Mon Aug 15, 2011 3:19 am by J038lack
First setup is getting stuck and will never return results. Wrong IP address
Second setup is an address that doesn't have an REST interface or Serviio running.
Which machine has Serviio running on it ? IP ? PC or NAS?
which machine has Sabnzbd+ running on it ? IP? PC or NAS?
a couple other things you can try is 127.0.0.1 instead of localhost
and also try removing the Port # ("localhost") instead of ("localhost",23423)
These two tips will only work if the Script is run on the same machine that is running Serviio.
If your using Putty then you can remove the # beside the print command in your script and it should return 200 if everything is OK
I will try and setup Serviio with a bound IP address and run the script from another PC on the local network.
You've almost got it
J03
