Serviio not refreshing
jannovik
Post Fri Mar 16, 2018 12:35 am
I have Serviio Pro latest version 1.9.1
I have keep library automatically updated selected but, the library is not updating. When I hit force refresh it take over 1 hour to actually refresh. What should I do to fix this?
Post Fri Mar 16, 2018 1:38 pm
Re: Serviio not refreshing
What operating system are you using? Is the drive connected to the same computer, or is it being accessed on the network?
When you configure your shared folder, there's a checkbox that says "Use the poller mechanism for monitoring this folder". Try this option and see if it monitors your shared folder better.
bbking67
Post Sat Mar 17, 2018 6:49 pm
I too am having problems with 1.9.1 refreshing. Windows 10.
Reverting to a previous build.
jannovik
Post Sat Mar 17, 2018 9:03 pm
atc98092 wrote:What operating system are you using? Is the drive connected to the same computer, or is it being accessed on the network?
I have a Mac Mini macOS High Sierra dedicated for Serviio and file sharing. Everything is on the same private network. The external drives are connected directly to the Mac Mini. I have 2 Samsung TVs and I can access Serviio on both. The problem is on both TVs. I've tried The poller mechanism and with that selected is worse. I restarted the Mac and that updated the list, but I don't want to restart the computer every time I add something. It should just update
zsirmo
Post Sat Mar 17, 2018 11:32 pm
I have a same problem with QNAP NAS.
My first problem, dont show/see the indexing process working :(
Post Sun Mar 18, 2018 3:03 am
I believe the next thing to try is enabling detailed logging, restart Serviio and force a refresh, then upload the log here. Then the developer can see if something looks amiss in the log when refreshing.
jannovik
Post Sun Mar 18, 2018 3:24 am
atc98092 wrote:I believe the next thing to try is enabling detailed logging, restart Serviio and force a refresh, then upload the log here. Then the developer can see if something looks amiss in the log when refreshing.
I've enabled detailed logging already. I tried to understand what's going, but it was like looking at the matrix lol lol. Should I upload that one or should I disable it, delete it, enable it and do the force refresh?
Post Sun Mar 18, 2018 9:37 pm
Yeah, I'm not great at following some of it :lol: , but Zip will know what's going on. I would agree to make a clean detailed log, then upload it here.
Post Wed Mar 21, 2018 2:15 pm
check what is the last file it's trying to add... it might be stuck on it, so try to move it else where to see if you get forward.
jannovik
Post Thu Mar 22, 2018 12:17 am
I don't understand this.
(423.21 KiB) Downloaded 1608 times
Post Thu Mar 22, 2018 12:11 pm
jannovik wrote:I don't understand this.
Is this from the start of the server? It looks like it never starts checking for any updates. I'll investigate.
jannovik
Post Thu Mar 22, 2018 12:38 pm
No the log is from a few days back when I started researching on this forum for info regarding my problem. I found your instructions for debug logging. I did it and tried to read it, but I couldn't understand lol. The mac Mini is running macOS 10.13.3. The file system on the server is APFS. The external drives are HFS+. Anything else you need to know let me know
the_hamburger
Post Thu Mar 22, 2018 1:15 pm
I'm having the same problem on Mac Sierra. [edit] also 1.9.1
To add Moving the last file didn't help.
I tried to untick Poller Mech. but then it won't save. Spinning wheel in the save box.
Also you cannot quit the app. Have to force quit.
Do you still want logs?
Thanks!
Post Thu Mar 22, 2018 2:49 pm
the_hamburger wrote:Do you still want logs?
Yes pls. From the start of the server with detailed logging on. Just the first 3 minutes of logs, really.
jannovik
Post Thu Mar 22, 2018 3:32 pm
Do you need me to do that? Can you please explain what do I need to do.
Post Thu Mar 22, 2018 5:19 pm
His post (and my sig line) has a link to instructions on enabling detailed logging. Follow that information and then upload the complete log. Be aware that by default the logs are broken into 500k sizes. So you might need to upload more than one file.
Belthazar
Post Fri Mar 23, 2018 9:05 pm
I was having the same problem. To get it to refresh, I used this work-around: I uncheck "Keep library automatically updated" and then "Forced Refresh" and the files were updated. It worked for me and may work for others.
the_hamburger
Post Sun Mar 25, 2018 3:53 am
Is this what you need?
2018-03-20 00:01:30,229 INFO  [UpdateChecker] Checking if a new version is available
2018-03-20 14:07:58,888 WARN  [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (/Volumes/White/._Madam.Secretary.S04E14.720p.HDTV.X264-DIMENSION[eztv].mkv). Message: Unknown video file type.
2018-03-20 14:08:00,404 WARN  [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (/Volumes/White/._The.Simpsons.S29E12.iNTERNAL.720p.WEB.x264-BAMBOOZLE[eztv].mkv). Message: Unknown video file type.
2018-03-20 14:08:23,919 INFO  [RetryExec] I/O exception (java.net.SocketException) caught when processing request: Operation timed out (Read failed)
2018-03-20 14:08:23,919 INFO  [RetryExec] Retrying request
2018-03-20 22:23:49,863 INFO  [AbstractAVTranscodingDeliveryEngine] Cleaning transcode engine and its data
2018-03-20 22:23:49,896 INFO  [WebServer] WebServer shutting down
2018-03-20 22:23:49,896 INFO  [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2018-03-20 22:23:49,899 INFO  [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2018-03-20 22:23:49,899 INFO  [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2018-03-20 22:23:49,899 INFO  [EventDispatcher] Leaving EventDispatcher
2018-03-20 22:23:51,532 INFO  [WebServer] WebServer starting on port 8895
2018-03-20 22:23:51,532 INFO  [Device] Updated bound IP address of Device with UUID: 00f06443-398c-3d99-ae1a-d31c171b4221, bound address: 192.168.1.115
2018-03-20 22:23:51,533 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2018-03-20 22:23:51,533 INFO  [EventDispatcher] Starting EventDispatcher
2018-03-20 22:23:51,533 INFO  [RendererSearchSender] Starting Renderer searcher process
2018-03-20 22:23:51,533 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface en1 (en1) and address 192.168.1.115, timeout = 0
2018-03-20 22:23:51,533 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2018-03-20 22:23:52,829 INFO  [RendererManager] Stored a new renderer: uuid='e365c645-6338-45cc-85de-d1d1792b1e90', name = 'Unrecognized device', ipAddress='192.168.1.111', profile = '1', accessGroupId = '1'
2018-03-20 22:25:09,704 INFO  [PlaybackEventsManager] Playback of media item 53864 (UFC.222.PPV.Cyborg.vs.Kunitskaya.HDTV.x264-Ebi [UFC.222.PPV.Cyborg.vs.Kunitskaya.HDTV.x264-Ebi.mp4]) has started at 0% on Identifier=192.168.1.107, Profile=Generic DLNA profile, Name=Unknown
2018-03-20 22:25:12,960 INFO  [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2018-03-20 23:12:33,349 INFO  [PlaybackEventsManager] Playback of media item 53864 (UFC.222.PPV.Cyborg.vs.Kunitskaya.HDTV.x264-Ebi [UFC.222.PPV.Cyborg.vs.Kunitskaya.HDTV.x264-Ebi.mp4]) has started at 0% on Identifier=192.168.1.116, Profile=Generic DLNA profile, Name=Unrecognized device
2018-03-20 23:13:20,232 INFO  [PlaybackEventsManager] Playback of media item 53864 (UFC.222.PPV.Cyborg.vs.Kunitskaya.HDTV.x264-Ebi [UFC.222.PPV.Cyborg.vs.Kunitskaya.HDTV.x264-Ebi.mp4]) has stopped at 0% on Identifier=192.168.1.116, Profile=Generic DLNA profile, Name=Unrecognized device
2018-03-20 23:13:20,234 INFO  [PlaybackEventsManager] Playback of media item 52644 (UFC.221.Prelims.HDTV.x264-Ebi [UFC.221.Prelims.HDTV.x264-Ebi.mp4]) has started at 0% on Identifier=192.168.1.116, Profile=Generic DLNA profile, Name=Unrecognized device
2018-03-20 23:28:16,556 INFO  [PlaybackEventsManager] Playback of media item 52644 (UFC.221.Prelims.HDTV.x264-Ebi [UFC.221.Prelims.HDTV.x264-Ebi.mp4]) has stopped at 13% on Identifier=192.168.1.116, Profile=Generic DLNA profile, Name=Unrecognized device
2018-03-20 23:28:16,556 INFO  [PlaybackEventsManager] Playback of media item 53837 (Toasted [The.Middle.S09E15.iNTERNAL.720p.WEB.x264-BAMBOOZLE[eztv].mkv]) has started at 0% on Identifier=192.168.1.116, Profile=Generic DLNA profile, Name=Unrecognized device
2018-03-20 23:29:04,942 INFO  [PlaybackEventsManager] Playback of media item 53837 (Toasted [The.Middle.S09E15.iNTERNAL.720p.WEB.x264-BAMBOOZLE[eztv].mkv]) has stopped at 3% on Identifier=192.168.1.116, Profile=Generic DLNA profile, Name=Unrecognized device
2018-03-20 23:29:24,159 WARN  [ResourceDeliveryProcessor] Error while processing resource, sending back 404 error. Message: /Volumes/WDTVLiveHub/TV/The Young Pope/The Young Pope Season 1 Mp4 720p/The Young Pope S01E03.mp4 (No such file or directory)
2018-03-20 23:29:24,167 WARN  [ResourceDeliveryProcessor] Error while processing resource, sending back 404 error. Message: /Volumes/WDTVLiveHub/TV/The Young Pope/The Young Pope Season 1 Mp4 720p/The Young Pope S01E03.mp4 (No such file or directory)
2018-03-20 23:29:34,705 INFO  [PlaybackEventsManager] Playback of media item 54061 (Day 422 [The.Good.Fight.S02E03.INTERNAL.720p.WEB.H264-DEFLATE[eztv].mkv]) has started at 0% on Identifier=192.168.1.116, Profile=Generic DLNA profile, Name=Unrecognized device
2018-03-20 23:35:26,698 INFO  [PlaybackEventsManager] Playback of media item 54061 (Day 422 [The.Good.Fight.S02E03.INTERNAL.720p.WEB.H264-DEFLATE[eztv].mkv]) has stopped at 10% on Identifier=192.168.1.116, Profile=Generic DLNA profile, Name=Unrecognized device
2018-03-20 23:39:22,011 INFO  [PlaybackEventsManager] Playback of media item 53844 (Can You Reverse the Curse? (1) [survivor.s36e01e02.720p.hdtv.x264-bajskorv.mkv]) has started at 0% on Identifier=192.168.1.116, Profile=Generic DLNA profile, Name=Unrecognized device
2018-03-21 00:01:28,482 INFO  [UpdateChecker] Checking if a new version is available
2018-03-21 01:08:58,862 INFO  [PlaybackEventsManager] Playback of media item 53844 (Can You Reverse the Curse? (1) [survivor.s36e01e02.720p.hdtv.x264-bajskorv.mkv]) has stopped at 100% on Identifier=192.168.1.116, Profile=Generic DLNA profile, Name=Unrecognized device
2018-03-21 01:26:29,458 INFO  [PlaybackEventsManager] Playback of media item 53864 (UFC.222.PPV.Cyborg.vs.Kunitskaya.HDTV.x264-Ebi [UFC.222.PPV.Cyborg.vs.Kunitskaya.HDTV.x264-Ebi.mp4]) has stopped at 100% on Identifier=192.168.1.107, Profile=Generic DLNA profile, Name=Unknown
2018-03-21 18:40:12,547 INFO  [PlaybackEventsManager] Playback of media item 53891 (Only Time Will Tell [survivor.s36e03.720p.hdtv.x264-bajskorv.mkv]) has started at 0% on Identifier=192.168.1.116, Profile=Generic DLNA profile, Name=Unrecognized device
2018-03-21 18:40:24,973 INFO  [PlaybackEventsManager] Playback of media item 53891 (Only Time Will Tell [survivor.s36e03.720p.hdtv.x264-bajskorv.mkv]) has stopped at 0% on Identifier=192.168.1.116, Profile=Generic DLNA profile, Name=Unrecognized device
2018-03-21 18:41:09,800 INFO  [PlaybackEventsManager] Playback of media item 53891 (Only Time Will Tell [survivor.s36e03.720p.hdtv.x264-bajskorv.mkv]) has started at 91% on Identifier=192.168.1.116, Profile=Generic DLNA profile, Name=Unrecognized device
2018-03-21 18:44:51,412 INFO  [PlaybackEventsManager] Playback of media item 53891 (Only Time Will Tell [survivor.s36e03.720p.hdtv.x264-bajskorv.mkv]) has stopped at 100% on Identifier=192.168.1.116, Profile=Generic DLNA profile, Name=Unrecognized device
2018-03-21 18:45:21,799 INFO  [PlaybackEventsManager] Playback of media item 53891 (Only Time Will Tell [survivor.s36e03.720p.hdtv.x264-bajskorv.mkv]) has started at 87% on Identifier=192.168.1.116, Profile=Generic DLNA profile, Name=Unrecognized device
2018-03-21 18:50:07,157 INFO  [PlaybackEventsManager] Playback of media item 53891 (Only Time Will Tell [survivor.s36e03.720p.hdtv.x264-bajskorv.mkv]) has stopped at 97% on Identifier=192.168.1.116, Profile=Generic DLNA profile, Name=Unrecognized device
2018-03-21 18:51:09,131 INFO  [PlaybackEventsManager] Playback of media item 54062 (Episode 124 [Last.Week.Tonight.With.John.Oliver.S05E05.720p.HDTV.X264-UAV[eztv].mkv]) has started at 0% on Identifier=192.168.1.116, Profile=Generic DLNA profile, Name=Unrecognized device
2018-03-21 19:21:34,472 INFO  [PlaybackEventsManager] Playback of media item 54062 (Episode 124 [Last.Week.Tonight.With.John.Oliver.S05E05.720p.HDTV.X264-UAV[eztv].mkv]) has stopped at 100% on Identifier=192.168.1.116, Profile=Generic DLNA profile, Name=Unrecognized device
2018-03-21 20:13:37,825 INFO  [PlaybackEventsManager] Playback of media item 53975 (April [mum.s02e02.hdtv.x264-river[ettv].mkv]) has started at 0% on Identifier=192.168.1.111, Profile=WDTV Live, Name=WD TV Live Hub
2018-03-21 20:13:43,078 INFO  [PlaybackEventsManager] Playback of media item 53975 (April [mum.s02e02.hdtv.x264-river[ettv].mkv]) has stopped at 0% on Identifier=192.168.1.111, Profile=WDTV Live, Name=WD TV Live Hub
2018-03-21 20:14:11,402 INFO  [PlaybackEventsManager] Playback of media item 53975 (April [mum.s02e02.hdtv.x264-river[ettv].mkv]) has started at 0% on Identifier=192.168.1.111, Profile=WDTV Live, Name=WD TV Live Hub
2018-03-21 20:14:20,555 INFO  [PlaybackEventsManager] Playback of media item 53975 (April [mum.s02e02.hdtv.x264-river[ettv].mkv]) has stopped at 0% on Identifier=192.168.1.111, Profile=WDTV Live, Name=WD TV Live Hub
2018-03-21 20:14:49,496 INFO  [PlaybackEventsManager] Playback of media item 53841 (Written in the Stars [modern.family.s09e14.internal.720p.web.h264-bamboozle.mkv]) has started at 0% on Identifier=192.168.1.111, Profile=WDTV Live, Name=WD TV Live Hub
2018-03-21 20:14:49,533 INFO  [PlaybackEventsManager] Playback of media item 53841 (Written in the Stars [modern.family.s09e14.internal.720p.web.h264-bamboozle.mkv]) has stopped at 0% on Identifier=192.168.1.111, Profile=WDTV Live, Name=WD TV Live Hub
2018-03-21 20:14:49,844 INFO  [PlaybackEventsManager] Playback of media item 53841 (Written in the Stars [modern.family.s09e14.internal.720p.web.h264-bamboozle.mkv]) has started at 0% on Identifier=192.168.1.111, Profile=WDTV Live, Name=WD TV Live Hub
2018-03-21 20:15:03,562 INFO  [PlaybackEventsManager] Playback of media item 53841 (Written in the Stars [modern.family.s09e14.internal.720p.web.h264-bamboozle.mkv]) has stopped at 0% on Identifier=192.168.1.111, Profile=WDTV Live, Name=WD TV Live Hub
2018-03-21 20:16:28,013 INFO  [PlaybackEventsManager] Playback of media item 54061 (Day 422 [The.Good.Fight.S02E03.INTERNAL.720p.WEB.H264-DEFLATE[eztv].mkv]) has started at 0% on Identifier=192.168.1.116, Profile=Generic DLNA profile, Name=Unrecognized device
2018-03-21 20:17:34,836 INFO  [PlaybackEventsManager] Playback of media item 54061 (Day 422 [The.Good.Fight.S02E03.INTERNAL.720p.WEB.H264-DEFLATE[eztv].mkv]) has stopped at 2% on Identifier=192.168.1.116, Profile=Generic DLNA profile, Name=Unrecognized device
2018-03-21 20:17:34,836 INFO  [PlaybackEventsManager] Playback of media item 53979 (Day 415 [The.Good.Fight.S02E02.INTERNAL.720p.WEB.H264-DEFLATE[eztv].mkv]) has started at 0% on Identifier=192.168.1.116, Profile=Generic DLNA profile, Name=Unrecognized device
2018-03-21 20:17:43,192 INFO  [PlaybackEventsManager] Playback of media item 53979 (Day 415 [The.Good.Fight.S02E02.INTERNAL.720p.WEB.H264-DEFLATE[eztv].mkv]) has stopped at 0% on Identifier=192.168.1.116, Profile=Generic DLNA profile, Name=Unrecognized device
2018-03-21 20:17:43,192 INFO  [PlaybackEventsManager] Playback of media item 53973 (Real.Time.With.Bill.Maher.2018.03.09.720p.HDTV.X264-UAV [Real.Time.With.Bill.Maher.2018.03.09.720p.HDTV.X264-UAV.mkv]) has started at 0% on Identifier=192.168.1.116, Profile=Generic DLNA profile, Name=Unrecognized device
2018-03-21 21:15:50,939 INFO  [PlaybackEventsManager] Playback of media item 53973 (Real.Time.With.Bill.Maher.2018.03.09.720p.HDTV.X264-UAV [Real.Time.With.Bill.Maher.2018.03.09.720p.HDTV.X264-UAV.mkv]) has stopped at 100% on Identifier=192.168.1.116, Profile=Generic DLNA profile, Name=Unrecognized device
2018-03-22 00:01:26,708 INFO  [UpdateChecker] Checking if a new version is available
2018-03-22 11:02:46,235 INFO  [RendererManager] Stored a new renderer: uuid='1beff38d-7dd4-4524-b418-bd9a9593bdda', name = 'Unrecognized device', ipAddress='192.168.1.118', profile = '1', accessGroupId = '1'
2018-03-22 20:05:42,276 INFO  [RendererManager] Stored a new renderer: uuid='f6c71f9a-cbbf-4af3-bc26-3f765036f595', name = 'Unrecognized device', ipAddress='192.168.1.109', profile = '1', accessGroupId = '1'
2018-03-22 20:05:42,625 WARN  [EventDispatcher] Couldn't send event message for subscription 795021d7-f207-4b9d-a321-2d98337962a0, will keep trying until subscription expires
2018-03-22 20:05:42,642 WARN  [EventDispatcher] Couldn't send event message for subscription ed7bcbc9-fca7-4b5e-ae19-87b2e1c42d6d, will keep trying until subscription expires
2018-03-22 20:20:56,640 INFO  [LibraryDeltaScanner] Added repository '/Volumes/WDTVLiveHub' to delta scanner (POLLER)
2018-03-22 21:48:09,499 WARN  [RendererManager] Error while retrieving renderer description: URL 'http://192.168.1.113:52235/dmr/SamsungMRDesc.xml' returned status code '401'
2018-03-23 00:01:24,860 INFO  [UpdateChecker] Checking if a new version is available
2018-03-23 16:47:34,928 WARN  [RendererManager] Error while retrieving renderer description: connect timed out
2018-03-23 16:48:02,159 INFO  [RepositoriesStatus] Repository '/Volumes/WDTVLiveHub' is not currently available. Deferring all operations for later.
2018-03-23 16:59:07,942 WARN  [RendererManager] Error while retrieving renderer description: connect timed out
2018-03-23 17:07:59,016 WARN  [RendererManager] Error while retrieving renderer description: connect timed out
2018-03-23 17:11:53,954 WARN  [MultiCastUtils] Host IP address 192.168.1.115 is not available, will try again 9 times
2018-03-23 17:11:59,021 INFO  [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2018-03-23 17:11:59,021 INFO  [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2018-03-23 17:11:59,021 INFO  [Device] Updated bound IP address of Device with UUID: 00f06443-398c-3d99-ae1a-d31c171b4221, bound address: 192.168.1.115
2018-03-23 17:11:59,022 INFO  [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2018-03-23 17:11:59,022 INFO  [EventDispatcher] Leaving EventDispatcher
2018-03-23 17:11:59,022 INFO  [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2018-03-23 17:11:59,022 INFO  [EventDispatcher] Starting EventDispatcher
2018-03-23 17:11:59,022 INFO  [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2018-03-23 17:11:59,023 INFO  [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface en1 (en1) and address 192.168.1.115, timeout = 0
2018-03-24 00:01:23,010 INFO  [UpdateChecker] Checking if a new version is available
2018-03-24 02:08:39,154 INFO  [PlaybackEventsManager] Playback of media item 53968 (Charlotte Brontë and a Backhoe [Mom.S05E14.720p.HDTV.x264-AVS[eztv].mkv]) has started at 0% on Identifier=192.168.1.118, Profile=Generic DLNA profile, Name=Unrecognized device
2018-03-24 02:29:02,008 INFO  [PlaybackEventsManager] Playback of media item 53968 (Charlotte Brontë and a Backhoe [Mom.S05E14.720p.HDTV.x264-AVS[eztv].mkv]) has stopped at 100% on Identifier=192.168.1.118, Profile=Generic DLNA profile, Name=Unrecognized device
2018-03-25 00:01:21,122 INFO  [UpdateChecker] Checking if a new version is available
Image Image Image
Post Sun Mar 25, 2018 4:56 am
Your settings look good, although I have no Mac knowledge so don't even know what that particular window is showing.
The log is not a detailed log. Zip might require the full debug log. From the log you did post, I have seen a similar error when I had a defective media file. Because of an aged hard drive, coupled with a power bump, I had a bunch of corrupted files. If you run ffmpeg -i on one you can see if the media within the container is valid. See the instructions in my sig line for gathering the media info.
the_hamburger
Post Mon Mar 26, 2018 6:00 am
here's the log.
Your message contains 257593 characters. The maximum number of allowed characters is 60000.
See attached.
I found that after stoping and starting the server from the Terminal , files started adding again.
start the server
sudo launchctl load -F /Library/LaunchDaemons/org.serviio.server.plist
stop the server
sudo launchctl unload /Library/LaunchDaemons/org.serviio.server.plist
So its working again , but with so many people having the same issue it points to a bug.
If you need more logs, please let me know.
Thanks!
Serviio.log
(139.24 KiB) Downloaded 1294 times
