Sony S570 stuttering - how do I change the socket buffer?
witters
Post Tue Feb 01, 2011 12:21 am
I am suffering from stuttering on m2ts files with HD audio. I believe I need to change the socket buffer? How do I do this please?
Post Tue Feb 01, 2011 8:50 am
Re: Sony S570 stuttering - how do I change the socket buffer
See FAQ: How to pass system properties to Serviio
http://www.serviio.org/component/content/article/21#q7
zip wrote:There is now (for some time) a settable socket size option, which might in some cases remove stuttering. Can you guys give it a try?
You'll have to set a system property on the Serviio service:
-Dserviio.socketBuffer=<number of bytes>
Default value is 65536.
witters
Post Tue Feb 01, 2011 8:54 am
Thanks but I need it spelling out a bit more if possible :D I'm not the most computer literate.
Any chance of a step by step please?
Post Tue Feb 01, 2011 9:12 am
For windows users:
- Edit [Serviio_Install_Path]\bin\ServiioService.exe.vmoptions file with Notepad
- You will find this line "-Xmx384m"
- Add this line "-Dserviio.socketBuffer=<number of bytes>" with <number of bytes> default value is 65536, you can change value
- Save file.
- Restart the Serviio service
- Check on [Serviio]\log\serviio.log logging file if socketbuffer change
witters
Post Tue Feb 01, 2011 9:41 am
Many thanks.
I have accessed the file and added the line -Dserviio.socketBuffer=<100000> but the log file does not update?
Post Tue Feb 01, 2011 9:46 am
remove the <> :
-Dserviio.socketBuffer=100000
witters
Post Tue Feb 01, 2011 9:50 am
Thanks again. Done bu sadly makes no difference. What is the maximum figure?
Post Tue Feb 01, 2011 10:22 am
Up to you
witters
Post Tue Feb 01, 2011 7:43 pm
Has made no difference. Is there anything else I can try please?
Post Tue Feb 01, 2011 7:55 pm
post ffmpeg -i of the file
Dejavu
Post Mon Apr 18, 2011 9:14 pm
I have the same problem with a KDL-32EX500.
I tried setting the socketbuffer to 262144 and then 33554432, that didn't seem to change anything.
The serviio log confirms the setting were applied.
here's the ffmpg -i output for the file :
FFmpeg version git-N-29157-gc967860, Copyright (c) 2000-2011 the FFmpeg developers
built on Apr 17 2011 13:48:41 with gcc 4.5.2
configuration: --enable-gpl --enable-version3 --enable-runtime-cpudetect --enable-memalign-hack --enable-avisynth --enable-bzlib --enable-frei0r --enable-libopencore-amrnb --enable-libopencore-amrwb
--enable-libfreetype --enable-libgsm --enable-libmp3lame --enable-libopenjpeg --enable-librtmp --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-libvpx --enabl
e-libx264 --enable-libxavs --enable-libxvid --enable-zlib --cross-prefix=x86_64-w64-mingw32- --target-os=mingw32 --arch=x86_64 --extra-cflags=-I/home/kyle/software/ffmpeg/external-libraries/win64/incl
ude --extra-ldflags=-L/home/kyle/software/ffmpeg/external-libraries/win64/lib --pkg-config=pkg-config
libavutil 50. 40. 1 / 50. 40. 1
libavcodec 52.119. 1 / 52.119. 1
libavformat 52.108. 0 / 52.108. 0
libavdevice 52. 4. 0 / 52. 4. 0
libavfilter 1. 79. 0 / 1. 79. 0
libswscale 0. 13. 0 / 0. 13. 0
[matroska,webm @ 00000000003FA420] Estimating duration from bitrate, this may be inaccurate
Seems stream 0 codec frame rate differs from container frame rate: 47.95 (5000000/104271) -> 23.98 (24000/1001)
Input #0, matroska,webm, from '_hd\The.Animatrix.2003.720p.BluRay.x264-HANGOVER\h-animatrix-x264.mkv':
Duration: 01:40:50.68, start: 0.000000, bitrate: 640 kb/s
Stream #0.0(eng): Video: h264 (High), yuv420p, 1280x528, PAR 1:1 DAR 80:33, 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default)
Stream #0.1(eng): Audio: ac3, 48000 Hz, 5.1, s16, 640 kb/s (default)
Post Tue Apr 19, 2011 7:17 am
Could you check the average and peak video bitrate of your file with that tool : viewtopic.php?f=17&t=2133 ?
Dejavu
Post Tue Apr 19, 2011 9:00 am
Illico wrote:Could you check the average and peak video bitrate of your file with that tool : viewtopic.php?f=17&t=2133 ?
The average bitarate on this file is 5572 kbps and the highest peak 25363 kbps.
video bitrate screenshot
Dejavu
Post Tue Apr 19, 2011 10:27 am
This file played nicely today, even over wifi !
I'm wondering if the fact I had a download running on the disk when I tried it yesterday wasn't responsible for the stuttering.
Or maybe some other processes were slowing it down...
Anyway, I'm very happy to be able to play 1080p over wifi now :)
Post Tue Apr 19, 2011 10:46 am
Dejavu wrote:This file played nicely today, even over wifi !
Good, but I think you'll have stuttering with such movie, 25Mbps its a very high bitrate for Wifi
