serviio not working with windows 1903
since the update of windows 10 version 1903 serviio no longer works, I tried the versuy 2 of serviio but same failure. I can no longer access the consolle.
do you have an idea?
cordially
atc98092 wrote:Zip will probably have to examine your log. But it does appear that the Serviio service itself is running. As far as your Windows update, Microsoft has on occasion reset your firewall settings and closed the ports necessary for Serviio to function. But a Serviio reinstall should restore the settings.
When you reverted to 1.10.1, did you first uninstall version 2.0? If not, you may have bits of both versions mixed in there. Do a complete uninstall, reboot the computer (just to make sure everything's closed) and then do a clean Serviio install. Then see if your access is restored.
Users browsing this forum: Google [Bot] and 54 guests
