Why can not see it after I add YouTube online resources?
colemanlee
Post Wed Oct 09, 2019 4:12 pm
I have added the Youtube.groovy to D:\Program Files\Serviio\plugins, and follow the steps in this page https://forum.serviio.org/viewtopic.php?f=20&t=3276, but I still can not see any Item in MediaBrowser webpage.
What's wrong with my steps?
Origin playlist URL:
https://www.youtube.com/playlist?list=PLLW-qoCMKQsxxXRmzxEJQhUrdX0kekHhV
transfer to playlist Resource URL:
https://www.googleapis.com/youtube/v3/playlistItems?playlistId=PLLW-qoCMKQsxxXRmzxEJQhUrdX0kekHhV
Origin video URL:
https://www.youtube.com/watch?v=mb4hN0TghAw&list=PLLW-qoCMKQsxxXRmzxEJQhUrdX0kekHhV
transfer to video Resource URL:
https://www.googleapis.com/youtube/v3/videos?id=mb4hN0TghAw&list=PLLW-qoCMKQsxxXRmzxEJQhUrdX0kekHhV
Youtube.groovy file infomation:
File Name: Youtube.groovy
File Size: 11.3 KB (11,641 Bytes)
MD5: A5383086C36E44781564991D2F4313B6
CRC32: 1CC8C60A
But this serviio://video:feed?url=http%3A%2F%2Ffeeds.hd-trailers.net%2Fhd-trailers&name=feeds works well.
Post Wed Oct 09, 2019 7:34 pm
Re: Why can not see it after I add YouTube online resources?
I tried your playlist and it should work. Are you sure you enable the web resource for your users (if you're using Pro)?
Can you post your log?
colemanlee
Post Thu Oct 10, 2019 1:21 am
zip wrote:I tried your playlist and it should work. Are you sure you enable the web resource for your users (if you're using Pro)?
Here is the relevant log:
2019-10-10 09:02:53,952 WARN  [FeedUpdaterWorker] An error occured while parsing the online resource https://www.googleapis.com/youtube/v3/playlistItems?playlistId=PLLW-qoCMKQsxxXRmzxEJQhUrdX0kekHhV, will try again soon: Error during feed reading. Message: connect timed out
org.serviio.library.online.metadata.OnlineResourceParseException: Error during feed reading. Message: connect timed out
   at org.serviio.library.online.feed.FeedParser.parse(FeedParser.java:109)
   at org.serviio.library.online.OnlineLibraryManager.findResource(OnlineLibraryManager.java:185)
   at org.serviio.library.online.OnlineLibraryManager.findResourceInCacheOrParse(OnlineLibraryManager.java:207)
   at org.serviio.library.online.metadata.FeedUpdaterWorker.getOnlineItems(FeedUpdaterWorker.java:194)
   at org.serviio.library.online.metadata.FeedUpdaterWorker.run(FeedUpdaterWorker.java:100)
   at java.lang.Thread.run(Thread.java:748)
Caused by: java.net.SocketTimeoutException: connect timed out
   at java.net.TwoStacksPlainSocketImpl.socketConnect(Native Method)
   at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:350)
   at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:206)
   at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:188)
   at java.net.PlainSocketImpl.connect(PlainSocketImpl.java:172)
   at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392)
   at java.net.Socket.connect(Socket.java:589)
   at sun.security.ssl.SSLSocketImpl.connect(SSLSocketImpl.java:666)
   at sun.net.NetworkClient.doConnect(NetworkClient.java:175)
   at sun.net.www.http.HttpClient.openServer(HttpClient.java:463)
   at sun.net.www.http.HttpClient.openServer(HttpClient.java:558)
   at sun.net.www.protocol.https.HttpsClient.<init>(HttpsClient.java:264)
   at sun.net.www.protocol.https.HttpsClient.New(HttpsClient.java:367)
   at sun.net.www.protocol.https.AbstractDelegateHttpsURLConnection.getNewHttpClient(AbstractDelegateHttpsURLConnection.java:191)
   at sun.net.www.protocol.http.HttpURLConnection.plainConnect0(HttpURLConnection.java:1156)
   at sun.net.www.protocol.http.HttpURLConnection.plainConnect(HttpURLConnection.java:1050)
   at sun.net.www.protocol.https.AbstractDelegateHttpsURLConnection.connect(AbstractDelegateHttpsURLConnection.java:177)
   at sun.net.www.protocol.http.HttpURLConnection.getInputStream0(HttpURLConnection.java:1564)
   at sun.net.www.protocol.http.HttpURLConnection.getInputStream(HttpURLConnection.java:1492)
   at java.net.HttpURLConnection.getResponseCode(HttpURLConnection.java:480)
   at sun.net.www.protocol.https.HttpsURLConnectionImpl.getResponseCode(HttpsURLConnectionImpl.java:347)
   at org.serviio.util.HttpClient.retrieveStreamFromConnection(HttpClient.java:200)
   at org.serviio.util.HttpClient.retrieveBinaryFileFromURL(HttpClient.java:89)
   at org.serviio.util.HttpClient.retrieveBinaryFileFromURL(HttpClient.java:105)
   at org.serviio.library.online.feed.FeedParser.parseFeedStream(FeedParser.java:120)
   at org.serviio.library.online.feed.FeedParser.parse(FeedParser.java:89)
   ... 5 more
Jimbo
Post Sun Nov 10, 2019 5:07 am
YouTube has been flaky for a couple of months. At first, it would go down for a few hours each day. It went away completely a couple of weeks ago on the windows 10 system. It came back about 3 days ago and worked properly for a couple of days then went away again and is still gone.
I installed Serviio on a windows 7 system when youtube first started acting up. It worked fine on windows 7 from the beginning and didn't fail until yesterday. Now youtube is flaky on win 10 and win 7 systems.
Other non-youtube plugins continue to work fine.
All other methods that I use to access youtube work fine. The problem is only with the serviio plugin so far.
I just figured that youtube was testing potential changes when it would go down for a gew hours then return.
This is one of my web resources that I use
https://www.googleapis.com/youtube/v3/c ... iatedPress
Jimbo
Post Wed Nov 20, 2019 9:07 pm
Well, youtube is now working. I hope they are finished with their testing.
Return to General discussion
Users browsing this forum: Google [Bot] and 10 guests
