Problem: Can't change user assigned to a device
Post Sat Aug 17, 2019 12:18 am
Zip, while assisting another user, I discovered an issue with user accounts. I created a second user account and tried to change the user assignment on a device that had the original user name. It appears to save, but when I leave the Status tab and then return, the device is back to the originally assigned user. I also tried changing the user to unassigned, but the same thing happens. I can change the rating assigned to the user account that is stuck on the devices, and that works correctly. While I was testing this on several Roku players, I also tried it on a Samsung TV with the same result, so it doesn't appear to be device specific.
wind998
Post Wed Sep 04, 2019 10:56 pm
Re: Problem: Can't change user assigned to a device
I confirm the bug. Me too, im not able to change the user previously assigned to every device.
please correct this in the source code.
BurstPace
Post Mon Sep 09, 2019 3:08 am
Confirmed here too. Validated permissions. Restarted service, server, not resolved. Nothing remarkable in the logs either.
Post Wed Sep 11, 2019 3:15 pm
nkodak
Post Wed Dec 11, 2019 9:29 pm
Hey Zip.. I see you've fixed this bug in the 2.1 build.. any idea when that's going to be released?
Keep up the good work. Love this product.
Serviio 2.4 Pro on CentOS 9 | Roku 4K Streaming Stick | Onn Roku TV | HD & 4K TV's
Moggwald
Post Sun Dec 29, 2019 9:31 am
Just come across this bug and am hopeful to see this fixed in Serviio.
