serviio not working with windows 1903
jocker50
Post Wed Jun 05, 2019 10:22 am
since the update of windows 10 version 1903 serviio no longer works, I tried the versuy 2 of serviio but same failure. I can no longer access the consolle.
do you have an idea?
cordially
Post Wed Jun 05, 2019 12:04 pm
Re: serviio not working with windows 1903
I'm not certain what version of Windows I'm running, but it should be the latest version. Have no issues with Serviio running. I'll check my Windows version this evening, but could you upload your Serviio log here so we can look for any error messages?
jocker50
Post Wed Jun 05, 2019 2:08 pm
hello, I have the same erratic message as this post.
I emptied the cache of my browser but the problem is always the same. I reinstalled version 1.10.1 but still the same thing
viewtopic.php?f=5&t=25485
(219.81 KiB) Downloaded 476 times
Post Wed Jun 05, 2019 3:31 pm
Zip will probably have to examine your log. But it does appear that the Serviio service itself is running. As far as your Windows update, Microsoft has on occasion reset your firewall settings and closed the ports necessary for Serviio to function. But a Serviio reinstall should restore the settings.
When you reverted to 1.10.1, did you first uninstall version 2.0? If not, you may have bits of both versions mixed in there. Do a complete uninstall, reboot the computer (just to make sure everything's closed) and then do a clean Serviio install. Then see if your access is restored.
jocker50
Post Wed Jun 05, 2019 8:00 pm
atc98092 wrote:Zip will probably have to examine your log. But it does appear that the Serviio service itself is running. As far as your Windows update, Microsoft has on occasion reset your firewall settings and closed the ports necessary for Serviio to function. But a Serviio reinstall should restore the settings.
Good evening,
Thank you for your reply.
indeed, I followed your recommendations and it re-works very well now with version 2, just to redo my settings.
again a big thank you for your help.
cordially
