Using CURL to force library refresh
phardwick
Post Tue Jan 25, 2011 6:02 pm
Quick tip:
I use this to force a library refresh (I'm running on linux):
curl -X POST "http://localhost:23423/rest/action" -H "Content-Type: text/xml" -d "<action><name>forceLibraryRefresh</name></action>"
I plan on putting this into a daily cron job and disabling the auto library refresh.
J038lack
Post Mon Mar 28, 2011 3:58 am
Re: Using CURL to force library refresh
This works perfectly as a post-processing script for SABnzdb+
J03
Xmantium
Post Wed Jul 27, 2011 11:00 pm
I use sabnzbd too, please can you tell me how you made this script work on your sab?
J038lack
Post Sat Aug 13, 2011 7:08 am
Xmantium wrote:I use sabnzbd too, please can you tell me how you made this script work on your sab?
Hey Xmantium,
You first install Curl
In windows just copy curl.exe to your system32 dir
Then create a batch file with the above line in it. (A text file saved as a .bat)
Then save in your script folder.
Then go to your category settings and change your (movie/tv/music/picture) category of choice script setting to the new batch file you just created.
I also took this one step further because I didn't like the CMD windowing opening all the time and converted the .bat file to a .exe to lose the black box. I used Bat_To_Exe_Converter.
works great
Hope this helps
J03
Xmantium
Post Sat Aug 13, 2011 2:00 pm
I will try this out, this suits the windows version
I've noticed your a very active member in the sabnzbd forum.
Is there a python script that can do the same curl script? I mainly use Serviio on Linux
J038lack
Post Sun Aug 14, 2011 4:50 am
Xmantium wrote:I will try this out, this suits the windows version
Hey Xmantium,
Here is a python script that will do the same -
import httplib
connection =  httplib.HTTPConnection("localhost",23423)
body_content = '<action><name>forceLibraryRefresh</name></action>'
connection.request('POST', '/rest/action', body_content)
result = connection.getresponse()
#print result.status
I have tested this on python 2.6 windows version, but I don't see anything that would cause any problems in Linux.
If you have a bound IP address change the connection line.
connection = httplib.HTTPConnection('1.2.3.4:23423')
Glad to help
J03
Xmantium
Post Sun Aug 14, 2011 2:02 pm
Thanks for this, i copied the code in a text file and renamed it ServiioRefresh.py
Im running my NAS on fixed IP, so my .py has the following script:
import httplib
connection =  httplib.HTTPConnection("192.168.1.6",23423)
It says "Cannot run script /share/MD0_DATA/.qpkg/SickBeard/autoProcessTV/ServiioRefresh.py"
Am i doing something wrong :?
J038lack
Post Sun Aug 14, 2011 6:15 pm
Xmantium wrote:Thanks for this, i copied the code in a text file and renamed it ServiioRefresh.py
import httplib
Hey Xmantium,
Have you tryed leaving the connection line localhost
Im doing some further testing on bound IP address but try localhost.
Also try running the script by itself to test.
To confirm working open your Serviio console and check if your library status changes.
Tell me how it goes.
J03
Xmantium
Post Mon Aug 15, 2011 12:11 am
I get the same error still...
i did change the line to - connection = httplib.HTTPConnection('192.168.1.6:23423')
I ran the script by Terminal Putty in WinSCP - # python ServiioRefresh.py
I get no messages...
Then i changed to - connection = httplib.HTTPConnection("localhost",23423)
Still the same message in sab, but putty terminal says
[/share/MD0_DATA/Qdownload/sabnzbd/script] # python ServiioRefresh.py
Traceback (most recent call last):
  File "ServiioRefresh.py", line 5, in <module>
  File "/opt/lib/python2.6/httplib.py", line 914, in request
    self._send_request(method, url, body, headers)
  File "/opt/lib/python2.6/httplib.py", line 951, in _send_request
    self.endheaders()
  File "/opt/lib/python2.6/httplib.py", line 908, in endheaders
    self._send_output()
  File "/opt/lib/python2.6/httplib.py", line 780, in _send_output
    self.send(msg)
  File "/opt/lib/python2.6/httplib.py", line 739, in send
    self.connect()
  File "/opt/lib/python2.6/httplib.py", line 720, in connect
    self.timeout)
  File "/opt/lib/python2.6/socket.py", line 561, in create_connection
    raise error, msg
socket.error: [Errno 111] Connection refused
J038lack
Post Mon Aug 15, 2011 3:19 am
First setup is getting stuck and will never return results. Wrong IP address
Second setup is an address that doesn't have an REST interface or Serviio running.
Which machine has Serviio running on it ? IP ? PC or NAS?
which machine has Sabnzbd+ running on it ? IP? PC or NAS?
a couple other things you can try is 127.0.0.1 instead of localhost
and also try removing the Port # ("localhost") instead of ("localhost",23423)
These two tips will only work if the Script is run on the same machine that is running Serviio.
If your using Putty then you can remove the # beside the print command in your script and it should return 200 if everything is OK
I will try and setup Serviio with a bound IP address and run the script from another PC on the local network.
You've almost got it
J03
Xmantium
Post Mon Aug 15, 2011 6:11 pm
Ive tried all variation using putty to run the python code, the only one that returns 200 is connection = httplib.HTTPConnection('192.168.1.6:23423')
It does refresh my Serviio Library - Hurray!!
[/share/Qdownload/sabnzbd/script] # python ServiioRefresh.py
200
My sabnzbd and serviio is on the same IP on the same NAS server - 192.168.1.6
BUT! - Its not running with sabnzb, sab keeps saying the same error message
Exit(-1) Cannot run script /share/Qdownload/sabnzbd/script/ServiioRefresh.py
Ive check the permission rights of the file, read and execute is enabled, dont know why sab wont run my script...
J038lack
Post Thu Aug 18, 2011 3:57 pm
So Here is your problem when you run putty you tell it to run python ServiioRefresh.py. Which tells it to use Python to run the script.
To correct the script so you dont need to tell it what to run it with is to add a line to the top of the script stating the path to where python is
Example.
#!/usr/local/bin/python
import httplib
With the above line you are specifying the location to the python executable in your machine, that rest of the script needs to be interpreted with.The above line is pointing to python that is located at /usr/local/bin/python this maybe different on your machine find the python executable and use that path.
I think after adding this line you should be able to run the script in putty without the python in front of it. Just type - ServiioRefresh.py
Hope this works
J03
Xmantium
Post Thu Aug 18, 2011 5:46 pm
J03 you are a star!! 8-)
Im such an idiot not realising this before, for my NAS linux its #!/usr/bin/env python after checking other .py scripts used by my sab
It works perfect and updates my library, just one little thing i want to change,
Iv added on an extra line print "Updated Serviio Library" but for some reason sab says
Updated Serviio Library (More)
It adds extra break line, is there a better way to printline without the link (more) doesnt appear
J038lack
Post Thu Aug 18, 2011 8:18 pm
Xmantium,
Just a little IF else statement will take care of your output,
As I explained earlier the 200 result is the OK command from the REST interface and we can use that to decide if the Update was successful or failed. try the code below.
As for the line break - you can put a , on the end of the print command. take a look below
but this will not stop the (more) link that is created by sabnzbd. It is a log link and it can only be disable by running a output free script or disable logging (which I'm pretty sure can not be done).
import httplib
if result.status == 200:
    print "Updated Serviio Library",
else :
    print "Update Failed",
J03
Xmantium
Post Mon Sep 26, 2011 9:00 pm
When i updated to 0.6, the script no longer works! :?
Has the ports changed to update library!?
Post Mon Sep 26, 2011 10:03 pm
no, nothing changed. just make sure the REST API still binds to the IP you're expecting (that changed, it now binds automatically to the public IP of the server)
Xmantium
Post Mon Sep 26, 2011 10:27 pm
Im a noob to REST, how do i do this to get the script working again?
It should return "200" when the library have been updated, it doesnt return anything now
Post Mon Sep 26, 2011 10:44 pm
check ip is still correct.
Post Mon Sep 26, 2011 10:50 pm
does it get throught to the server, ie is the library updated?
Xmantium
Post Tue Sep 27, 2011 6:22 am
my sabnzbd and serviio are on the same NAS and all same fixed IP - 192.168.1.6
The script is exactly the same as J03Black's last post.
the script is in python, its designed to run after a media file is downloaded in sabnzbd so I don't have to press force refresh to watch media file straight away, the library does not get updated
Users browsing this forum: No registered users and 117 guests
