18:41:09,800 INFO [PlaybackEventsManager] Playback of media item 53891 (Only Time Will Tell [survivor.s36e03.720p.hdtv.x264-bajskorv.mkv]) has started at 91% on Identifier=192.168.1.116, Profile=Generic DLNA profile, Name=Unrecognized device
2018-03-21 18:44:51,412 INFO [PlaybackEventsManager] Playback of media item 53891 (Only Time Will Tell [survivor.s36e03.720p.hdtv.x264-bajskorv.mkv]) has stopped at 100% on Identifier=192.168.1.116, Profile=Generic DLNA profile, Name=Unrecognized device
2018-03-21 18:45:21,799 INFO [PlaybackEventsManager] Playback of media item 53891 (Only Time Will Tell [survivor.s36e03.720p.hdtv.x264-bajskorv.mkv]) has started at 87% on Identifier=192.168.1.116, Profile=Generic DLNA profile, Name=Unrecognized device
2018-03-21 18:50:07,157 INFO [PlaybackEventsManager] Playback of media item 53891 (Only Time Will Tell [survivor.s36e03.720p.hdtv.x264-bajskorv.mkv]) has stopped at 97% on Identifier=192.168.1.116, Profile=Generic DLNA profile, Name=Unrecognized device
2018-03-21 18:51:09,131 INFO [PlaybackEventsManager] Playback of media item 54062 (Episode 124 [Last.Week.Tonight.With.John.Oliver.S05E05.720p.HDTV.X264-UAV[eztv].mkv]) has started at 0% on Identifier=192.168.1.116, Profile=Generic DLNA profile, Name=Unrecognized device
2018-03-21 19:21:34,472 INFO [PlaybackEventsManager] Playback of media item 54062 (Episode 124 [Last.Week.Tonight.With.John.Oliver.S05E05.720p.HDTV.X264-UAV[eztv].mkv]) has stopped at 100% on Identifier=192.168.1.116, Profile=Generic DLNA profile, Name=Unrecognized device
2018-03-21 20:13:37,825 INFO [PlaybackEventsManager] Playback of media item 53975 (April [mum.s02e02.hdtv.x264-river[ettv].mkv]) has started at 0% on Identifier=192.168.1.111, Profile=WDTV Live, Name=WD TV Live Hub
2018-03-21 20:13:43,078 INFO [PlaybackEventsManager] Playback of media item 53975 (April [mum.s02e02.hdtv.x264-river[ettv].mkv]) has stopped at 0% on Identifier=192.168.1.111, Profile=WDTV Live, Name=WD TV Live Hub
2018-03-21 20:14:11,402 INFO [PlaybackEventsManager] Playback of media item 53975 (April [mum.s02e02.hdtv.x264-river[ettv].mkv]) has started at 0% on Identifier=192.168.1.111, Profile=WDTV Live, Name=WD TV Live Hub
2018-03-21 20:14:20,555 INFO [PlaybackEventsManager] Playback of media item 53975 (April [mum.s02e02.hdtv.x264-river[ettv].mkv]) has stopped at 0% on Identifier=192.168.1.111, Profile=WDTV Live, Name=WD TV Live Hub
2018-03-21 20:14:49,496 INFO [PlaybackEventsManager] Playback of media item 53841 (Written in the Stars [modern.family.s09e14.internal.720p.web.h264-bamboozle.mkv]) has started at 0% on Identifier=192.168.1.111, Profile=WDTV Live, Name=WD TV Live Hub
2018-03-21 20:14:49,533 INFO [PlaybackEventsManager] Playback of media item 53841 (Written in the Stars [modern.family.s09e14.internal.720p.web.h264-bamboozle.mkv]) has stopped at 0% on Identifier=192.168.1.111, Profile=WDTV Live, Name=WD TV Live Hub
2018-03-21 20:14:49,844 INFO [PlaybackEventsManager] Playback of media item 53841 (Written in the Stars [modern.family.s09e14.internal.720p.web.h264-bamboozle.mkv]) has started at 0% on Identifier=192.168.1.111, Profile=WDTV Live, Name=WD TV Live Hub
2018-03-21 20:15:03,562 INFO [PlaybackEventsManager] Playback of media item 53841 (Written in the Stars [modern.family.s09e14.internal.720p.web.h264-bamboozle.mkv]) has stopped at 0% on Identifier=192.168.1.111, Profile=WDTV Live, Name=WD TV Live Hub
2018-03-21 20:16:28,013 INFO [PlaybackEventsManager] Playback of media item 54061 (Day 422 [The.Good.Fight.S02E03.INTERNAL.720p.WEB.H264-DEFLATE[eztv].mkv]) has started at 0% on Identifier=192.168.1.116, Profile=Generic DLNA profile, Name=Unrecognized device
2018-03-21 20:17:34,836 INFO [PlaybackEventsManager] Playback of media item 54061 (Day 422 [The.Good.Fight.S02E03.INTERNAL.720p.WEB.H264-DEFLATE[eztv].mkv]) has stopped at 2% on Identifier=192.168.1.116, Profile=Generic DLNA profile, Name=Unrecognized device
2018-03-21 20:17:34,836 INFO [PlaybackEventsManager] Playback of media item 53979 (Day 415 [The.Good.Fight.S02E02.INTERNAL.720p.WEB.H264-DEFLATE[eztv].mkv]) has started at 0% on Identifier=192.168.1.116, Profile=Generic DLNA profile, Name=Unrecognized device
2018-03-21 20:17:43,192 INFO [PlaybackEventsManager] Playback of media item 53979 (Day 415 [The.Good.Fight.S02E02.INTERNAL.720p.WEB.H264-DEFLATE[eztv].mkv]) has stopped at 0% on Identifier=192.168.1.116, Profile=Generic DLNA profile, Name=Unrecognized device
2018-03-21 20:17:43,192 INFO [PlaybackEventsManager] Playback of media item 53973 (Real.Time.With.Bill.Maher.2018.03.09.720p.HDTV.X264-UAV [Real.Time.With.Bill.Maher.2018.03.09.720p.HDTV.X264-UAV.mkv]) has started at 0% on Identifier=192.168.1.116, Profile=Generic DLNA profile, Name=Unrecognized device
2018-03-21 21:15:50,939 INFO [PlaybackEventsManager] Playback of media item 53973 (Real.Time.With.Bill.Maher.2018.03.09.720p.HDTV.X264-UAV [Real.Time.With.Bill.Maher.2018.03.09.720p.HDTV.X264-UAV.mkv]) has stopped at 100% on Identifier=192.168.1.116, Profile=Generic DLNA profile, Name=Unrecognized device
2018-03-22 00:01:26,708 INFO [UpdateChecker] Checking if a new version is available
2018-03-22 11:02:46,235 INFO [RendererManager] Stored a new renderer: uuid='1beff38d-7dd4-4524-b418-bd9a9593bdda', name = 'Unrecognized device', ipAddress='192.168.1.118', profile = '1', accessGroupId = '1'
2018-03-22 20:05:42,276 INFO [RendererManager] Stored a new renderer: uuid='f6c71f9a-cbbf-4af3-bc26-3f765036f595', name = 'Unrecognized device', ipAddress='192.168.1.109', profile = '1', accessGroupId = '1'
2018-03-22 20:05:42,625 WARN [EventDispatcher] Couldn't send event message for subscription 795021d7-f207-4b9d-a321-2d98337962a0, will keep trying until subscription expires
2018-03-22 20:05:42,642 WARN [EventDispatcher] Couldn't send event message for subscription ed7bcbc9-fca7-4b5e-ae19-87b2e1c42d6d, will keep trying until subscription expires
2018-03-22 20:20:56,640 INFO [LibraryDeltaScanner] Added repository '/Volumes/WDTVLiveHub' to delta scanner (POLLER)
2018-03-22 21:48:09,499 WARN [RendererManager] Error while retrieving renderer description: URL 'http://192.168.1.113:52235/dmr/SamsungMRDesc.xml' returned status code '401'
2018-03-23 00:01:24,860 INFO [UpdateChecker] Checking if a new version is available
2018-03-23 16:47:34,928 WARN [RendererManager] Error while retrieving renderer description: connect timed out
2018-03-23 16:48:02,159 INFO [RepositoriesStatus] Repository '/Volumes/WDTVLiveHub' is not currently available. Deferring all operations for later.
2018-03-23 16:59:07,942 WARN [RendererManager] Error while retrieving renderer description: connect timed out
2018-03-23 17:07:59,016 WARN [RendererManager] Error while retrieving renderer description: connect timed out
2018-03-23 17:11:53,954 WARN [MultiCastUtils] Host IP address 192.168.1.115 is not available, will try again 9 times
2018-03-23 17:11:59,021 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2018-03-23 17:11:59,021 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2018-03-23 17:11:59,021 INFO [Device] Updated bound IP address of Device with UUID: 00f06443-398c-3d99-ae1a-d31c171b4221, bound address: 192.168.1.115
2018-03-23 17:11:59,022 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2018-03-23 17:11:59,022 INFO [EventDispatcher] Leaving EventDispatcher
2018-03-23 17:11:59,022 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2018-03-23 17:11:59,022 INFO [EventDispatcher] Starting EventDispatcher
2018-03-23 17:11:59,022 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2018-03-23 17:11:59,023 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface en1 (en1) and address 192.168.1.115, timeout = 0
2018-03-24 00:01:23,010 INFO [UpdateChecker] Checking if a new version is available
2018-03-24 02:08:39,154 INFO [PlaybackEventsManager] Playback of media item 53968 (Charlotte Brontë and a Backhoe [Mom.S05E14.720p.HDTV.x264-AVS[eztv].mkv]) has started at 0% on Identifier=192.168.1.118, Profile=Generic DLNA profile, Name=Unrecognized device
2018-03-24 02:29:02,008 INFO [PlaybackEventsManager] Playback of media item 53968 (Charlotte Brontë and a Backhoe [Mom.S05E14.720p.HDTV.x264-AVS[eztv].mkv]) has stopped at 100% on Identifier=192.168.1.118, Profile=Generic DLNA profile, Name=Unrecognized device
2018-03-25 00:01:21,122 INFO [UpdateChecker] Checking if a new version is available
Users browsing this forum: Google [Bot] and 97 guests
