Code for Panasonic BDT110 to play DTS files on DLNA
Laz Baz
Post Fri Nov 01, 2019 8:00 pm
The Panasonic plays discs very well.
I would like to play my DTS movies via Serviio Server but the player does not play "cannot play" message comes up.
Is there a code that can be implemented so it will play DTS?
Please help
Samsung UE55JU7000; Panasonic BDT 110; Cambridge Audio 640; IMF TLS80 Mk II front & Yamaha centre & surround speakers
Post Fri Nov 01, 2019 8:39 pm
Re: Code for Panasonic BDT110 to play DTS files on DLNA
I'm assuming you are using the "Panasonic BD player" profile. It does have a DTS capture line, but only for H264 video. If your DTS files are from DVD rips, or if it's a Blu Ray rip with DTS Master Audio, there doesn't appear to be a match. Please confirm the codecs within one of your unplayable files and we'll see what can be fixed for you.
See my sig line for a link to assist discovering the contents of your media.
Laz Baz
Post Mon Nov 04, 2019 1:13 pm
Dear DLNA Master,
I have attached all the information of 3 DTS MKV ripped files.
I trust you can help me out.
Regards
William
Panasonic BDT110 Code for Serviio.docx
(353.22 KiB) Downloaded 612 times
Post Mon Nov 04, 2019 4:10 pm
Laz Baz wrote:Dear DLNA Master,
Regards
William
Yep, there's the problem. Your first two files have DTS Master Audio, and the Panasonic BD profile does not capture that. Your third file is MPEG-2 video and DTS audio. That also is not captured by the profile.
So, as a test try using the Roku TV profile. It will capture both audio codecs and leave the video alone. That's what you need, the audio only transcoded. Your player will the video just fine for all three. It's just the audio that's tripping it up. It's strange that your player isn't playing the standard DTS audio, but many BD players will not stream DTS Master Audio via DLNA.
And your comment at the bottom of the document about no FF or rewind. Unfortunately, most players cannot do so with transcoded files. The Roku TV profile I suggested you try uses HLS transcoding, and some players will allow FF and rewind with that method. So let us know if it works with that one.
Once we've confirmed that those videos play with the Roku TV profile, then we can create a user profile for you to use to best match up with your player.
Laz Baz
Post Tue Nov 05, 2019 12:00 pm
Hi again,
I found the exercise very confusing.
Please see my attachment.
PS: Personal message: How did your daughter do in Cambridge?
ROKU Profiles.xlsx
(10.43 KiB) Downloaded 602 times
Post Tue Nov 05, 2019 1:58 pm
Well, it seems the Panasonic player doesn't care for HLS transcoding. We'll have to try something different. I'm at work now, so don't have access to the profiles file to look for a different one to try. You could experiment with some other profiles, just as a test. There's several Sony player profiles that might help.
But the jerkiness you are seeing puzzles me. I'm wondering if you're having network issues. Are you hard wired or using WiFi?
Daughter came home with her M-Phil (Masters) after 10 hectic months. She's now working at one of our state universities, doing what she loves, research.
Post Wed Nov 06, 2019 1:22 am
Here's one you could try: "Philips (2010-)". This profile captures DTS and DTS HD audio and transcodes it to Dolby Digital. Doesn't touch the video. And it's using the TS container, which should be fine for your BD player.
After that, we'd probably have to begin experimenting with a custom built profile, but we really need to find one first that handles at least some to most of your files as a starting point.
Laz Baz
Post Wed Nov 06, 2019 11:43 am
Hi Dan,
I tried all the Sony profiles and does not work.
Just tried Philips 2010 and still "Cannot play" shows up.
I will wait your next advice.
Regards
William
Laz Baz
Post Wed Nov 06, 2019 10:22 pm
Just to be clear, you said ""Philips (2010-)". This profile captures DTS and DTS HD audio and transcodes it to Dolby Digital."
I do not want the DTS to be converted to Dolby Digital. I want original DTS to be played back as DTS or DTS HD as it may be.
Perhaps I was not clear on this at the start.
Regards
William
Post Wed Nov 06, 2019 11:59 pm
OK, we have to find out why a Blu Ray player that supports all of these codecs is refusing top play almost anything. I think we need a detailed log showing an attempt to play something that doesn't work.
Switch back to the Panasonic BD profile, stop the Serviio service, enable detailed logging, delete your log file so we have a clean log, then start the Serviio service back up and try to play something you know doesn't play. Then stop the service, zip up the log file, disable detailed logging and start Serviio again. Then upload that log here and I'll see if I can spot something. I'm not an expert at examining the log, but I'll give it a shot.
All of that I just typed is much easier to do that you'd think looking at the instructions. Trust me, you can do it. :)
Laz Baz
Post Thu Nov 07, 2019 9:26 pm
Please find attached the debug log file. I first tried to play a video with transcoding turned on which works but only with DD5.1. Then the same video again with transcoding turned off which results in an error message "Cannot Play" on the blu-ray player.
Thanks for any and all help given on this.
serviio.zip
(185.8 KiB) Downloaded 558 times
Post Fri Nov 08, 2019 4:05 pm
Laz Baz wrote:Please find attached the debug log file. I first tried to play a video with transcoding turned on which works but only with DD5.1. Then the same video again with transcoding turned off which results in an error message "Cannot Play" on the blu-ray player.
OK, I see the playback of Master and Commander with transcoding in the log, apparently working correctly. You say it works transcoded with DD5.1. That's the way it's supposed to work. Your audio cannot be transcoded into DTS, so DD is what you should see. With the transcoding disabled, I would expect it to not work.
So, what I'm looking for is a video that still won't play with transcoding enabled.
Looking at your previous quote, maybe we're having a communications issue between us. You said
If your player won't support DTS over DLNA, there's no way to play your videos with DTS audio. They have to be transcoded to DD. I downloaded the users manual for your player, but unfortunately they don't list what codecs are supported. But it sounds like it doesn't support DTS in any flavor over DLNA, and there's nothing we can do about that.
Laz Baz
Post Sat Nov 09, 2019 11:19 am
1. Thank you for stating that Panasonic BDT110 will not play back DTS on DLNA. I did read the manual and it was clear that it will play DTS discs but I could not find where it clearly says it will not play DTS on DLNA.
Thank you for helping me on this subject.
2. Could you point me to the direction I should be looking to solve : When Paused, it cannot be resumed, have to start from beginning; Can FF but does not resume and Cannot Forward to Chapters.
Any help will be welcome.
Regards
William
Post Sat Nov 09, 2019 8:14 pm
Laz Baz wrote:1. Thank you for stating that Panasonic BDT110 will not play back DTS on DLNA. I did read the manual and it was clear that it will play DTS discs but I could not find where it clearly says it will not play DTS on DLNA.
Regards
William
When you say pause, do you mean playback stopped and you are attempting to resume where you stopped, or just pausing playback with an image on the screen? For transcoded files, things like resume, chapter select and FF (usually referred to as trick play) generally aren't available. Depending on the player and the format used for transcoding, sometimes trick play can work, but with the limited functionality your player seems to have it's unlikely it will work.
Laz Baz
Post Thu Nov 14, 2019 2:56 pm
Sorry for the late response.
Yes. When playing a Blu Ray disc or DVD, it can be paused and resume, Fast Forward and Skip chapters, that's what I mean.
Say if I went for a KODI box like this: https://www.amazon.co.uk/Android-T9-RK3 ... 636&sr=8-1 ; will it allow the full functions I listed?
Advice is very welcome.
Regards
William
Post Thu Nov 14, 2019 4:40 pm
Laz Baz wrote:Sorry for the late response.
Regards
William
Yes, when files are transcoded and streamed via DLNA those trick play functions generally aren't available. I use Kodi on an Nvidia Shield and all of those functions are available. That's because the Shield (which is an Android box) has support for all of the codecs and containers that I use. I can't say for certain that any Android box will do the same, but chances are good. It will certainly support far more than your Panasonic BD player.
Users browsing this forum: No registered users and 67 guests
