Browsing OK but no streaming on Samsung TV
Pierremenard
Post Sat Feb 01, 2020 2:38 pm
I used to use Minidlna server on my Raspberry PI for sharing videos in the house. I'm trying to switch to serviio, as I was missing some features.
The server works flawless when I use my pc as client (both VLC nd WMP).
But from my Samsung TV (QE49Q64RATXZT) I can browse folders and categories without problems but when I try to launch a movie the stream can not be played. It stucks on loading wheel.
Transcoding is off and the same file can be played from minidlna. So I think it's not file related. I tried to change several profiles (but with transcoding set to off I do not know if that could help) but no one worked.
Below you can find my log.
Thank you very much for your help
F.V.
2020-02-01 15:29:22,896 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1, format AVC_MKV_HP_HD_AAC_MULT5 and profile Samsung TV / player (C/D-series)
2020-02-01 15:29:22,900 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1 (local)
2020-02-01 15:29:22,902 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1)
2020-02-01 15:29:22,911 DEBUG [VideoDAOImpl] Reading a Video (id = 1)
2020-02-01 15:29:22,916 DEBUG [VideoDeliveryEngine] Delivering item '1' for client 'Identifier=192.168.100.117, Profile=Samsung TV / player (C/D-series), Name=QE49Q64RATXZT'
2020-02-01 15:29:22,917 DEBUG [VideoDeliveryEngine] Delivering file '1941 allarme a Hollywood (1979).mkv' in native format
2020-02-01 15:29:22,923 DEBUG [MediaItemDAOImpl] Getting file of media item 1
2020-02-01 15:29:22,933 DEBUG [GETMethodProcessor] Stream entity has length: 499231458
2020-02-01 15:29:22,934 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Length: 499231458,Content-Type: video/x-mkv,Cache-control: no-cache,Connection: close,Content-Range: bytes 6144-499237601/499237602,contentFeatures.dlna.org: DLNA.ORG_PN=AVC_MKV_HP_HD_AAC_MULT5;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,Date: Sat, 01 Feb 2020 14:29:22 GMT,realTimeInfo.dlna.org: DLNA.ORG_TLAG=*,Server: Linux UPnP/1.0 DLNADOC/1.50 Serviio/2.0,transferMode.dlna.org: Streaming]]
Post Sat Feb 01, 2020 6:15 pm
Re: Browsing OK but no streaming on Samsung TV
Hi, try to use the latest Samsung profile - or disable transcoding altogether.
Pierremenard
Post Sat Feb 01, 2020 6:26 pm
Thank you for the suggestion, but as I wrote transcoding is off and I've already tried all the Samsung profiles. The supposed stream should be the same for minidlna and serviio (the untouched media file), but it's not.
F.
n3mmr
Post Wed Feb 05, 2020 4:52 pm
Pierremenard wrote:Thank you for the suggestion, but as I wrote transcoding is off and I've already tried all the Samsung profiles. The supposed stream should be the same for minidlna and serviio (the untouched media file), but it's not.
F.
Have you solved your problem?
Pierremenard
Post Wed Feb 05, 2020 6:35 pm
No, still stuck on loading from the Samsung TV. I'm still using minidlna for that.
F.
Post Wed Feb 05, 2020 6:46 pm
Samsung in general has miserable DLNA support. I have three different Samsung sets, and all three have something external connected for streaming. On my two 4K sets I have an Nvidia Shield, and the smaller set has an old Sony SMP-N200 that's still kicking. I also have a couple of Vizio sets that I feel the same way about. I use a Roku on one, while the others are mainly used as PC monitors, so I don't stream to them anyway.
Honestly, you'll be far happier using something other than the Samsung interface. Even on a 55" TV I have trouble seeing the cover image for my movies, and there's no metadata whatsoever available.
Pierremenard
Post Wed Feb 05, 2020 6:49 pm
Sincerely I don't know. What I know is that minidlna as server works flawlessly, serviio does not. With the same file, not transcoded, same network and same TV. It's quite odd.
F.
shinoda
Post Tue Feb 18, 2020 7:42 pm
Which Samsung TV are you using? Could you please tell me the model name?
Pierremenard
Post Wed Feb 19, 2020 8:34 am
Yes, it's QE49Q64RATXZT
Thank you
F. V.
